Alaskan Impreza Club
Old 08-04-2009, 04:55 PM   #1
chanomatik
Member#: 159474
2013 BRZ Ltd 6MT CBS
SNOSLO
Default Spazzak's Boost Issue: Input Please
I'm posting this on behalf of Billboard2001 who's asking on behalf of spazzak (adam):
"adam has what sounds like a boost leak to me. he's not really hitting any boost until like 5k rpm and then even so it's a wimpy pull, not like it used to be. my guess is a leak in the turbo inlet tubes or vac. lines or somethin like that, or the wastegate arm may be loose. the turbo still spools and sounds normal, he's just not getting boost. I was doing some rough research trying to diagnose the problem and that's my guess. Lemme know if you have any other ideas or had anyone that had similar problems.
Thanks, Bill"
The car is a bugeye WRX sedan. Anyone have any ideas? You can pm Billboard2001 or spazzak direct or just reply here. Thanks guys.
-Chano
Last edited by chanomatik; 08-05-2009 at 04:55 PM. Reason: "What kind of car is it", he asks?
chanomatik is online now   Reply With Quote
Old 08-05-2009, 04:40 AM   #2
sol0
Member#: 152976
TDI Jetta/VW Bus
92 Integra RaSecar
I would get ahold of a intake system boost pressure tester. You can usually fab one up out of pvc, sealant, and a tire valve stem. I know that there are a few people on the board that have a few, but I forget exactly who.
Google is your friend if you want to try to make your own.
Hook up the tester to your system and using an air compressor, pressurize the system to specified psi (like 22psi). Listen for hissing, that is your problem. If its the wastegate arm, that won't show its ugly face because its obviously not on the cold side plumbing. GL with troubleshooting!
sol0 is offline   Reply With Quote
Old 08-05-2009, 05:30 AM   #3
TurboSetch
Member#: 192358
MANY P3 Import Auto
907 355 6655
A leak that big you should be able to see or hear. Look for a big rip in the IC hose.
What kind of car is this? We need a little more info...
Go back to the basics. Worst case you have a bad turbo or damaged internals. Also leaking manifold exhaust or intake could cause this.
What does vac read at idle? Should be around 20 on the vac gauge?
TurboSetch is offline   Reply With Quote
Old 08-05-2009, 04:54 PM   #4
chanomatik
Member#: 159474
SNOSLO
My bad. I knew I forgot something. It's a bugeye WRX sedan. I'll edit my OP.
Grah! Compressor Calculations, RiftsWRX, Anybody Yer input please! sherifx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 9 05-07-2002 12:06 PM
Rifts your input please... sherifx Mid West Subaru Owners Club Forum -- MWSOC 20 04-22-2002 11:40 AM
Blitz FMIC/SBC owners - input please rayder Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 04-11-2002 05:46 PM
Unsure of problem... input please. TFW Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 12 03-27-2002 07:01 AM
your input please! wrx for sale! need advice! fooie8 General Community 6 12-29-2001 05:10 PM
