Welcome to the North American Subaru Impreza Owners Club Monday July 28, 2014
Old 08-04-2009, 06:04 PM   #1
WheelieMonster
Member#: 206241
2004 Impreza STI
Rally Blue
Default shifting into 4th gear issues
Recently I have been having a issue while shifting only into 4th gear...it will shift fine into 4th for about 15min but after it gets warmed up it grinds (like its goin into 4th hard) when going into the gear from 3rd to 4th but not from 5th to 4th...if i shift super slow letting my rpms get all the way down it wont grind sometimes...does anyone have any ideas of what might be causing this?
WheelieMonster is offline   Reply With Quote
Old 08-04-2009, 06:06 PM   #2
alexmartynyuk
Member#: 191967
2002 wrx
Captain America tuned
Worn out synchros maybe?
alexmartynyuk is offline   Reply With Quote
Old 08-04-2009, 06:08 PM   #3
WheelieMonster
Member#: 206241
2004 Impreza STI
Rally Blue
how big of issue might this be to have fixed?..should i trust a local guy that does good work or go to a dealer?
Old 08-04-2009, 06:09 PM   #4
seanathanq83
Member#: 173241
2002 s256 twinscroll
now with one more gear
syncros, i am having the same problem, i went and put plain coastal 80/90 gear oil and it went away for a little while, about 5k, i am going to redo it and see, have been contemplating putting some of the redline lightweight or whatever it is they call it
seanathanq83 is offline   Reply With Quote
Old 08-04-2009, 06:10 PM   #5
seanathanq83
Member#: 173241
you could prbably buy a new tranny for the price someone would charge you now days 5 speeds are cheap, and syncros normaly are not to much but you might as well do all of them while you are in there
Old 08-04-2009, 06:10 PM   #6
WheelieMonster
Member#: 206241
2004 Impreza STI
Rally Blue
i had a bad feeling thats what was going on..how much r the redline syncros your talkin about?
Old 08-04-2009, 06:12 PM   #7
ej_trbo_si_eater
Member#: 148009
use thicker non synthetic gear oil or just wait an extra half to 3/4 seconds to put it into gear.. double clutching helps you to wait.. i have the same problem its just that the gear ratios from third to 4th are such a big difference... best solution- DOGBOX
ej_trbo_si_eater is offline   Reply With Quote
Old 08-04-2009, 06:14 PM   #8
ej_trbo_si_eater
Member#: 148009
an the sychros for just fifth an reverse were somethin ridiculous like 280 at cost from the dealership.. oh an by the way dont go to the dealership they would rather put a new trans in it or charge you an unbelievable amount of money .. find somebody local or do it urself theres a thread on here somewhere on how to do it iv done it its reall not all that hard
Old 08-04-2009, 06:34 PM   #9
solidace46
Member#: 208431
2002 WRX Stage 2
I have the same exact problem you do, if it bothers you that bad, shift into fifth first, then back down into fourth and it won't give you problems. At least that works on mine, but mine has been doing it for about a year so I know how to shift into it perfectly fine, just gotta be slow and easy with it and its fine. I just dont wanna fork up a couple hundred if I don't need to
solidace46 is offline   Reply With Quote
Old 08-04-2009, 06:37 PM   #10
Haelan
Member#: 151045
2013 Subaru STI
CBP
I thought my 4th gear synchro was dead. I used a transmission cocktail available at Grimmspeed and not only did it clear up all my grinding...I can shift into 1st gear rolling at 20 mph.
Needless to say I am happy as hell
Haelan is offline   Reply With Quote
Old 08-04-2009, 06:52 PM   #11
SubySal
Member#: 43011
2004 Impreza RS
PacificaBlue/BlackTarmacs
I had the same exact problem. Grinding on the 3>4 upshift when the fluid warmed up and thinned out.
I kinda wonder what kind of oil you using? I was using Redline 75W90NS and it worked OK for a while, but I won't use it again since better options are available.
I've come to learn Subaru transmissions break down their fluid rather quickly as some owners are changing tranny oil at 10,000 miles.
Anyway after researching doing a rebuild on the tranny I came across some useful info. If you use Swepco 201 80W90 or Subaru Extra S 75W90 chances are the tranny will go back to shifting like a dream. As I said I had the same exact problem. A few weeks ago I changed out to the Swepco oil.
IT'S AWESOME!!!
Today for instance I took a spirited drive. The car shifts better than it ever has. At high RPM I can upshift instantly. Downshifting has become easier too even with double-clutching.
SubySal is offline   Reply With Quote
Old 08-04-2009, 06:57 PM   #12
Audiosavvy
Member#: 150794
Qcab dakota 4x4
LT1 Formula Firebird
I had grinding issues going from neutral to 1st, and then from 3rd to 4th, especially when shifting fast at the track. New fluids cured that problem.
Audiosavvy is offline   Reply With Quote
Old 08-04-2009, 11:49 PM   #13
WheelieMonster
Member#: 206241
2004 Impreza STI
Rally Blue
thanks for the help..i think i am goin to train the fluid and try the transmission cocktail at Grimmspeed and hope that cures my problem..this will be the first time changing it since i bought the car about 10000 miles ago..whats the best way to do it..any tips or tricks i should know about?
Old 08-05-2009, 12:12 AM   #14
WheelieMonster
Member#: 206241
2004 Impreza STI
Rally Blue
do i use all of the fluids they have together for the cocktail?
Old 08-05-2009, 07:54 AM   #15
Spenk
Member#: 7164
2000 Miata LS
Evo Orange Mica (1/644)
http://www.scoobymods.com/manual_tra...43.html?t=1743
You'll probably get ~12K-15K out of the cocktail before you start getting a grind on 4th again. It worked great for me, but I wanted a fluid that I could get more life out of, so I tried Extra-S and it's heavenly.
Spenk is online now   Reply With Quote
Old 08-05-2009, 08:33 AM   #16
Haelan
Member#: 151045
2013 Subaru STI
CBP
Yes, mix them all in a large container. Drain your existing fluid. Put drain plug back in. Get a long funnel and fill through the transmission dip stick hole. Pour it SLOWLY or your new fluid is going to gargle and splash all over the place.
Old 08-05-2009, 02:14 PM   #17
SubySal
Member#: 43011
2004 Impreza RS
"Heavenly", "Liquid gold"...seems to be the concensus on Extra S. I figure I'll go to 20-25,000 with the Swepco unless the tranny starts acting up first. Depending on how the Swepco performs I may try Extra S next change. This time around Swepco was easier to get.
FWIW I'm not a big fan of cocktails. Results have been mixed at best from "this stuff is awesome" to "my transmission now needs a rebuild".
Old 08-05-2009, 02:19 PM   #18
AndrewtechAutomotive
Member#: 99694
2002 dogbox,'11 wrx
I continually recommend 3-quarts of Redline Lightweight Shockproof and 1-quart of Motul Gear300-75W90.
The only complaints I've ever gotten about this mixture are from people who had literally broken synchros. No fluid will fix that.
Phil
Andrewtech Automotive
AndrewtechAutomotive is offline   Reply With Quote
Old 08-12-2009, 12:00 AM   #19
WheelieMonster
Member#: 206241
2004 Impreza STI
Rally Blue
u have changed my mind on the cocktail and think im goin to go with the "extra s" but can i get this at a parts store or is it somethin i need to order online?..a a 2002 is 3.6 quarts rite?
Old 08-12-2009, 05:09 AM   #20
SubySal
Member#: 43011
2004 Impreza RS
Extra S is available from Subaru, but only in 5 gallon (20L) drums that go for about $150-170 (like this).
However some Suby sites online have started to sell it by the quart out of said drums. This shop for example... http://www.fredbeansparts.com/servle...ra-S%22/Detail
Old 08-15-2009, 11:29 PM   #21
subbie37
Member#: 211354
06 STI
Java Black
i have the same problem. shift from 3rd to nuetral then to 4th. its stops the grind
subbie37 is offline   Reply With Quote
Old 08-17-2009, 03:52 PM   #22
reyrey
Member#: 211909
2006 wrx
white
i have that same prob and i wanna do an sti tranny swap but too pricey so i plan to rebuild wid double syncros and harder gears
reyrey is offline   Reply With Quote
High Pitch Grinding Sound When Shifting Into 4th Gear mcrawford Newbies & FAQs 3 10-09-2007 01:10 PM
Weird 4th gear issue (not really a grind): jacobsen1 Transmission (AT/MT) & Driveline 5 05-11-2007 01:46 PM
I get an odd grinding noise when throwing into 4th Gear? VIRULENT Factory 2.0L Turbo Powertrain 18 04-25-2007 10:55 AM
04 STi 4th Gear Issues kujo79 Transmission (AT/MT) & Driveline 5 07-13-2005 02:11 PM
I grind going into 4th gear- is my synchro shot? SleepyRex Transmission (AT/MT) & Driveline 33 05-30-2004 04:50 AM
