Old 05-02-2002, 03:11 PM   #1
rupteur7000
Member#: 11585
02 2.5RS
i am also not a p****
Question intake experts Q?
i made a ganzflow replica diameter about 2.4". unfortunately i just did a temp test in the intake and the temp of the air going in the tube increases quite a bit while in the tube. i wanted to if i should :
1) ditch that one, it is heavy and aluminized steel, get the PDM one for $50
2) work on this one with isulating material until i can get it to the rigth temp, ie aluminum shields around the engine, plus thoce beer cans slieves.
3) just go for the cobb
thanks guys
rupteur7000 is offline   Reply With Quote
Old 05-02-2002, 11:00 PM   #2
HondaH8er
Member#: 3097
2013 Ford Focus ST
Performance Blue
The Cobb intake will increase the intake temp as it travels through the tube also, since it's still made of aluminum. I saw a post recently where someone tested several, and the Cobb showed that in thier tests. I have a GanzFlow, and I insulated it using Frost King self-adhesive foil-backed foam. I don't have anything to measure charge temp differences, but I'm sure this helps stop it from warming up too much.
HondaH8er is offline   Reply With Quote
Old 05-03-2002, 06:47 PM   #3
tonytiger
Member#: 3844
1993 Legacy 1.8
I'm interested in how much did it increase inside the tube. Do you still have the results?
tony
tonytiger is offline   Reply With Quote
Old 05-03-2002, 07:17 PM   #4
Reciprocity
Member#: 1165
2012 dcrawford died
for your sins
Try these links
First one
and...
There ya go.
n00b! Sorry...OT gets to me sometimes.
NC
Reciprocity is offline   Reply With Quote
Old 05-04-2002, 09:20 AM   #5
Stealthbmbr
Member#: 13823
2009 Legacy 2.5i SE
C A P S CAPS CAPS CAPS
Good info dc. Try a test and tune at a local drag strip and run the test again. This time you will have actual et's to go with it.
Stealthbmbr is offline   Reply With Quote
Any porsche experts here? freetors Off-Topic 183 06-07-2011 10:18 AM
FS: APS Pod Intake, APS 3" Turbo Inlet, OEM 04-05 Fog Lights with Bezels lancelucas NWIC Private Classifieds 17 06-09-2010 02:05 PM
FS: Headers + Uppipe, Cobb Intake, VF39, STI TMIC, Boost Controller ProjectChaos SCIC Private Classifieds 44 06-03-2010 11:24 PM
EcuTek experts or ECU experts - HELP! big_adventure Engine Management & Tuning 6 09-13-2003 01:52 PM
Need math / physics experts help to design new intake tube alfriedesq Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 28 07-26-2002 12:53 AM
