#1 |
Member#: 144550
Hey can someone please tell me where I can tap Tach wire for my remote starter. I can remote start just fine but it keeps engaging starter every 15-30 seconds. So I think the unit does not know the car has been started w/o tach input. I've read and read then finally posted for HELP...
#2 |
Member#: 111735
South East
Vehicle:96 Legacy2.0GTSOLD Bimmer Tech |
lol. thats funny, let me dig through some diags.
#3 |
Member#: 111735
South East
![]() there ya go. courtesy of northursalia.com better one ![]() |
#4 |
Member#: 144550
Thank you TurboL...fortunately I've 2200cc (2.2L) engine in my Legacy. Are B134, B135 and B136 located by the passenger foot well behind the plastic cover on the side wall?
#5 |
Member#: 36735
Vehicle:99 GF8 Impreza 2.0 2= 1998 BD + BK Legacy GT |
Those are ECU pinouts. You're going to pull up your passenger side carpet, and undo the footplate that guards the ECU. You'll see the corresponding plugs there, you can trace them back or splice directly in there.
#6 |
Member#: 4273
NESIC
Vehicle:2011 GR-STI & 2013 Impreza Sport |
If your engine has sparkplug wires and not coil packs, you can get tach from the distribution center where the 4 spark plug wires go on the intake manifold... should be a plug with a few wires... get a multimeter and test, one will be the right wire.
Alternatively, (At least this works on newere Subies, if you have a tach on the cluster, you can pull the cluster and get a wire there.) |
#7 |
Member#: 144550
I pulled carpet and took off metal plate covering the ECU. Found B134 connector and PIN 30 is blank. My car specs are 1999 Subaru Legacy L (Brighton) with 2.2 L engine and AT transmission. Looking at the coil with spark plug wires connected, I see one connector w/clip going to coil. I've read numerous post here stating "Blue wire with red dots at coil" but I'm not able to find it. I'm looking at ECU now but the above diagram is not for 2.2L. PLEASE HELP as my interior is in disarray right now and want to put it together before I forget all.
#8 | |
Member#: 4273
NESIC
#9 |
Member#: 144550
without cutting wires at the coil, how can I test them?
#10 |
Member#: 4273
NESIC
#11 |
Member#: 144550
There is a connector with four wires at the coil. Tested blue wire with multimeter set to AC and still not getting tach signal.
| Thread Tools | |
| Display Modes | |
| Got a 1999 Legacy Brighton wagon...now what? | fasterthanrayswrx | Legacy Forum | 18 | 12-20-2007 09:55 PM |
| Remote Start Tach Wiring Question (i'm all searched out) | i102spd | Car Audio, Video & Security | 8 | 10-18-2005 09:52 AM |
| Remote starter - help locate tach wire | Impregacy | Car Audio, Video & Security | 2 | 08-25-2004 05:28 PM |
| Tach (rpm) wire location? | slimjim04 | Electrical & Lighting | 3 | 06-09-2003 08:16 PM |
| Need Location of Tach Wire for WRX Autostart | hman | Car Audio, Video & Security | 6 | 05-11-2001 09:35 AM |
