Old 08-06-2009, 04:43 PM   #1
compressro
Member#: 193383
2004 WRX WRB
97 Impreza Wagon
Default JDM STI RA Gears & STI 6-Speed (Looking for opinions and advice)
I am looking for opinions on the JDM STI RA gears. I've done some searching and it looks like there are a lot of varied opinions.
I own an 02' WRX and its manufactured date is 04/01. So if I'm correct, I definitely own the weakest of the "glass trannys".
Anyways, I am getting ready to do a EJ205/EJ257 hybrid swap and am afraid of doing damage on the weak trans. I've been looking into tranny options and it looks like the RA gears would be a good choice for both the power I will be making and the budget I am in.
My tuner is expecting to pull about 300awhp and 350 ft lb torque out of the wrx. From what I've been reading that falls right into the reliability of the RA gears.
I've got about $2,400 to spend on a tranny solution. If I had the $ then I would simply go for the STI 6-speed. I'm open to saving up for it so if anyone can help me with the best option of the 6-speed that would help too. I'm basically just looking to know what MY would be best to fit with the 02'. I want to replace the least amount of parts possible during the swap.
All advice is appreciated, thanks guys.
compressro is offline   Reply With Quote
Old 08-06-2009, 05:22 PM   #2
AndrewtechAutomotive
Member#: 99694
2002 dogbox,'11 wrx
Based on my experience, there is no legitimate "reliability range" for RA gears.
You'd want an 06 STi 6MT. It's almost a bolt-in replacement, needing just a few additional parts in order to work.
If you aren't drag racing, I'd go the 6MT route. It'll probably save you a little money over PPG's.
If you are drag racing, then I'd consider waiting and saving for a more reliable gearset.
Phil
Andrewtech Automotive
AndrewtechAutomotive is offline   Reply With Quote
Old 08-07-2009, 10:11 AM   #3
compressro
Member#: 193383
2004 WRX WRB
97 Impreza Wagon
Phil
Thanks for the info on the 6-speed, still considering just going for that in the long run. Any opinions on the legacy gt 5-speed?
Old 08-07-2009, 10:34 AM   #4
Member#: 99694
2002 dogbox,'11 wrx
I feel about the same on all OEM gearsets. I wouldn't try to run more than 280 wheel through any of them (other than the 6MT). Whether or not other people have been fine making more power, I see too many failures to feel comfortable with that.
Phil
Old 08-07-2009, 12:58 PM   #5
Adrenalinecrisis
Member#: 84519
2005 LGT wagon
one other option to look at is Mfactory's 1-4 gearset. Its been tested up to 375 ft/lbs without breaking. The only downside is that they are a little bit more expensive. Defiantly an option i'd check out if i were in your situation.
Adrenalinecrisis is offline   Reply With Quote
Old 08-09-2009, 10:00 AM   #6
02WRX"monster"
Member#: 173100
sorry to hijack but why would you not recommend the 6speed MT for drag racing use?
02WRX"monster" is offline   Reply With Quote
Old 08-09-2009, 01:58 PM   #7
JSarv
Member#: 163445
l33t *******
[email protected]
Mainly because of ratio's... I'm at the end of 4th gear in my 6 speed in the 1/8th mile... I may/may not get out of 5th in the 1/4...
Most Dog boxes will be a 1-2 and maybe 3 1/8th and 4th 1/4... Meaning you have 1 less shift which will shave at least .1 seconds off your times...
Reliablity with the 6 speed isn't the issue.
-jerod
JSarv is offline   Reply With Quote
Old 08-12-2009, 12:31 AM   #8
drewdogg
Member#: 90003
2005 STi
drewdogg is offline   Reply With Quote
Old 08-12-2009, 10:17 AM   #9
Member#: 99694
2002 dogbox,'11 wrx
I don't know about you, but I'd rather NOT shift 4, maybe 5, times through the 1/4 mile.
Phil
alright alright PPG vs sti Ra gears vs sti 6mt youngW03 Subaru Conversions 9 04-20-2009 04:24 PM
JDM type RA-R shift knob 6 speed for sale mint wrb2006sti Interior/Dressup/Audio & Security 1 07-19-2007 01:43 AM
JDM V6 RA Tranny & 99 2.5rs tranny for sale!! JlDlM GC8 Private 'For Sale' Classifieds 3 05-13-2005 11:55 AM
STI RA gears vs STI non RA gears rexorama Transmission (AT/MT) & Driveline 8 12-14-2004 07:36 PM
Looking for opinions and images on the Tanabes vs Pinks... asceleon Brakes, Steering & Suspension 2 04-27-2004 10:55 AM
