![]() Tire & Wheel Forum sponsored by The Tire Rack |
#1 |
Member#: 179937
NWIC
Vehicle:2002 WRX PSM |
Found a set of 215/50/16 tires from a local member that were on his Forester. They will fit stock WRX wheels (2002) correct? Any caveats/benefits to this size?
#2 |
Member#: 122305
SWIC
Vehicle:2002 wrx half breed Aspen White |
Yeah they will fit quite nicely you could fit 225's on but thats a bit big and with it being 50 it means just alittle less side wall play so your good to go it will change your speed but i never noticed a change from when i had 45's and went to 40's so who knows technically it should change slightly.
#3 |
Member#: 179937
NWIC
Thanks for the quick info, I appreciate it.
#4 |
#Belieber
Moderator Member#: 140163
Vehicle:03 STi hellaflunctional |
http://www.miata.net/garage/tirecalc.html
215/50/16 is slightly smaller in diameter than the stock 205/55/16, so your speedo will read 60mph when you're actually going 59mph. |
#5 |
Member#: 177401
Vehicle:2004 STi White 16G powered lagless fun |
The wrx benefits from extra tire width and a slightly shorter tire. Both of these are benefits of 215/50/16 over 205/55/16. They'll work fine.
| Thread Tools | |
| Display Modes | |
| 225/50/16 Victoracers on stock WRX wheels OK? | Snowphun | Tire & Wheel | 4 | 12-18-2005 11:08 PM |
| 225/50/16 slicks on stock wrx wheels? | lettucemanatee | Tire & Wheel | 4 | 04-20-2005 12:53 AM |
| pic request, 215/50/16 tire on stock rim | disaster999 | Member's Car Gallery | 1 | 12-02-2004 10:12 AM |
| 215/45/16 fit on stock WRX Wagon wheel? | 5-speedfreak | Tire & Wheel | 7 | 03-07-2004 04:54 AM |
| 225/50/16 fit on stock rim? | bluestone | Tire & Wheel | 10 | 01-09-2004 07:30 AM |
