Old 08-06-2009, 06:04 PM   #1
stage2??
Member#: 192590
2007 STI
Default Can i wash my floormats in the washing machine?
is it alright to wash my sti's floormats in the washing machine?
stage2?? is offline   Reply With Quote
Old 08-06-2009, 06:36 PM   #2
John__Gotti
Member#: 70598
The Oil patch, as
fun as it sounds
Guess you could but might mess up the machine. I would recommend just pressure washing them. Have done this many times with good results and most wash bays have clamps on the wall you can hang them form so they don't get dirty on the floor.
John__Gotti is offline   Reply With Quote
Old 08-06-2009, 06:43 PM   #3
John__Gotti
Member#: 70598
The Oil patch, as
fun as it sounds
edit: double post, crap server at work
Old 08-06-2009, 07:50 PM   #4
Ryan314
Member#: 82989
Hybrid EJ257
I have washed my mats in the washer before... leaves a huge mess in your washer though. I don't think I would do it again...
Ryan314 is offline   Reply With Quote
Old 08-06-2009, 07:57 PM   #5
V6TurboTA
Member#: 9090
09 Forester Gump
02WRX->04STi->09Gump
+1
Make sure you do it on a day where they will dry or you risk getting mold in your car... and thats the LAST thing you want.
Either a warm day, or a few dry days in a row...
V6TurboTA is offline   Reply With Quote
Old 08-06-2009, 08:57 PM   #6
sic08wrx
Member#: 192100
08 wrx
dgm
If your going to machine wash just go to a laundry mat
sic08wrx is offline   Reply With Quote
Old 08-06-2009, 09:26 PM   #7
trueno16v
Member#: 175170
2005 WRX Wagon
owl + bungee cord= my a$$
+1 for screwing up someone else's washer.
If you've ever powerwashed floormats you'd know how dirty they are. The dirt just keeps coming and coming no matter how may passes you make. Helps to hang them up vertical and spray them.
trueno16v is offline   Reply With Quote
Old 08-06-2009, 09:31 PM   #8
jaypt802
Member#: 149730
2002 Impreza WRX
I've done it several times, just make sure you get all the little rocks out.....and just vacuum right before putting it in the washer. it will leave a mess in your dryer, you can get away with just letting it air dry for a day or two.
jaypt802 is offline   Reply With Quote
Old 08-07-2009, 12:04 AM   #9
nevin95 LSi
Member#: 219571
'02 wrx wagon 288k+
'95 SVX ebony mica
I and a friend own a detailing business together and we have cleaned many a floormat with the good 'ole pressure washer. It really is the easiest way, and won't make a mess or possibly ruin your washing machine.
Keep in mind that if they're in a washing machine and it gets out of balance it could realyl screw some things up inside there. Not saying it can't be done, but there are just better ways! Pressure washer, baby!
p.s. FIRST POST!!
nevin95 LSi is offline   Reply With Quote
Old 08-07-2009, 12:25 AM   #10
Smoke
Member#: 172486
95 V4 STi-RA swap
Stage 49.8
Go to a self-use car wash.
Smoke is offline   Reply With Quote
Old 08-07-2009, 09:08 AM   #11
timmah
Member#: 54203
2011 WRX
yeah, not a good idea. you'll end up with alot of sand and grit in the bottom of your washer. don't ask me how i know this.
timmah is offline   Reply With Quote
Old 08-07-2009, 04:07 PM   #12
HappyIdiot
Member#: 83494
2004 WRX Wagon
Red
+1 on the pressure washer. I tried the washing machine once with my mats and one of the mats got caught under the spindle. It ate the side of my mat off. Power washing is so much easier and only takes a few minutes. I like to spray some 303 High Tech Fabric Guard on my mats once they dry.
HappyIdiot is offline   Reply With Quote
Old 08-08-2009, 02:45 PM   #13
nevin95 LSi
Member#: 219571
'02 wrx wagon 288k+
'95 SVX ebony mica
+1 on putting something on when you're done.
We use 3m Scotch Guard on our customer cars. Works great, and makes cleaning the next time easier.
Old 08-08-2009, 02:48 PM   #14
nathan379
Member#: 219065
2003 Impreza WRX
There was a ton of oil spilled on teh pass. mat when I bought my car. I vac'd them real well and washed them. I put the washer on the "hand wash" setting and they faired well.
The only thing is they are a dark gray, almost black and it faded them a bit. Pressure washed probably wouldn't have done that.
nathan379 is offline   Reply With Quote
Old 08-09-2009, 02:23 AM   #15
pnutbutta
Member#: 192572
2007 Impreza
CGM
i suggest using a pressure washer as well. also, if you spray some carpet cleaner on them and agitate with a brush while the mat is wet, it will help with getting the dirt out. the foaming action will act as a suspender for the dirt and lift it a bit, making it easier to clean. then power wash all the chemical out (dont use too much chemical or youll be there all day). then when you have to dry them, get a pants hanger you would use to dry pants, and clip your mats and allow to hang dry. then, once most of the water has dripped out, prolly about 30 mins or so, take an ice scraper that you use to take ice off your windows and squeegee the bottoms of the mats (or vacuum if you have a wet/dry vac, which is prolly better)
pnutbutta is offline   Reply With Quote
Old 08-09-2009, 09:33 AM   #16
DetailersDomain
Member#: 165558
I would say pass on putting floor mats in the washer /dryer. if the back of the mats break down in the washer you will have a mess on your hands.
your better off doing the pressure washer method.
DetailersDomain is offline   Reply With Quote
Old 08-10-2009, 02:30 PM   #17
DC16A2
Member#: 174357
2002 OBS
When I had carpet mats, I just lathered them up with a brush and garden hosed them down.
DC16A2 is offline   Reply With Quote
Old 01-06-2010, 10:22 PM   #18
Wrgb
Member#: 169096
2009 DGM STi Hatch
2000 2.5RS *Gone*
Has Anyone thought about getting them Dry cleaned... i have some stains and stuff that arnt coming off with a pressure washer
Wrgb is offline   Reply With Quote
Old 01-06-2010, 10:43 PM   #19
DetailersDomain
Member#: 165558
i would agree pressure washer and hang dry
Old 01-07-2010, 11:05 AM   #20
Kean
Member#: 25187
'08 Foz Prem TGM
'10 Challenger R/T Blk
....try using a carpet cleaner and agitation. ....then pressure wash or thouroughly rinse with a strong stream of water.
Kean is offline   Reply With Quote
Old 01-07-2010, 11:30 AM   #21
scooby_wooby
Member#: 79653
I don't own a
suby. I just lurk.
I use the washer from the laundraumat out of town in order not to break my washer and let it hang dry with no issues.
scooby_wooby is offline   Reply With Quote
Old 01-07-2010, 11:31 AM   #22
WRXav8r
Member#: 98548
2015 Crosstrek
Oxy clean works the best (RIP Mr. Mays). Dilute in garden sprayer, spray on mat, brush with bathroom cleaner brush, rinse. For the really bad stains let it sit for awhile or use a steam jet cleaner. (I am addicted to infomercials).
WRXav8r is offline   Reply With Quote
Old 01-07-2010, 12:42 PM   #23
Hedbergsuby07
Member#: 160840
2007 impreza
urban gray scoooped
all weather is where its at just take them out and a little soap and water with elbow grease bam your done.
Hedbergsuby07 is offline   Reply With Quote
Old 01-07-2010, 05:52 PM   #24
turbo20valve
Member#: 223733
2002 WRX wagon
Just buy new ones. I picked up a set of brand new black WRX mats for $35 + shipping from genuinesubaruparts. STi ones aren't too much more than that. Even if I had spent a couple hours cleaning mine, they wouldn't have looked this good. Totally worth it IMO. Keep the old ones for when you play in the dirt.
turbo20valve is offline   Reply With Quote
Old 01-07-2010, 08:06 PM   #25
Wrgb
Member#: 169096
2009 DGM STi Hatch
2000 2.5RS *Gone*
I Think you might have the right idea... Which ones did you get for 35$?
Taking my clothes out of the washer and I found a quarter in the wash tub. Brad Pittiful Off-Topic 21 06-21-2009 06:13 PM
can you wash wrx floor mats in the washing machine? blackie Interior & Exterior Modification 8 10-31-2004 10:46 PM
Washed my car in the rain T-WRX Mid West Subaru Owners Club Forum -- MWSOC 1 05-31-2004 04:08 PM
How can i get my car in the sema show STEALTH-WRX Southern California Impreza Club Forum -- SCIC 20 09-27-2003 03:36 AM
Can I mount my MBC in the cabin? STiShawn Normally Aspirated with bolt-on Forced Induction Powertrain 7 10-16-2001 12:48 PM
