Old 08-06-2009, 11:50 PM   #1
2.5iSTI
Member#: 162585
2007 03 Evo w/2.3
Default Boost logging maxed at 18.43?
I have been doing some logging in my car and it is saying the car is topping out at 18.43 psi uncorrected. 04 STI ECU is what I am using. Does anyone know if this is it? I thought I was good at least till 22 psi. Any input is appreciated.
2.5iSTI is offline   Reply With Quote
Old 08-07-2009, 11:44 AM   #2
the suicidal eggroll
Member#: 51961
2005 STi
2012 WRX
What parameter are you logging?
Use "Manifold Relative Pressure (direct)"
Old 08-07-2009, 02:59 PM   #3
2.5iSTI
Member#: 162585
2007 03 Evo w/2.3
I used corrected today and it logged what I believed it to be(a tick over 20 psi). I will try the direct thing though.
Old 08-08-2009, 08:48 PM   #4
fastblueufo
Member#: 212154
02 billet crank
pauter rods, pt5857, E85
On the 04 sti ecu the right peram to log is manifold relative pressure 4 bit.
fastblueufo is offline   Reply With Quote
Old 08-13-2009, 03:51 PM   #5
2.5iSTI
Member#: 162585
2007 03 Evo w/2.3
the 4 byte is working great. What is the advantage of the 4-byte logging?
Old 08-13-2009, 04:05 PM   #6
Dubstar112
Member#: 143149
2006 gmc envoy
stealth
More precision from the 4 byte logging.
I always use Manifold relative pressure from my car and it peaks at 18.43 psi... should I try logging with a different manifold pressure parameter and see ?
Dubstar112 is offline   Reply With Quote
Old 08-13-2009, 05:07 PM   #7
Member#: 51961
2005 STi
2012 WRX
You should always use either the (direct) or (4byte) parameter
Old 08-13-2009, 06:34 PM   #8
Tea cups
Member#: 103136
if the 2-byte version is available for your ECU, I would use that instead of the 4-byte. It also has no effective limit for turbo models.
Tea cups is offline   Reply With Quote
10.85 at 129.43 New best time jasv11 Proven Power Bragging 36 07-17-2009 09:29 PM
boost problem: tuner says its maxing at 6 lbs birchwood Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 11-16-2007 05:17 PM
Does cobb ap2 boost reading max at 18.4lbs? STI_SLC AccessPort 22 01-07-2007 11:47 PM
Help with log max out wastegate and fuelpump jdgrimm Engine Management & Tuning 2 05-15-2006 10:37 AM
Hitting Fuel Cut and Boost cut at 18 PSi HELP!! ChrisV-FL Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 08-11-2002 10:36 AM
