08-07-2009, 12:37 AM | #1 |
Member#: 154434
NWIC
Vehicle:2009 WRX Hatch <@_@> SWP |
DIY: 2009 wrx tail light mod (only 10 dollars!)
2009 wrx 5 door DIY tail light overlay mod:
Conducted by Super_HKS So let me start out by saying this mod is AMAZING. So after thinking of some cheap tint overlay ideas at work while being bored out of my mind, I googled transparent red paint and sure enough I ran into the Krylon stained glass spray paint. I knew right away for 9.99 I couldnt not try it. Well after telling my buddy about the mod, he told me that a couple guys on nasioc had already done it. I was a little bummed cause I honestly thought I was going to be super innovative and genius but someone already beat me to the punch. Well good news is that all the DIY mods for the tail light on nasioc are for a 2008 wrx and the 2008 and 2009 wrx are a little bit different in terms of removing the lights so basically in this demonstration, I will show you guys step by step on what to do. Hope you enjoy because I sure did. Best 9.99 spent on the car yet. Materials needed for this mod: -Window cleaner (Lights need to be clean when being painted) -Krylon transparent (color code is 9020) (I purchased mine at Michaels) -A small ratchet -10 MM small socket -8 MM small socket _An extender to reach the bolt to remove the reverse lights (Extender is shown in pix) -Painters or masking tape -Towel or a clean material for cleaning lights (preferable microfiber cloth) -Phillips screwdriver -flat head screwdriver or some type of flat item -Clear coat enamel spray paint Directions for removing both lights: 1. Start by popping the hatch open.. For the outer lights, start to loosen them by using the 10MM socket. Once loosened (doesnt take much), take your flathead screwdriver and remove the bolts out. 2. Use a little force and remove the lights. (dont be affraid to show the light whos boss, your not going to break it). There is no other bolts of screws holding it in place. Once the light is removed, remove the clip that connects the lights up. (Put light aside and repeat with other side) 3. Now we will move on to the revease lights, remove the plasic covers on the inner hatch liner. (use a flathead or another item that can get it open) 4. Remove the clip that connects from the car to the rear bulb 5. Also remove the bulbs so you can lay the lights down flat instead of having them slant. (To remove the bulbs, just twist slightly to the left) 6. Now this is probably going to be the hardest part of the whole mod. Removing the liner in the hatch. Basically just yank and pull it around until the clips snap out. Dont be affraid to pull it hard. It will sound like your breaking it but it is very very sturdy plastic. Once you yank the liner out, move on to the next step. 7. After that is done, take your ratchet and your 8 MM socket and remove the 2 bolts connecting the tail lights 8. Now left is 1 more nut and this is a tricky son of a bitch. What you will need to do is throw on your extender and reach up into the area and loose the nut and get it out. 9. After you remove the nut, remove the light (repeat on both lights), now we can move on to prep and paint
08-07-2009, 12:38 AM | #2 |
Member#: 154434
NWIC
Directions for prep and paint:
1. First spray your window cleaner on your lights and wash them off with a clean towel or cloth (insure they are super clean) 2. After all lights are cleaned, get your masking tape and start marking off the reverse section and anything else you would like. there are 3 or 4 different variations of this mod so if you want to paint it all red, forget about the masking off section. When completing the masking off section properly, it will look like this: 3. Take your transparent red spray paint and start spraying the lights. (for a lighter red, only use 1 coat of paint on the lights, for medium darkness, use 2 coats. And for a really dark red smoke, use 3 coats.) <=== I only used 2 coats of spray paint 4. After the spray paint has dried 100% or close to it, take your clear coat/enamel and spray 1 coat of clear coat. (You can use more than 1 coat of enamel/clear coat but do keep in mind, if you do this, the light will be more textured 5. After that has dried, remove the masking tape if applied and now install your lights back into your car. 6. Step back and look at your lights for 2 hours and take lots of pix. FINISHED: Thanks for taking the time to stop by and checking this mod out. Hope I helped and if you need any help please ask Sincerely -Daniel |
08-07-2009, 12:54 AM | #3 |
Member#: 138187
NWIC
Vehicle:2008 2.5i 5-Door DGM |
Very nice tut, I might just give this a go.
08-07-2009, 01:03 AM | #4 |
Member#: 207366
SCIC
Looks good, just have to make sure you mask it nice n tight.
08-07-2009, 01:22 AM | #5 |
Member#: 154434
NWIC
Do it. I was kind of nervous about doing it but I really wanted to get rid of the altezzas!
For sure!!!!! That would suck if you left a little slit and it got paint on it. I overlapped the tape to insure that from not happening. |
08-07-2009, 01:42 AM | #6 |
Member#: 149317
Vehicle:'95 BMW M3 (E36) Hellrot |
The good thing about this stuff is you can get it right off with some lacquer thinner and paper towel. Just rub pretty hard and it slowly comes off. I used this stuff on my foglights (but in yellow) and just recently removed it.
edit: I wish they sold it in black at Michael's though, I want to do my reverse lights. |
08-07-2009, 01:45 AM | #7 |
Member#: 179573
South East
Vehicle:2002 MBP Bugeye Flip Flop Tuned on corn |
Well damn that looks amazing. Good job man!!
08-07-2009, 01:50 AM | #8 |
Member#: 199365
Vehicle:06 sti sgm |
nice job
08-07-2009, 01:52 AM | #9 |
Member#: 138187
NWIC
You live so close, i might just have to strike up a deal for you to do that to my car =)
08-07-2009, 02:36 AM | #10 | |
Member#: 154434
NWIC
Thanks guys I really appreciate it Quote:
Are you too nervous to do it yourself? PM me and we can get something going -daniel |
08-07-2009, 03:03 AM | #11 |
Member#: 216231
SCIC
Vehicle:2009 2.5i Sedan SWP 2002 Suzuki SV650S Silver |
That looks so much better. If I had the hatch I would definitely go that route. Where did you get the color-matched center piece?
08-07-2009, 04:49 AM | #12 | |
Member#: 154434
NWIC
Upgraded turbo (faster in a 1/4 mile than a stock STI!!!!!) red stitched interior no chromy pieces on the car gunmetal rims etc, etc,etc. The difference between the two cars is very significant. Check out cars101.com for all the differences. Also check this out!!!! 2008 vs 2009 wrx. The 09 absolutly walks all over the 08. Subaru really did do a phenominal job with getting customer feedback on the 08's and really made something special with the 2009's. I hated the 2008's when they came out because of all the chrome and all the bling than when the 2009's were released, they really caught my eye! |
08-07-2009, 08:02 AM | #13 |
Member#: 212277
RMIC
08-07-2009, 08:36 AM | #14 |
Member#: 212589
Vehicle:12 135i alpine white |
looks very clean. nice job man.
08-07-2009, 01:12 PM | #15 |
Member#: 118789
NWIC
Vehicle:I just went from six to midnight... |
That looks fantastic Daniel! Basically perfect***8230;
Can't wait to see it in person. (Maybe next Tuesday?) |
08-07-2009, 01:28 PM | #16 |
Member#: 194826
Vehicle:'09 WRX 5dr PP DGM '07 VTX1300c, '03 VFR800 |
Looks awesome!
It's a very smooth finish -- no sanding? Cool! Extra THANKS for the color code too, maybe I can ask them at Michaels since they don't have it around here/don't know what the hell I'm talking about. I like the results from the Krylon better than the Testor's. How long ago did you do this? Are you waxing the paint on the lights or leaving it as is? And those shiny UR flaps are growing on me... looks great!! I've heard good things about the VHT nightshades. It was very very popular on the honda/acura boards I was on before this.. I've since grown wiser and traded up to a WRX |
08-07-2009, 01:37 PM | #17 |
Member#: 101691
Vehicle:97 Supra TT SOLD - 35r bug/hawkeye |
did you clear over the red only or did you take the tape off and clear the entire light?
looks great BTW, they should have really came like this already. |
08-07-2009, 01:40 PM | #18 | |
Member#: 194826
If you didn't take the tape off to clear, does it have a little lip where the paint leaves off? |
08-08-2009, 08:16 PM | #19 |
Member#: 155492
NWIC
Vehicle:2009 OBS Silver |
great write up HKS - much appreciated. I still can't decide whether to go vinyl or paint on my 09 OBS. The one thing I've noticed from pics is it seems that when they've been painted they look darker (even with 2 coats) than red vinyl. I like the brighter red myself. Has anyone been able to compare side by side tails that have been painted with someone who's used vinyl?
08-08-2009, 08:35 PM | #20 |
Member#: 146200
SCIC
Vehicle:2009 Supermoto |
Keep us updated after car washes and over time ect..
Ive heard alot from people who painted them, that theres faded. I have the overlays right now, But have always wanted to paint them for a more cleaner look |
08-08-2009, 08:39 PM | #21 |
Member#: 187179
Vehicle:14 STi Cocain |
"Patent Pending" lol this is a sick job man very well done.
08-08-2009, 09:23 PM | #22 |
Member#: 96093
SCIC
Vehicle:2015 impreza wrx Dark gray metallic |
amazingly well done! i think it improves the look of the car sooo much and it is very cost effective. amazing job +1 !
08-09-2009, 12:47 AM | #23 |
Member#: 154374
Vehicle:2011 WRX Sedan Prem Satin White Pearl |
I just did this today thanks to this write-up! I will post pics tomorrow. I did it late afternoon and was dark by the time i put them on the car.
08-09-2009, 08:36 AM | #24 |
Member#: 154374
Took pics this morning!Sorry for the ****ty camera phone quality and the dirty car.
08-09-2009, 06:46 PM | #25 | ||||||
Member#: 154434
NWIC
2. Did this the same day I posted the DIY up. being in Washington, we have very severe weather so ill keep you guys posted via this thread or PM. I am gonna be washing my car probably this week sometime. 3. For sure, the UR mudflaps not only look amazing but they perform amazing as well. I LOVED them on my 2005 and love them even more on my 09 Quote:
AHhaha for sure. I already have people in my state PM'ing me to help em out and stuff Quote:
The pix turned out great. Glad I could help you out man. |
New! Clear Tail Light Mod... WRX Rally Style | Subie Gal | Member's Car Gallery | 33 | 03-15-2011 07:08 AM |
2009 WRX fog light mod | Andrey | Electrical & Lighting | 8 | 04-24-2010 05:43 AM |
WTT: my06 sti taillight for you 05 sti/wrx tail light + $20, local swap only, (FL) | yenny | Private 'Wanted' Classifieds | 2 | 08-02-2009 01:39 AM |
WTT 2006 WRX tail lights for 2005 WRX tail lights | SCRAPPYDO | TXIC Private Classifieds | 4 | 12-04-2006 01:01 AM |
WTT 2006 WRX tail lights for 2005 WRX tail lights | flymordecai | TXIC Private Classifieds | 1 | 11-23-2006 01:07 AM |
