Old 11-01-2011, 09:12 PM   #551
nomad1987
Member#: 295961
Red looks so much better.
nomad1987 is offline   Reply With Quote
Old 11-01-2011, 09:20 PM   #552
cianuro
Member#: 235475
Chapter/Region: PRSIC
2008 WRX
Originally Posted by DrDustin View Post
I do want the cutouts on both, he said I will be able to feel the edge of the paint. I'm moving to Ohio next year and have heard that passing vehicle inspection may be difficult if you paint over the reverse and turn signal. Don't know if anyone else has had a problem with that.
Your paint in the write up looks good BTW.
I'm from PR, but inspections here are not that harsh, plus many american vehicles have red turn signals from the factory. I believe you won't have an issue if you at least leave the reverse lights clear.
cianuro is offline   Reply With Quote
Old 11-02-2011, 11:25 PM   #553
.KR3W.
Member#: 293951
2009 WRX
Hey guys, i'm having trouble removing the fender liner where it connects to the rest of it. I have all the white clips popped out but it's not coming off at the pillers on the side. Top left and right corners of this piece:
Any suggestions? I fear that if i pull too hard that i might break it
.KR3W. is offline   Reply With Quote
Old 11-02-2011, 11:45 PM   #554
thrdeye
Member#: 24569
2004 Mazda RX8
Titanium
all i can say is just pull. It is in there really good, but i just jerked the crap out of it and no issues.
thrdeye is offline   Reply With Quote
Old 11-03-2011, 01:13 AM   #555
.KR3W.
Member#: 293951
2009 WRX
This made me lol. But i ended up just leaving it on there. I was able to get to the bolts without taking it completely off so i didn't bother trying to remove it any further
Old 11-03-2011, 05:39 PM   #556
.KR3W.
Member#: 293951
2009 WRX
How do you get rounded corners with masking tape?. I picked up a roll of clear cupboard/cabinet liner. It has an adhesive backing so this is what i'm doing: Cut out a piece of lining, stick it to the tailight, trace out the lines with a marker where it needs to be masked, take the lining off, attach it to another piece of lining (because the tack would be less adhesive if you take it off to cut it and reattach it) and cut the shape out of the new piece of lining. It's a little bit time consuming but it seems to be a precise way to get detailed corners. It's also a pain in the arse to work with cause it keeps rolling back up whenever i try to cut it, making it hard to get a clean cut - so i'm letting it straighten out atm.
Old 11-03-2011, 10:31 PM   #557
thrdeye
Member#: 24569
2004 Mazda RX8
Titanium
You can round the edges of the tape. Tear off a piece and practice. Not sure how to describe the process of doing it but it's not too hard
Old 11-03-2011, 10:53 PM   #558
cianuro
Member#: 235475
2008 WRX
Did you start with the third brake light area? This is like a puzzle, so you need to start from there, then the sides and leave the trim on the pic for last.
Old 11-04-2011, 12:56 AM   #559
Celery GT-5
Member#: 98210
2016 Forester XT CWP
2002 WRX SRP
i just exacto knifed the tape since i was painting on the line anyway..lol
Celery GT-5 is offline   Reply With Quote
Old 11-04-2011, 02:27 AM   #560
.KR3W.
Member#: 293951
2009 WRX
The way i did it turned out really well. Go to your local canadian tire equivalent and look in the kitchen/organization section for some clear cabinet liner. I was worried that the tack wouldn't be strong enough but it was perfect. And it's cheap too, only cost me $5.
What you do is:
1) Cut liner into a rectangle big enough to fit over what you want masked out (reverse light in this case)
2) Stick it over top of the part you want masked (again, reverse light) and outline the shape with a sharpie
3) Peel off the liner off of the light, stick it onto a fresh piece of liner and cut the shape out of the fresh piece
Done. That way you have perfect corners and edges without having to engrave your headlights like Celery over here haha. You could skip step 3 and just cut out the shape from the original piece, but the adhesive might wear down once taken off so i just played it safe. It may be a little bit more time consuming..or maybe not since i didn't try it with masking tape in the first place..but this way you know it will be super precise.
Old 11-04-2011, 02:41 AM   #561
Celery GT-5
Member#: 98210
2002 WRX SRP
interesting idea
Old 11-04-2011, 09:30 PM   #562
.KR3W.
Member#: 293951
2009 WRX
Just finished with them earlier today and they didn't turn out the greatest. Paint is very light and uneven around the edges on the outside light. I'm gonna have to give them another coat eventually but they don't look too bad from a distance. I also don't think i gave the top clear coat enough time to dry (last coat of clear went on at around 10pm and i wetsanded today at around 1pm). Not to mention i'm having great difficulty trying to put the hatch liner back on..
Old 11-04-2011, 09:35 PM   #563
Celery GT-5
Member#: 98210
2002 WRX SRP
hatch liner should be easy if you do it in the correct order...starting with the top i think, to take it out anyway
Old 11-04-2011, 09:43 PM   #564
.KR3W.
Member#: 293951
2009 WRX
taking it out wasn't bad. But i'm trying to put it back now and i'm having no luck whatsoever
Old 11-05-2011, 08:09 AM   #565
Pineapple Devil
Member#: 261570
2011 WRX Premium
has anyone tried baking the lights and painting the inside?
Pineapple Devil is offline   Reply With Quote
Old 11-05-2011, 08:25 AM   #566
superhit
Member#: 300075
Comes stock using the 2009's. The 2009s I personally don't like to express it but they are 100 occasions much better than the 08s.
Upgraded turbo (faster inside a 1/4 mile than the usual stock STI!!!!!)
red-colored sewn interior
no chromy pieces around the vehicle
gunmetal rims
etc, etc,etc. The main difference between your two cars is extremely significant. Take a look at cars101.com for the variations. Also look at this!!!! 2008 versus 2009 wrx. The 09 absolutly walks all around the 08. Subaru really did perform a phenominal job with getting customer comments around the 08's and extremely made something using the 2009's. I hated the 2008's once they arrived on the scene due to all of the chrome and all sorts of the jewelry than once the 2009's were launched, they caught my attention!
__________________
superhit is offline   Reply With Quote
Old 11-05-2011, 01:55 PM   #567
Celery GT-5
Member#: 98210
2002 WRX SRP
its been covered somewhere before. I think people have done it, but you can't just bake them open, it involve cutting plastic and gluing it back together
gunmetal rims
__________________
cool story bro
Old 11-09-2011, 01:08 AM   #568
.KR3W.
Member#: 293951
2009 WRX
I'm in desperate need of help with re-installing the hatch liner!
Old 11-09-2011, 07:23 AM   #569
jonklein611
Member#: 117776
2011 WRX Limited 5dr
WR Blue Pearl
Talk to me, what's up?
jonklein611 is offline   Reply With Quote
Old 11-09-2011, 07:41 AM   #570
LCBogey
Member#: 291207
2006 Aspen White
WRX Stage 2
I hope nobody makes the same mistake and tries this on an 02-07 model.
I did it and then spent about 2 hrs removing it, looked terrible.
But I sure love it on 08 + hatches!
LCBogey is offline   Reply With Quote
Old 11-10-2011, 12:23 AM   #571
.KR3W.
Member#: 293951
2009 WRX
Well...I can't get the damn thing back on lol. Step by step instructions would go a long way. Pictures would also be most helpful but i don't think anybody wants to go through such lengths to help out a noob haha
Old 11-12-2011, 12:02 PM   #572
Zordos
Member#: 165121
are white clips on the pic you posted broken off? if not the bottom trim piece should pop right back in with little pressure. just line it up as it should be on there.
i could take some pics but i doubt it'll be really helpful since you can't really see much other then when the panel is on or off.
Zordos is offline   Reply With Quote
Old 11-12-2011, 09:05 PM   #573
sobejoe
Member#: 298122
2011 WRX Sedan
first off, i think every hatch should do this mod. I hate the all clear look.
Just in case you all were wondering what blacked out looks like here it is... beware that i went tooooo black and on sunny days it is hard to see blinkers and you may gert pulled over. At night though, it is as if they are stock.
sobejoe is offline   Reply With Quote
Old 11-13-2011, 08:53 PM   #574
0BlueSTi4
Member#: 98955
2011 WRX Hatch
Now that we established what u like and dislike I'll just add that I don't like it and that it's not practical or safe.
Also since all of u seem to be changing ur rear lights I am going to keep mine stock to be different - sorry it's my thing it's what I do...u know!?...
0BlueSTi4 is offline   Reply With Quote
Old 11-13-2011, 08:59 PM   #575
Celery GT-5
Member#: 98210
2002 WRX SRP
yeah if you leave them stock a bunch of guys from 1996 will show up and compliment you on your dope euro tails bro
I agree with you about the blackouts though..look bad and dangerous
New! Clear Tail Light Mod... WRX Rally Style Subie Gal Member's Car Gallery 33 03-15-2011 07:08 AM
2009 WRX fog light mod Andrey Electrical & Lighting 8 04-24-2010 05:43 AM
WTT: my06 sti taillight for you 05 sti/wrx tail light + $20, local swap only, (FL) yenny Private 'Wanted' Classifieds 2 08-02-2009 01:39 AM
WTT 2006 WRX tail lights for 2005 WRX tail lights SCRAPPYDO TXIC Private Classifieds 4 12-04-2006 01:01 AM
WTT 2006 WRX tail lights for 2005 WRX tail lights flymordecai TXIC Private Classifieds 1 11-23-2006 01:07 AM
