Old 11-13-2011, 09:08 PM   #576
sobejoe
Member#: 298122
2011 WRX Sedan
No need to be rude sir.
sobejoe is offline   Reply With Quote
Old 11-14-2011, 01:43 AM   #577
.KR3W.
Member#: 293951
2009 WRX
Originally Posted by Zordos View Post
are white clips on the pic you posted broken off? if not the bottom trim piece should pop right back in with little pressure. just line it up as it should be on there.
i could take some pics but i doubt it'll be really helpful since you can't really see much other then when the panel is on or off.
It's the back part that i'm having trouble with. Like where it connect to the 2 side pillars
.KR3W. is offline   Reply With Quote
Old 11-14-2011, 04:35 PM   #578
sobejoe
Member#: 298122
2011 WRX Sedan
to all you haters......ummm... well i actually for once dont blame you, i hated my lights that dark as well. So, I striped them and redid them. Safety first!
in the sun
in the shade or with a shadow I should say.
Old 11-14-2011, 04:40 PM   #579
Celery GT-5
Member#: 98210
2016 Forester XT CWP
2002 WRX SRP
i you agreed with us we aren't haters..lol
looks much better
Celery GT-5 is offline   Reply With Quote
Old 11-14-2011, 05:30 PM   #580
0BlueSTi4
Member#: 98955
2011 WRX Hatch
Originally Posted by Celery GT-5
yeah if you leave them stock a bunch of guys from 1996 will show up and compliment you on your dope euro tails bro
I agree with you about the blackouts though..look bad and dangerous
At first I wanted to paint them red but the more I wait the more I realize that stock doesn't look all that bad on white and silver cars. I feel like darker colors need this mod the most. But that is once again a matter of personal taste and opinion.
0BlueSTi4 is offline   Reply With Quote
Old 11-14-2011, 06:54 PM   #581
sobejoe
Member#: 298122
2011 WRX Sedan
thanks lol...
to obluesti4 who has a white wrx haha funny, agree to disagree... my final goal is black and white and that is it. no chrome, no blue. But that may take a while cause i want to slow down on the modding, this needs to last 2-3 years.
Old 11-15-2011, 07:06 AM   #582
pip757
Member#: 290221
2004 STI
Black/Gold rims
Wow that really looks factory
pip757 is offline   Reply With Quote
Old 11-15-2011, 07:36 AM   #583
sobejoe
Member#: 298122
2011 WRX Sedan
thanks!
Old 11-15-2011, 10:51 AM   #584
Celery GT-5
Member#: 98210
2002 WRX SRP
stock looks great in the dark..lol
Old 11-15-2011, 01:30 PM   #585
spec b 002
Member#: 217716
2010 STI se
So whats the advantage of wet sanding the tails?
spec b 002 is offline   Reply With Quote
Old 11-15-2011, 01:57 PM   #586
sobejoe
Member#: 298122
2011 WRX Sedan
its not stock... thats with 2 coats of VHT. the blacked out pics were with like 5 or so coats.
The advantage of wet sanding is that it will smoth out the paint so when you buff it will give you a glass like finish which obviously looks a bazillion times better...
Old 11-15-2011, 02:12 PM   #587
spec b 002
Member#: 217716
2010 STI se
and you wet sand before painting?
Thanks!
Old 11-15-2011, 02:20 PM   #588
Celery GT-5
Member#: 98210
2002 WRX SRP
no after
if you can get the paint on very evenly you don't need to wetsand
Old 11-16-2011, 07:54 AM   #589
sobejoe
Member#: 298122
2011 WRX Sedan
wet sanding before add surface area to the tails and will allow the paint to better stick... and i disagree with you celery, wet sanding after is very important as well.. that is the only way you can smooth out the surface and reduce "orange peel" (this is the pitted area you will see when you paint.
However, you can paint without sanding ever. It just want look as good. Same for the clear coat. you dont HAVE to use it, but it will protect the paint. Plus if you do wet sand afterwards then it will be a must unless you want to sand the dark away...
Old 11-25-2011, 12:23 AM   #590
accuracy
Member#: 152151
2011 WRX 5door
Default Removing duplicolor metalcast & clearcoat
I've been reading that to remove the paint, what people have been doing is wetsanding it off. does this work well? and if so, how far down do you sand? like all the way down till nothing left?
I had mine painted over a year ago, but I just didn't do well getting an even coat with my clear the first time around. And i'd hate to ruin $1000 dollar lights for my car.
Is there a general consensus on proper steps for removal for repainting the lights?
accuracy is offline   Reply With Quote
Old 11-25-2011, 12:25 AM   #591
LCBogey
Member#: 291207
2006 Aspen White
WRX Stage 2
Yeah, I just used good old paint remover and scrubbed it off. Took about an hour, but it looks good as new.
LCBogey is offline   Reply With Quote
Old 11-25-2011, 12:39 AM   #592
Celery GT-5
Member#: 98210
2002 WRX SRP
dont use brake clean...one of my lights found out the hard way..lol
Old 11-25-2011, 12:46 AM   #593
accuracy
Member#: 152151
2011 WRX 5door
ooh, paint remover? it doesn't marr up the plastic or etch it?
any specific brand that you would recommend?
thanks
Old 11-25-2011, 01:33 AM   #594
Celery GT-5
Member#: 98210
2002 WRX SRP
i did a test run on a window of a junked car, 3m adhesive remover takes it right off...I would recommend rubbing it on rather than spraying though
Old 11-25-2011, 01:36 AM   #595
LCBogey
Member#: 291207
2006 Aspen White
WRX Stage 2
thanks
Yeah, just good old paint remover. No specific brand, I got mine from Home Depot. I was a little nervous it would muff up the plastic, but it reacted really well to it. Looks like I never even painted it now.
Be prepared to scrub the hell out of it.
Old 11-25-2011, 04:19 AM   #596
accuracy
Member#: 152151
2011 WRX 5door
much thanks guys!
Old 11-25-2011, 10:18 PM   #597
93starletgt
Member#: 302079
much better! i have always hated clear tail lights
93starletgt is offline   Reply With Quote
Old 11-29-2011, 08:38 PM   #598
sobejoe
Member#: 298122
2011 WRX Sedan
gasoline! it worked perfectly without damage. (obviously though, do not let it soak, just pour it on and wipe it and the paint off) I did this with 5 coats of VHT and like 4-5 coats of clear.
Old 11-29-2011, 08:41 PM   #599
cianuro
Member#: 235475
Chapter/Region: PRSIC
2008 WRX
Good to know. Thanks for the tip.
cianuro is offline   Reply With Quote
Old 11-29-2011, 08:42 PM   #600
Celery GT-5
Member#: 98210
2002 WRX SRP
fading...lol
New! Clear Tail Light Mod... WRX Rally Style Subie Gal Member's Car Gallery 33 03-15-2011 07:08 AM
2009 WRX fog light mod Andrey Electrical & Lighting 8 04-24-2010 05:43 AM
WTT: my06 sti taillight for you 05 sti/wrx tail light + $20, local swap only, (FL) yenny Private 'Wanted' Classifieds 2 08-02-2009 01:39 AM
WTT 2006 WRX tail lights for 2005 WRX tail lights SCRAPPYDO TXIC Private Classifieds 4 12-04-2006 01:01 AM
WTT 2006 WRX tail lights for 2005 WRX tail lights flymordecai TXIC Private Classifieds 1 11-23-2006 01:07 AM
