Old 04-07-2012, 11:59 AM   #626
jkacman77
Member#: 316021
2011 WRX
Spark silver
Not bad for ten dollars, from the pics they look factory, nice job!
jkacman77 is offline   Reply With Quote
Old 04-07-2012, 10:59 PM   #627
P_tothe_G
Member#: 311516
2011 wrx hatch
wr blue
yup, I am another convert to painting. Have experience with vinyl work with signage, and was thinking of doing it with bulk sheet (cheap for a 24"x10yd roll). But it would definately be a pita applying to the outer tails. I agree that the overlays can be done to look nice, but the hassle is not worth it. The painting is the way to go...and I will be doing this one soon
P_tothe_G is offline   Reply With Quote
Old 04-10-2012, 01:50 AM   #628
kriswithak
Member#: 315151
2008 STI
after reading this over the weekend i stopped at a local crafts shop and picked up some of the Krylon Stained Glass paint. the previous owner put some vinyl overlays on the tail lights, the inside (on the hatch) lights looked fine, they were starting to peel where the hatch meets the body, but the outside lights had really bad bubbling on the top. so i heated the lights up with a blow dryer and peeled the vinyl off.
scrubbed them down, and started painting.
thats 2 coats red, waited an hour between. just hit them with Crystal Clear right now. waiting to put them on
kriswithak is offline   Reply With Quote
Old 04-17-2012, 12:09 PM   #629
lifeonwalls
Member#: 317150
2009 WRX Hatch
Dark Grey Metallic
As a new Subaru owner/member I wanted to thank everyone who posted tips/hints on how to paint the tails. Did this last night and all of the tips were very helpful - from the steps to remove the inner tails (top/pillars/lower) to the best methods on masking/taping.
I ended up using the plastic sheet method to create a single template that I could use on the inner tails and then masking off the outer ones by hand/eye. I used the Metalcast Red (3 coats) and UPOL clear #1 (2)and they look great. One thing I noticed that one light had some red bleed thru the tape (used 3m blue painters tape) and should have taped it over once more just to be sure.
Be sure to mask them off while they are on car so you can see that they are symmetrical and then when you are painting them have the left/right lined up as they would be on the car so you are making sure to get them as even as possible. I wanted a strip of red between the tail lights and therefore didn't mask all the way to the edge - left about 3/8s of red border.
I purchased this sanding pack on Amazon:
Amazon.com: 3M 03006 Wetordry 3-2/3" x 9" Automotive Sandpaper with Assorted Grit Sizes, (Pack of 5): AutomotiveAmazon.com: 3M 03006 Wetordry 3-2/3" x 9" Automotive Sandpaper with Assorted Grit Sizes, (Pack of 5): Automotive
And while I was working remembered that I had this lens restorer kit leftover which also came in very handy - the lubricating liquid was perfect for the light wet-sanding, especially around the edges.
Amazon.com: Turtle Wax T-240KT Headlight Lens Restorer Kit: AutomotiveAmazon.com: Turtle Wax T-240KT Headlight Lens Restorer Kit: Automotive
It helps if you have some side projects to work on while you wait for it to dry, I cleaned/polished my wheels and exhaust during the wait. All in, it was more than $10 but certainly well under what it would cost for new lights. It took me a few hours to complete - masking took the longest because I wanted to make sure the lines were tight, and then drying time was extended because I did it on a rainy night.
Thanks again!
lifeonwalls is offline   Reply With Quote
Old 04-17-2012, 07:10 PM   #630
SwiftShifter87
Member#: 208994
2009 Impreza WRX/STI
Camouflage Blue
here's an amazing question for this topic. What did you guys use to strip the lights? mine have faded and I've had to strip the paint and do a new coat twice now, obviously because I haven't yet found UV resistant paint, which is fine, but the tail lights get ugly as sin after removing the paint, recommendations suggestions?
SwiftShifter87 is offline   Reply With Quote
Old 05-07-2012, 09:30 AM   #631
lifeonwalls
Member#: 317150
2009 WRX Hatch
Dark Grey Metallic
Is there a DIY for removing the rear spoiler to gain access to the third brake light?
I've taken the trim piece off and see the lines for the power and washer fluid but can't seem to find where to disconnect them. There are two screws that hold the spoiler in on the but I don't want to unscrew those just yet and be left with a dangling spoiler without an idea of how to disconnect safely.
Old 05-07-2012, 09:57 AM   #632
dickiescoob
Member#: 259508
2015 WRX Limited
Spoiler is super easy to remove on the hatch. After the trunk liners, remove the 2 outer bolts, then there is 2 more inner bolts that you will need a deep socket to remove. After those, there are only a few plastic clips, so you just pull it up.
As far as disconnecting power/washer fluid, once the trunk trim is gone, about 4 inches from the center to the left is where you disconnect.
Ill see if I can find a pic sometime today
dickiescoob is offline   Reply With Quote
Old 05-07-2012, 10:55 AM   #633
dickiescoob
Member#: 259508
2015 WRX Limited
Here is a spoiler removed. Notice the disconnect after the rubber seal
And as you can see here, you can remove the spoiler and have a little room to flip it over
Old 05-07-2012, 10:58 AM   #634
lifeonwalls
Member#: 317150
2009 WRX Hatch
Dark Grey Metallic
Awesome, thanks so much for taking the time to upload pics - I appreciate it.
So it looks like you unscrew the two bolts that keep the plastic light piece attached to remove it without having to disconnect the other end of the power line.
Old 05-07-2012, 10:59 AM   #635
dickiescoob
Member#: 259508
2015 WRX Limited
No problem.,lemme know if you have more questions
Old 06-11-2012, 01:12 PM   #636
Celery GT-5
Member#: 98210
2016 Forester XT CWP
2002 WRX SRP
redoing mine today with nightshades red. going solid red on the outer lights because im too lazy to do all that masking again. So far the color looks good but I may have to do some wet sanding
Celery GT-5 is offline   Reply With Quote
Old 06-11-2012, 10:30 PM   #637
laxpro388
Member#: 322935
thats pretty sick man came out nice
laxpro388 is offline   Reply With Quote
Old 06-12-2012, 11:36 AM   #638
Celery GT-5
Member#: 98210
2002 WRX SRP
repainted the outer tails with nightshades
for the record with all the fading and repainting this has cost way way more than $10, its probably closer to $60 at this point and I'm going to need more 3m adhesive remover to get the paint off the center lights and more nightshades. in the long run overlays are much cheaper unless you do an insanely good job
Old 06-13-2012, 12:19 AM   #639
aaronn
Member#: 275418
2010 WRX Hatch
Does anyone else have a problem with fading? I've done this process maybe 3 times, each time looking better and better but it always ends up fading. I'm at a pretty high elevation with really sunny, hot weather which I'm sure doesn't help.
Should a different UV spray completely prevent fading?
aaronn is offline   Reply With Quote
Old 06-13-2012, 12:58 AM   #640
Celery GT-5
Member#: 98210
2002 WRX SRP
I'm thinking VHT nightshades might be better for fading since its made specifically for taillights. Idk a lot of noobs are driving around with blacked out tails and they usually don't look faded. Also they said to use lacquer...I piled a ton on there because I really dont want to do this again...I was thinking of just switching to overlays but removing the paint 100% is pretty hard especially under the sides
I think I may have gone a bit to dark this time but better than fading, I liked the look better with the turn signal masked off but its such a PITA
Old 06-13-2012, 11:23 AM   #641
thrdeye
Member#: 24569
2004 Mazda RX8
Titanium
I have zero fading. Mine were done Oct 16 2011.
VHT nightshades and 3-4 coats of clear.
thrdeye is offline   Reply With Quote
Old 06-13-2012, 11:24 AM   #642
Celery GT-5
Member#: 98210
2002 WRX SRP
good to hear..lol
Old 06-13-2012, 04:21 PM   #643
subyhatch05
Member#: 296700
if done coe right correctly with vht and the right clearcoat, it will last you years and shine as much as a freshly waxed car
subyhatch05 is offline   Reply With Quote
Old 06-18-2012, 11:21 AM   #644
Super_HKS
Member#: 154434
2009 WRX Hatch <@_@>
You may want to consider using a canuba wax on the tail lights 3-4 times a year to give it that much more UV resistant protection. I live in Washington State where we get a ton of gray but I still do notice a little bit of fade after about a year or so. Honestly its not that bad though, all you need to do is give it a very light wet or dry sand with a very high grit sand paper and give it 1-2 coats of paint and 1-2 coats of clear coat. After everything is 100% dry giving it a canuba wax wouldn't hurt anything. (I haven't tried the canuba wax on them yet but I plan on giving my lights a new coat this weekend so I will keep things posted as time elapses)
Super_HKS is offline   Reply With Quote
Old 06-18-2012, 12:49 PM   #645
STi410
Member#: 158800
2010 STi
I just did mine this weekend and used VHT, I did 4 coats of red and 2 coats of clear. Like said before since VHT is made for the lights it will probably last longer.
STi410 is offline   Reply With Quote
Old 06-21-2012, 02:36 PM   #646
Ashr
Member#: 210984
2009 WRX 265
for the life of me I can not find Krylon glass stain...
Ashr is offline   Reply With Quote
Old 06-21-2012, 03:16 PM   #647
Celery GT-5
Member#: 98210
2002 WRX SRP
good, it just fades. Go to advance auto, autozone or amazon.com and get some VHT nightshades red(and possibly some clear lacquer) as per the directions
Amazon.com: VHT Nite-Shades Red Lens Cover Coating SP888 10 oz Spray: AutomotiveAmazon.com: VHT Nite-Shades Red Lens Cover Coating SP888 10 oz Spray: Automotive
Old 06-21-2012, 05:39 PM   #648
scarney1988
Member#: 317760
Anyone ever considered just going to a body shop and having a tinted clear coat applied? Wont be 10 dollars but... their clear coats will last much longer
scarney1988 is offline   Reply With Quote
Old 06-21-2012, 05:55 PM   #649
Celery GT-5
Member#: 98210
2002 WRX SRP
well this isn't $10 either once it fades
Old 06-21-2012, 10:39 PM   #650
cianuro
Member#: 235475
Chapter/Region: PRSIC
2008 WRX
I read a lot here about the paint fading. It all depends on how you did it.
First off, how often do you guys wash the car? If you didn't apply a clear coat, the nightshades will fade because you're washing it down little by little. There's no point in doing this if you're not applying the clear coat. Its point is to protect the nightshades coat.
If you applied clear coat and it still fades, then your clear coat was too thin. Try waxing a corner of the light and look at how the cloth comes out. If it's red, then you no longer have a clear coat.
I did mine almost a year ago, and they still look like they did the first day. I used the vht nightshades in red and Krylon Fusion clear coat. I only polished them once to give them the mirror look, and that was it.
cianuro is offline   Reply With Quote
New! Clear Tail Light Mod... WRX Rally Style Subie Gal Member's Car Gallery 33 03-15-2011 07:08 AM
2009 WRX fog light mod Andrey Electrical & Lighting 8 04-24-2010 05:43 AM
WTT: my06 sti taillight for you 05 sti/wrx tail light + $20, local swap only, (FL) yenny Private 'Wanted' Classifieds 2 08-02-2009 01:39 AM
WTT 2006 WRX tail lights for 2005 WRX tail lights SCRAPPYDO TXIC Private Classifieds 4 12-04-2006 01:01 AM
WTT 2006 WRX tail lights for 2005 WRX tail lights flymordecai TXIC Private Classifieds 1 11-23-2006 01:07 AM
