Welcome to the North American Subaru Impreza Owners Club Thursday August 27, 2015
Old 10-08-2012, 08:28 PM   #726
dsn112
Member#: 332561
2015 Legacy LTD
Twilight Blue
Originally Posted by zwalk
I could do this with the car taped off instead of Poppin em out right
That would be the laziest and most guaranteed way to get some overspray all over your car.
Take them off
dsn112 is offline   Reply With Quote
Old 10-08-2012, 08:32 PM   #727
ChesterWRX
Member#: 328794
2012 WRX Premium
Ice Silver Metal
Take them off
+1.
It more work leaving them on vs removal.
ETA: my krylon should be here this week. Had no luck w / local stores or chains.
ChesterWRX is offline   Reply With Quote
Old 10-08-2012, 10:09 PM   #728
zwalk
Member#: 281705
2005 STi
CGM
I just did tint like that once and I cracked interior trim when I took those out one time haha, granted I'm better at doing this **** now hahaha, anyone know what the RustOleum equiv would be? Guess it doesn't matter I think my Walmart has krylon
zwalk is offline   Reply With Quote
Old 10-08-2012, 10:10 PM   #729
orijinalx
Member#: 253355
2013 VW Golf R
Finally did mine. Taking off the plastic trim was a PITA, hardest part of the whole process lol. I also used VHT Red, which came out pretty good.
orijinalx is offline   Reply With Quote
Old 10-08-2012, 11:13 PM   #730
dsn112
Member#: 332561
2015 Legacy LTD
Twilight Blue
The only thing I would do is do the third brake light too. Looks out of place being clear still
Old 10-08-2012, 11:15 PM   #731
Celery GT-5
Member#: 98210
2015 WRX Premium 6MT
i have water in my left reverse light...too much abuse from recoating
Celery GT-5 is offline   Reply With Quote
Old 10-11-2012, 05:34 PM   #732
ChesterWRX
Member#: 328794
2012 WRX Premium
Ice Silver Metal
see post 718. FAIL.
the bad:
Old 10-11-2012, 05:35 PM   #733
Celery GT-5
Member#: 98210
Just wet sand and polish lol
Old 10-11-2012, 05:39 PM   #734
ChesterWRX
Member#: 328794
2012 WRX Premium
Ice Silver Metal
take 2: removed old paint with Goof Off, sanded down with some 1000 and 1500 grit sand paper. then sprayed. 2 coats of red, 1 coat of clear.
Old 10-11-2012, 05:42 PM   #735
ChesterWRX
Member#: 328794
2012 WRX Premium
Ice Silver Metal
Old 10-11-2012, 07:42 PM   #736
hoffmanEstates
Member#: 122043
04 wagonier
psm
Originally Posted by ChesterWRX
see post 718. FAIL.
the bad:
Looks like something ya would see in Chicago
hoffmanEstates is offline   Reply With Quote
Old 10-18-2012, 10:19 AM   #737
themaus
Member#: 321211
On the VHT Nightshades Red can it says you can't remove it. Is this true? If I **** up I wanna be able to take it off....
themaus is offline   Reply With Quote
Old 10-18-2012, 11:14 AM   #738
ChesterWRX
Member#: 328794
2012 WRX Premium
Ice Silver Metal
goof off will take it off.
Old 10-18-2012, 11:44 AM   #739
themaus
Member#: 321211
I thought you used Stained glasspaint? You have used goooff to take the VHT Nightshade off though?
Old 10-18-2012, 12:29 PM   #740
ChesterWRX
Member#: 328794
2012 WRX Premium
Ice Silver Metal
i'm pretty sure goof off will take off just about any spray paint off.
they also have a grafitti remover which i do NOT recommend using because it says on the can "no plastic" or something to that effect.
i used regular spray paint (see post 718 and 732) and took it right off with a rag and goof off.
Old 10-18-2012, 01:23 PM   #741
Celery GT-5
Member#: 98210
lol don't do this mod expecting to go back to stock easily. even f you get the paint off cleanly you will never get it out of seams on the side of the lights
Old 10-18-2012, 02:31 PM   #742
ChesterWRX
Member#: 328794
2012 WRX Premium
Ice Silver Metal
good point.
the only way around that would be to tape off the inner lens and housing assemblies.
Old 10-18-2012, 02:35 PM   #743
Celery GT-5
Member#: 98210
lol it would be hard
Old 10-18-2012, 03:13 PM   #744
themaus
Member#: 321211
Good points. I am still going to attempt it this weekend. I can't get the vinyl looking good at all.
Old 10-18-2012, 04:41 PM   #745
zwalk
Member#: 281705
2005 STi
CGM
I used VHT nightshade and clearcoat once and it came off fine with gas...
Old 10-18-2012, 06:14 PM   #746
mrkyle3
Member#: 272675
2011 WRX
2004 Miata
I honestly prefer overlays to painting them. A bit more expensive but they don't fade and they look awesome.
mrkyle3 is offline   Reply With Quote
Old 10-18-2012, 06:15 PM   #747
Celery GT-5
Member#: 98210
overlays are less expensive when you consider the redos...lol
Old 10-18-2012, 06:58 PM   #748
ChesterWRX
Member#: 328794
2012 WRX Premium
Ice Silver Metal
if it wasn't for the bump on the outter tail i would have stuck with overlays.
i've seen pictures on here from so-called professional installs that had it bunched up around the edges and improperly cut.
the paint is pretty easy and two cans can easily do 5x jobs - assuming it fades in the first place.
i'm actually considering getting a 2nd set of tail lamps just for this reason. i know Depo (sp) makes the outter ones, no such luck finding a "steady" supply of the inner ones. but the prices of OEM aren't that bad either.
worst case: new tail lamp assemblies
but knowing i can strip and repaint *or* just strip it off, sand and polish to make them good as new... (except for the residue on the inside of the lens)
Old 10-18-2012, 07:07 PM   #749
Celery GT-5
Member#: 98210
I want some new tails..lol
Old 10-18-2012, 07:37 PM   #750
mrkyle3
Member#: 272675
2011 WRX
2004 Miata
Iag performance did mine and they are flawless as you can see.
New! Clear Tail Light Mod... WRX Rally Style Subie Gal Member's Car Gallery 33 03-15-2011 07:08 AM
2009 WRX fog light mod Andrey Electrical & Lighting 8 04-24-2010 05:43 AM
WTT: my06 sti taillight for you 05 sti/wrx tail light + $20, local swap only, (FL) yenny Private 'Wanted' Classifieds 2 08-02-2009 01:39 AM
WTT 2006 WRX tail lights for 2005 WRX tail lights SCRAPPYDO TXIC Private Classifieds 4 12-04-2006 01:01 AM
WTT 2006 WRX tail lights for 2005 WRX tail lights flymordecai TXIC Private Classifieds 1 11-23-2006 01:07 AM
