Old 08-31-2009, 05:13 PM   #76
tphskab
Member#: 114466
Bowl of
white rice
I want to do this so bad but have heard people say it fades to pink over time..
tphskab is offline   Reply With Quote
Old 08-31-2009, 05:13 PM   #77
09NewfieWRX
Member#: 59036
2013 Outback
Venician Red
Wink
Originally Posted by JGard View Post
Oh, another question. Those of you who did your third brake light...how? I can't get it out of the car, as the wires don't seem to have an accessible harness anywhere. I'm sure as hell not going to spray while they're on the car, either.
...you have to remove the rear spoiler.
It's held on with 2 nuts & 2 bolts. Disconnect the rear windshield washer hose and electrical for the LED then pop it off the rear hatch. Once you have this done, you can unbolt the LED to remove for painting.
09NewfieWRX is offline   Reply With Quote
Old 08-31-2009, 07:23 PM   #78
Member#: 221969
09 WRX
ahhh im dying to do mine but i get soo lazy with that
damanpaul23@aol.com is offline   Reply With Quote
Old 08-31-2009, 10:14 PM   #79
homer_atl
Member#: 210965
2009 WRX
hey all. you guys should check out iwsti for my original post on painting. tons of pics from others with different paints. i went testors and it's held up so far (since feb 09). but after seeing some of the guys w/ metalcast red i think i'm going to remove my paint and redo w/ metalcast.
http://www.iwsti.com/forums/gr-exter...her-one-2.html
homer_atl is offline   Reply With Quote
Old 08-31-2009, 10:16 PM   #80
homer_atl
Member#: 210965
2009 WRX
i know how you feel. dont worry tho. it can be fixed. i redid mine a couple of times. it just takes a little time to undo the old paint.
Originally Posted by Spindrift View Post
Tried it on my 06 and I think it looks like crap. Super flat, even with the clearcoat.
Fail?
Old 09-01-2009, 09:35 AM   #81
wrx jay
Member#: 201269
2009 Foz
This mod is soo worth it on the newer WRX/STI's. I've said this before but this is how they should have came from the factory.
wrx jay is offline   Reply With Quote
Old 09-01-2009, 12:14 PM   #82
EGREX
Member#: 219126
09 WRX Hatch
SSM
I went the lamin-x route, stuff was pretty difficult to apply around the wave on the outside light. They look great but up close you see a few imperfections, overall look is much cleaner. If the paint holds up I may go that route in the future, figured I start with something removable...
EGREX is offline   Reply With Quote
Old 09-01-2009, 12:23 PM   #83
tphskab
Member#: 114466
Bowl of
white rice
has anyone had their tails painted for a while? AT LEAST 6 or 8 months? Any noticeable fading yet?
Old 09-01-2009, 12:28 PM   #84
Dan07WRX
Member#: 154374
2011 WRX Sedan Prem
Satin White Pearl
I just cut the 2 wires in mine...... and just used but connectors to reconnect them...... easy enough.
Dan07WRX is offline   Reply With Quote
Old 09-01-2009, 12:50 PM   #85
dwf137
Member#: 161333
'09 wrx
'14 Outback
i painted and I'm NOT happy with the results.
It's just my painting skill, but there's air bubbles, and the thickness is variable, giving dark and light spots.
Switching over to laminx.
Old 09-01-2009, 04:44 PM   #86
EGREX
Member#: 219126
09 WRX Hatch
SSM
Its $50-55 for the WRX kit, comes with the blade and a fine mist bottle. Do the inners first to get a feel for the film...the outers will be tough to get pefect.
Old 09-01-2009, 07:20 PM   #87
homer_atl
Member#: 210965
2009 WRX
i've had mine for about 6 months. mine looks the same. i used the testors paint. my pics can be found at the link in my prior post... couple posts up frmo this one. the only thing with the pictures is it looks more opaque than it is in person. anyhow, i think some have said testors will fade, but metalcast is rated for higher temps, so it should be less likely to fade. anyhow your results on how it looks depends on how good you are with the spray can so results vary. good luck!
Old 09-01-2009, 08:17 PM   #88
tphskab
Member#: 114466
Bowl of
white rice
and I suppose worst case scenario, it fades and I paint it again.
Old 09-01-2009, 11:57 PM   #89
homer_atl
Member#: 210965
2009 WRX
you can strip and paint again. personally i'd go for something w/ the temp resistance and then make sure to put on several clearcoat layers.
Old 09-03-2009, 07:10 PM   #90
Ninjutsu PiloT
Member#: 204449
2011 STI
Default Not sure what happened
So I was working on this a few hours ago to fix these ugly lights and all was going well until I dropped something on one of the lights, smudging the paint and I have to strip it and repaint it (sucks for me) but I reconnected the battery after I reattached the lights and went to start my car and it didn't start.
I could get the starter to run but for whatever reason I didn't get it to turn over. I tried again and it worked and I drove around for a little bit in case the battery needed some charge but I don't know what caused this.
Ninjutsu PiloT is offline   Reply With Quote
Old 09-03-2009, 07:35 PM   #91
elwray
Member#: 194826
'09 WRX 5dr PP DGM
'07 VTX1300c, '03 VFR800
Don't worry about it, I don't think.
I don't know if it's the fuel pump losing prime or what, but whenever you disconnect the battery it takes a few cranks before it fires.
The first time I ever disconnected the battery the same thing happened. FREAKED me out because I had just put in my Kenwood stereo and thought I botched something BIG TIME.
Also, every time I flash a new map to the ECU, the same thing happens.
I don't know exactly what it is that's happening, but just keep that key turned until it starts
elwray is offline   Reply With Quote
Old 09-04-2009, 10:00 AM   #92
redobs
Member#: 1501
2009 WRX wagon
Dark grey
How many coats of paint are you putting on?
redobs is offline   Reply With Quote
Old 09-04-2009, 07:22 PM   #93
boostin08wrx
Member#: 166307
2008 Impreza WRX
From what i was told disconnecting the battery for a little bit resets the ecu and takes awhile to reset itself... but im not saying thats your problem, just something i've heard.
boostin08wrx is offline   Reply With Quote
Old 09-04-2009, 07:26 PM   #94
elwray
Member#: 194826
'09 WRX 5dr PP DGM
Well, it definitely does reset the ECU. Don't know why it keeps it from starting, but for whatever reason I stopped worrying about it... maybe I shouldnt?
Old 09-04-2009, 11:18 PM   #95
Ninjutsu PiloT
Member#: 204449
2011 STI
Default Red on red
Unfortunately I have a bad schedule right now and I have had to work on this project in pieces but here is what it looks like on red, or excuse me, LIGHTNING red!
I painted the back of the light black instead of the light gray, I think it goes better with the flow of the car. This is 1 coat of paint, I don't think I need any more
Old 09-06-2009, 05:23 PM   #96
nitroinsane
Member#: 216027
I did the same and my third brake light
nitroinsane is offline   Reply With Quote
Old 09-06-2009, 06:24 PM   #97
dwf137
Member#: 161333
'09 wrx
'14 Outback
yea, i can imagine with all of the contours.
I have a heat gun though, so i should be able to manage, I wrapped my mini cooper tail lights with tinted laminx just a few weeks ago, about a week before trading it in for the rex.
I'm happy with the look from a distance, but up close is where I'm unhappy..
Old 09-06-2009, 09:11 PM   #98
NorthBayResident
Member#: 204200
2008 Impreza 2.5i
Originally Posted by nhmtns View Post
The lights look awesome!
and not to throw this thread off topic, but what base racks are those and how much were they? I am in the market for a set, and right now the OEM crossbars just are not doin' it for me
Thanks
-NBR
NorthBayResident is offline   Reply With Quote
Old 09-07-2009, 04:05 PM   #99
tphskab
Member#: 114466
Bowl of
white rice
I am working on this right now. I am on the liner part of the hatch and the last two corners will not break loose! Getting a little frustrated! And sweaty
Old 09-07-2009, 08:37 PM   #100
tphskab
Member#: 114466
Bowl of
white rice
turned out great!
New! Clear Tail Light Mod... WRX Rally Style Subie Gal Member's Car Gallery 33 03-15-2011 07:08 AM
2009 WRX fog light mod Andrey Electrical & Lighting 8 04-24-2010 05:43 AM
WTT: my06 sti taillight for you 05 sti/wrx tail light + $20, local swap only, (FL) yenny Private 'Wanted' Classifieds 2 08-02-2009 01:39 AM
WTT 2006 WRX tail lights for 2005 WRX tail lights SCRAPPYDO TXIC Private Classifieds 4 12-04-2006 01:01 AM
WTT 2006 WRX tail lights for 2005 WRX tail lights flymordecai TXIC Private Classifieds 1 11-23-2006 01:07 AM
