Old 10-21-2009, 03:53 PM   #126
thejordan
Member#: 185374
i typed out everything i did:
Well this shouldn't cost you much more than $20.
Go to your local hobby store.
You'll want to get 2-3 cans of this stuff:
http://www.hobbypeople.net/gallery/336487.asp
Also get 1-2 cans of clear coat.
It's a translucent stained glass sort of paint.
You'll be ok with 2 cans of red and 1 clear, but depends on how well you paint.
You'll also want tape to mask off the centers (notice in the picture on each piece i painted the edge lines instead of continuing the mask to the second piece if this makes sense). If you're real picky, mask of the edges so that only the lens plastic is showing. When you open your hatch you might see some overspray.
Remove all 4 tail light pieces and clean with alcohol/acetone. Removing is easy, just pop everything out, remove a few screws.
Once clean and ready, shake your red can and apply to each individually, the first coat is usually the lightest. Do 3 coats total, the last 2 coats should be slightly heavier. After 3 coats per piece, it should look perfectly red, if not apply a 4th coat.
When spraying, swing your whole arm and body across the entire surface without stopping, make sure to get the curvature of the surface and remain perpendicular, make sure to get the edges since those are easiest missed.
Now use the clear and apply 2 coats. It should look like OEM plastic now.
Wait to dry and remove tape, these dry fairly quickly. Install the pieces. When reinstalling there are sort of sliding rails that pop in on the corners so make sure those go in right.
The next time you wax your car, apply a coat of wax to help for protection.
If you mess up or don't like it, use acetone to completely remove.
friends car: (sorry for crappy phone pic, but if it looks light it is just the reflection)
thejordan is offline   Reply With Quote
Old 10-24-2009, 01:02 AM   #127
Bryanwrx
Member#: 157349
2010 WRX
hey guys, get my 2010 wrx on tuesday ao been searching and re-searching everything. I was wondering if anyone has done the full light....and if they can still see while reversing. If so chirp in I cančt be the only one wondering this! otherwise, most look awesome!
Bryanwrx is offline   Reply With Quote
Old 10-24-2009, 02:35 PM   #128
hjmik
Member#: 222835
2007 Forester
^what do you mean by "full light"?
hjmik is offline   Reply With Quote
Old 10-24-2009, 08:04 PM   #129
paul_shark
Member#: 227396
2009 wrx
spark silver
I think he's talking about painting over the reverse light rather than just around the border which has no light output.
If you paint over the reverse light, it will probably dim the light output a bit. When the reverse lights come on, it will probably look pink. You might be able to mitigate both problems by alternating clear/red strips when you paint, but I'm not certain if that will work. The inner (reverse lamp) portion of this Saab tail illustrates what I'm talking about:
paul_shark is offline   Reply With Quote
Old 10-24-2009, 08:31 PM   #130
Bryanwrx
Member#: 157349
2010 WRX
Ya the full light. I presume it would still light up fairly well. I'll see how ballsy I'll b when the time comes.
Old 10-25-2009, 01:25 PM   #131
PERRIN
NASIOC Manufacturer
Member#: 6776
Duplicolor MetalCast Red FTMFW! They also have a smoke color too, if you want to get tricky and tint the center portions smoky. I tried both and ended up going all red. But that is the perfect paint!
PERRIN Performance
PERRIN is offline   Reply With Quote
Old 10-25-2009, 09:49 PM   #132
Bryanwrx
Member#: 157349
2010 WRX
PERRIN Performance
how was the reversing with it all red? i guess it's similar to just hitting the brakes while reversing?
Old 10-25-2009, 10:04 PM   #133
tehknikhal
Member#: 227548
2009 09 WRX Sedan
Obsidian Black Pearl
Dope... anybody got tail light tints for the 09 wrx sedan?
tehknikhal is offline   Reply With Quote
Old 10-25-2009, 10:35 PM   #134
hjmik
Member#: 222835
2007 Forester
My friend has reverse light painted but you can see light fine... you are just painting glass paint over w/ clear coat. It IS little bit dimmer compare to no paint, but it's not bad at all
Old 10-25-2009, 11:43 PM   #135
Subie_Junkie
Member#: 224629
09 Wrx 5 door
not bad
Subie_Junkie is offline   Reply With Quote
Old 10-26-2009, 09:34 AM   #136
Super_HKS
Member#: 154434
2009 WRX Hatch <@_@>
Originally Posted by Subie_Junkie View Post
not bad
Thanks man, you gonna give it a shot
Super_HKS is offline   Reply With Quote
Old 10-26-2009, 11:58 AM   #137
GFN-WRX
Member#: 227824
pretty damn cool man i might try this!
GFN-WRX is offline   Reply With Quote
Old 10-26-2009, 09:12 PM   #138
redobs
Member#: 1501
2009 WRX wagon
Dark grey
Has anyone used acetone to remove the paint on their taillights? Wondering if it is safe to use.
redobs is offline   Reply With Quote
Old 10-28-2009, 09:04 AM   #139
Super_HKS
Member#: 154434
Do it, it will not be a waste of 10 dollars I can assure you of this
Alot of people said paint thinner but gosh i just dont know. Do it right the first time so you dont have to worry about that
Old 10-28-2009, 09:16 PM   #140
davecamp21
Member#: 221080
04 Impreza WRX STI
blue
davecamp21 is offline   Reply With Quote
Old 11-02-2009, 11:20 PM   #141
mykee069
Member#: 195546
2009 WRX 5 door
spark silver
went to wal-mart looking for paint remover safe for plastics.
found "Krud Kutter" Graffiti Remover.
Initially didn't work so well, but if you apply a liberal amount, let site for a few minutes and wipe off...works like a charm!
I just tested it on a 5 gallon water jug that i had sprayed with the same paint when I did my tails.
Will try it on a small corner of the tails tomorrow and report with the results.
Hopefully we can all avoid this fate from here on out.....
Originally Posted by PERRIN_Jarid View Post
Taillight lens....62 dollars
Paint...8 Dollars
paint remover....11 dollars
Watching the plastic melt off the lens you are trying to take the failed paint off of.....priceless.
mykee069 is offline   Reply With Quote
Old 11-13-2009, 06:25 PM   #142
RedefinedTR
Member#: 149848
2011 Honda CRZ
Performance White Pearl
^ Let us know if your remover works out, if so I may have the courage to try this out.
RedefinedTR is offline   Reply With Quote
Old 11-15-2009, 03:49 PM   #143
airnickman
Member#: 230074
2008 WRX STi
grey
I did mine with three coats of Tamiya "smoke" then a clear coat. Looks way better. My problem was getting the plastic liner back in place. Is there a trick to getting it back in?
airnickman is offline   Reply With Quote
Old 11-16-2009, 10:22 AM   #144
PERRIN
NASIOC Manufacturer
Member#: 6776
Which liner? They all should just snap right back in. What exactly is the problem to see if I can help!
Adam
PERRIN Performance
Old 11-16-2009, 10:24 AM   #145
Super_HKS
Member#: 154434
You refering to the liner that you take out to get access to the screws on the hatch tails? As adam mentioned, everything should snap back in place. This plastic is very STURDY! Dont be affraid to use a little force with it.
Old 11-16-2009, 11:32 AM   #146
LaCroix2.5i
Member#: 223055
2008 Impreza 2.5i 5d
Think I'm going to give this a go. Definitley should have come from the factory like this. The stock tails are just so darn flashy.
LaCroix2.5i is offline   Reply With Quote
Old 11-16-2009, 01:20 PM   #147
blueteamno
Member#: 32089
2011 WRX
2012 Outback
so how did it go?
my tails faded and i want to redo them but am trying to find a safe way to remove the paint first.
blueteamno is offline   Reply With Quote
Old 11-18-2009, 01:28 PM   #148
blueteamno
Member#: 32089
2011 WRX
2012 Outback
bump for good solutions to remove paint from tails plz
Old 11-25-2009, 08:16 PM   #149
moorex
Member#: 160345
2010 WRX
Almost done, just waiting for it to be dry long enough to put back on the car.
moorex is offline   Reply With Quote
Old 11-25-2009, 08:16 PM   #150
moorex
Member#: 160345
2010 WRX
New! Clear Tail Light Mod... WRX Rally Style Subie Gal Member's Car Gallery 33 03-15-2011 08:08 AM
2009 WRX fog light mod Andrey Electrical & Lighting 8 04-24-2010 06:43 AM
WTT: my06 sti taillight for you 05 sti/wrx tail light + $20, local swap only, (FL) yenny Private 'Wanted' Classifieds 2 08-02-2009 02:39 AM
WTT 2006 WRX tail lights for 2005 WRX tail lights SCRAPPYDO TXIC Private Classifieds 4 12-04-2006 02:01 AM
WTT 2006 WRX tail lights for 2005 WRX tail lights flymordecai TXIC Private Classifieds 1 11-23-2006 02:07 AM
