Welcome to the North American Subaru Impreza Owners Club Wednesday June 1, 2016
Old 11-25-2009, 07:38 PM   #151
thatkhmer
Member#: 217500
2009 SWP Wrx
2010 WW Evo X
goo gone works to take the paint off
you just gotta spray alot and let it sit
be careful though because its gunna look ugly nasty and crusty when it comes off you just gotta wipe it off nicely
thatkhmer is offline   Reply With Quote
Old 11-25-2009, 08:33 PM   #152
moorex
Member#: 160345
2010 WRX
I agree with the instructions on this mod with one exception...
Don't just pry off the liner on the hatch. Pop off the plastic piece at the top (above the window inside) between the two pillars first, then pop of the two pillars, and THEN remove the big black liner.
Do this in reverse when you put them back on (liner, pillars, piece between pillars), and you'll save yourself from breaking clips like myself and others have.
moorex is offline   Reply With Quote
Old 11-25-2009, 08:42 PM   #153
Super_HKS
Member#: 154434
2009 WRX Hatch <@_@>
Good tip man thanks for the input.
Im glad I didnt break any
Super_HKS is offline   Reply With Quote
Old 11-25-2009, 11:47 PM   #154
moorex
Member#: 160345
2010 WRX
Yeah, I broke two when i went to put the liner back on. I was trying to force the pillars to fit properly with the top part under the liner, and snap!
Oh well, it's not even noticeable. Only way it would bother me is if it started to rattle or something.
Great write up tho, I never would have attempted it without such detailed instructions. Tails came out perfect!
Old 11-27-2009, 05:37 PM   #155
acheneightyfive
Member#: 227632
I am thinking about doing this pretty soon. Anyone know if this voids your factory warranty? That would be my biggest concern since you are removing the tail lights in order to paint them...
acheneightyfive is offline   Reply With Quote
Old 11-28-2009, 11:51 PM   #156
hjmik
Member#: 222835
2007 Forester
^ taillight has nothing to do w/ how your car function which means they won't voide your warranty.
Anyway, what is the best way to remove clearcoat and paint on taillight? Mine faded to pink now and I need to redo mine. But my friends told me goo gone actually crack or melt tail light.
hjmik is offline   Reply With Quote
Old 11-28-2009, 11:53 PM   #157
acheneightyfive
Member#: 227632
Heh thanks for the reply. Asked around a bit too and everyone suggested that it would be fine so I painted them today! Pics up tomorrow when it's sunny
I heard wet sanding would be the best bet to remove the paint since other things may be too strong and hurt the plastic. Wet sand + polish maybe?
Old 11-29-2009, 04:12 AM   #158
dwf137
Member#: 161333
'09 wrx
'14 Outback
i used acetone on my paint to remove it.
watch though, because acetone WILL eat at the plastic. It's not bad enough to eat through it, but it will dull the surface. I essentially used it until the paint was super thin, but still there... after that, i used a lot of elbow grease.
Old 12-02-2009, 03:22 AM   #159
w74bronco
Member#: 139178
2010 WRX HB
Just finished up mine with Metalcast and Duplicolor Auto Clear Coat. I think it's so-so. I didn't like the spray pattern of the clear coat. I ended up with a few runs in the clear. Hard to spot if you're not looking for it, but noticeable for me. If I redo it, I'll use the Rustoleum Crystal Clear Enamel. I used it for 4 coats on my winter wheels and I got no runs on any of the rims.
I masked the lights while still installed on the car. It's helpful to turn on the reverse lights and turn signals to help with cutting the tape to size.
I applied 1 light coat, 2 medium coats and 1 heavy coat of Metalcast (in that order). Waited about 20 minutes in between coats of the paint. I went to Costco for groceries, then came back and topped it all with 3 coats of the clear coat (20 minutes apart).
The materials:
After one coat
After all the paint and clear has been applied.
Unmasked.
See the run?
Installed. Yeah, I know...needs debadging.
Next time, I'm using this for the clear.
w74bronco is offline   Reply With Quote
Old 12-02-2009, 03:45 AM   #160
Brother EddieJ.
Member#: 181617
2004 wrx
6speed/ 330whp/ 300wtq
Looks good. If I had an 09 this would be the first thing I would do.
Brother EddieJ. is offline   Reply With Quote
Old 12-02-2009, 04:21 AM   #161
elscoobie20
Member#: 214606
2009 WRX
DGM AP Stage 2 + AEM CAI
Definitely gonna tackle this during the winter when classes are over.
Hopefully with the help of somebody who knows a thing or two about painting and cars lol.
elscoobie20 is offline   Reply With Quote
Old 12-03-2009, 01:42 AM   #162
Landin2010
Member#: 231674
2010 Impreza WRX
Obsidian Black Pearl
as of about 7 hours ago i am now the proud owner of an obsidian black pearl 2010 wrx 5 door, much like most of you my only complaint about the car is the tail lights,
what i was wondering is if anyone has "jimmy" modded the tail lights, by this i mean actually seperated the light assembly from the housing and painted the inside of the light, i have done this on several other vehicles i have owned as well as on plenty of friends cars for headlights.
my only concern is that if i were to do it, 1 the leds would not be as bright because they are no longer surrounded by chrome, and 2 i might mess something up with the warranty because i disassembled the headlight.
this is the first new car i have owned so i have never had to deal with a warranty before and it was one of the main reasons i did not buy an older wrx.
thanks in advance for the input
Landin2010 is offline   Reply With Quote
Old 12-03-2009, 03:47 AM   #163
barkley2-6
Member#: 221961
so much better than stock
barkley2-6 is offline   Reply With Quote
Old 12-03-2009, 10:31 AM   #164
Landin2010
Member#: 231674
2010 Impreza WRX
i think i am going to go ahead and do this the way i have in the past and actually seperate the housing from the tail light, im jsut debating if i want the inside of the housing to be black or if i want it to be red, i just dont feel like dealing with any tickets for it no longer being reflective or what have you because thats what the problem with the black tail lights and that nightshades stuff is.
police will pull you over because your tail lights are non refelctive at night.im gonna do some research and see if the reflectors in th rear bumper are enough or if you have to have reflective tail lights as well
Old 12-03-2009, 07:31 PM   #165
kgj996
Member#: 157545
2004 wrx
red
You really need to use a good automotive clear coat if you expect the red to last more than a few months without fading due to the sun. ppg and dupont among other two part clears contain UV blocking compounds in them to keep the paint underneath from fading and they are impervious to other nasty chemicals that will eat right through that rattle can clear.
I do this for a living and have painted over 20 sets with candy red and a nice clear coat.
kgj996 is offline   Reply With Quote
Old 12-03-2009, 09:22 PM   #166
tphskab
Member#: 114466
Bowl of
white rice
I painted mine with krylon stained glass and a uv resistant clear back in like august. It is already fading a bit. I am thinking about getting them professionally painted.
tphskab is offline   Reply With Quote
Old 12-03-2009, 11:00 PM   #167
mykee069
Member#: 195546
2009 WRX 5 door
spark silver
at first it seemd to work really well, then the surface of the plastic got kinda hazy. i think if i wetsand it now i will look good and undo the haziness. i will give it a shot if i get time, but work schedule is kinda crazy right now. sorry for the delay.
Originally Posted by blueteamno View Post
so how did it go?
my tails faded and i want to redo them but am trying to find a safe way to remove the paint first.
mykee069 is offline   Reply With Quote
Old 12-04-2009, 02:24 AM   #168
elscoobie20
Member#: 214606
2009 WRX
How much do you charge, curious what the going rate for a professional job is.
Old 12-04-2009, 06:13 AM   #169
kgj996
Member#: 157545
2004 wrx
red
I charge $100 plus your old lights as a core. I also ship any where in the US. I haven't seen anyone else at least in the north east that does this. I have shipped lights all the way out to the west coast last month
This is me HERE.
Old 12-04-2009, 08:14 PM   #170
butta1210
Member#: 131218
2010 WRX HATCH
Micah Blue
This is me HERE.
wow I'm interested.
butta1210 is offline   Reply With Quote
Old 12-04-2009, 09:25 PM   #171
BLkdubRX
Member#: 229971
2009 WRX
w/ SF hotbox
This Looks Great, I Have The WRX Sedan but great idea!!
BLkdubRX is offline   Reply With Quote
Old 12-04-2009, 10:42 PM   #172
Whitford
Has never had a cavity
Member#: 97875
Originally Posted by nhmtns View Post
^^^ Add some tint and she'll look even better! Painted tails, mudflaps, and tint make the rear of the '09 WRX look a hundred times better.
I read that wetsanding and then polishing will make them look clear. I might do that at some point with mine.
I think that's one of the best looking new WRX' I've seen.
Originally Posted by STi__G View Post
Whoa I thought that was my car for a second.
I took my time with this project as my car is not my daily driver. I'll offer a few tips based on my experience.
I tried Blue Bat's overlays first but failed getting the outer lens overlay on. For the price and the look, I think this is the way to go if you get them professional installed. Having said that, if you take your time painting it will come out seamless.
I used Duplicolors Metalcast Red spray paint and then applied Duplicolors automotive clear over that.
I must of sprayed 10 light to medium coats of each leaving 20 minutes between coats. After drying for 48 hours I wet sanded with 2000 grit sandpaper. I then used a coarse rubbing compound followed by some car polish which I buffed in. They look great and when I tell people I painted them, they think I'm lying.
Great work!
Great mod guys, looks really good.
Whitford is offline   Reply With Quote
Old 12-04-2009, 10:55 PM   #173
hjmik
Member#: 222835
2007 Forester
I think going w/ overlay is much better option. It's easier to undo and won't have to worry about fading. Mine faded after ~2 months and now I don't know what to do w/ them... I am too scared to use goo gone or other paint remover on my tail light...
Old 12-05-2009, 06:03 AM   #174
kgj996
Member#: 157545
2004 wrx
red
Polyurethane thinner works great to take the paint off in about 2 wipes. I have had to use it a few times painting tails and it leaves the plastic like new.
Old 12-05-2009, 06:30 AM   #175
Kurikaze
Member#: 174252
2014 BRZ
Duplicolor Metalcast (Couldnt find Krylon for the life of me)
4 Coats of Color, 2 layers of clear coat
Kurikaze is offline   Reply With Quote
New! Clear Tail Light Mod... WRX Rally Style Subie Gal Member's Car Gallery 33 03-15-2011 07:08 AM
2009 WRX fog light mod Andrey Electrical & Lighting 8 04-24-2010 05:43 AM
WTT: my06 sti taillight for you 05 sti/wrx tail light + $20, local swap only, (FL) yenny Private 'Wanted' Classifieds 2 08-02-2009 01:39 AM
WTT 2006 WRX tail lights for 2005 WRX tail lights SCRAPPYDO TXIC Private Classifieds 4 12-04-2006 01:01 AM
WTT 2006 WRX tail lights for 2005 WRX tail lights flymordecai TXIC Private Classifieds 1 11-23-2006 01:07 AM
