Welcome to the North American Subaru Impreza Owners Club Sunday February 14, 2016
Old 05-02-2002, 09:09 PM   #1
maciek
Member#: 11216
1991 SS 1998 BG
1996 BD
Default can't get the crank pulley off!
It's in 5th gear and my friend is pressing the break...And the crank is still spinning...what the hell?
Is it safe to dw40 the bolt?
maciek is offline   Reply With Quote
Old 05-02-2002, 09:40 PM   #2
SoCalScooby
Member#: 854
2000 2.5 RS
Blue Ridge Pearl
I bought myself a UD pulley back in the day...yeah, I had the same problem you are having. I asked lots and lots and the suggestion that worked for me was this:
put the breaker bar on the bolt, downwards against the ground. Just to be on the safe side I pulled out one of the spark plug cables. sit in the car, and click it once and the thing will come right off. I've been driving with my new pulley for a long time now and no problems. No one else who has done this has had any problems either.
btw, WD40 is fine to put on, I did. Put anti-sieze on the bolt just incase you want to take it off later.
Good luck!
~Eric
SoCalScooby is offline   Reply With Quote
Old 05-02-2002, 09:54 PM   #3
maciek
Member#: 11216
1991 SS 1998 BG
1996 BD
Got it!
I put a screwdriver through the ps pump pulley and locked it...extra friction from the belts did the trick.
How do I get the crank pulley off w/ motor out of car?(I've searched) pheonix991 Service & Maintenance 8 06-10-2009 11:28 AM
Spring install: I can't get the rear 19mm strut bolts off! rex n effect Brakes, Steering & Suspension 33 03-09-2003 11:33 AM
can't get the starter cable off wrxspdr Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 01-08-2003 10:31 PM
help: can't get the two nuts off the rear struts makanouchi Brakes, Steering & Suspension 7 11-28-2002 12:02 AM
Got new front rotors! Hmn. Can't get the old ones off. Siper2 New England Impreza Club Forum -- NESIC 23 10-10-2002 08:42 PM
