Old 08-07-2009, 04:06 AM   #1
stijet
Member#: 209216
Default tallest tire for an 06 STi
Been searching and finding lot's of info on tire width maximums.
I'm looking to see what is the tallest tire I can fit on my 06 STi. Stock rims and stock suspension. I drive dirt, daily in rocky conditions and want more rubber between the wheel and the road. Likely to buy a snow type tire.
thanks
stijet is offline   Reply With Quote
Old 08-07-2009, 07:33 AM   #2
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
if you want offroad ability........you gonna want different wheels
Old 08-07-2009, 11:54 AM   #3
nhat
Member#: 140163
03 STi
hellaflunctional
if you don't wanna buy new wheels, 245/45/17 is the tallest i would go on the stock 17x8s.
Old 08-07-2009, 02:48 PM   #4
stijet
Member#: 209216
uncle scotty- I do want different wheels but cant get them now.
nhat- why not?
It's not just offroad ability it's also a case of protecting the flimsy stock rims from the rocks in our roads. I live on a dirt road with lots of rocks. Not gravel but lumpy rocks all over. I daily drive my sti on dirt road and over a twisty paved mountain pass daily.
Prefer not to downsize rim do to the loss in brake size. Smaller rims work well on the dirt but the smaller brakes were not as gratifying once we hit the paved.
thanks for all responses
Old 08-07-2009, 02:56 PM   #5
nhat
Member#: 140163
03 STi
hellaflunctional
what're you talking about? the 05-07 sti came with 17x8s stock. if you want a taller tire to absorb more of the rocks/bumps/shock/etc, go with a 245/45/17. any taller and you'll rub everywhere, unless you wanna spend money to raise your car some more.
Old 08-07-2009, 03:39 PM   #6
stijet
Member#: 209216
what am I talking about? please keep in mind that my response is to you, uncle scotty and anyone else reading this. Not just to you. "why not?" was the only part directed just towards you.
As you know there are many similar sizes for instance 225/50/17 It's approximately .1" narrower and .2" taller than the 245/45 you suggest. Pretty close. Just showing there may be other options.
And looking for any others
Old 08-07-2009, 04:12 PM   #7
nhat
Member#: 140163
03 STi
hellaflunctional
i was confusing by the why not.
225/50/17 is marginally taller but you could possibly run into rubbing at full lock, on the lower strut perch, or on the fender liner due to the height...or all 3 due to the high offset of the stock bbs wheels.
Old 08-07-2009, 06:51 PM   #8
Drakar
Member#: 68402
2016 WRX
if your on dirt alot, I would swap out to some wrx springs, raise your ride height alittle then combine that with a taller tire and you could gain another .5" or more in height, and add a good skid plate/diff protector.
Drakar is offline   Reply With Quote
Old 08-07-2009, 10:38 PM   #9
Gclark
Member#: 192352
1994 Legacy STI
ლ( ಠ ಠ)
Well Im running 215/65/16 general grabber a/t and they barely barely fit and thats on obs struts and springs with a 1in lift.
Gclark is offline   Reply With Quote
Old 08-08-2009, 01:37 AM   #10
turboICE
Member#: 33979
2006 STi,'11 OBS
WRB & Black/Silver
The stock wheels are anything but flimsy.
This is the size I would take in the situation you are describing.
Tire height will protect the wheel from fixed vertical hits like in a pot hole or head on curb.
Don't dismiss width as it will add protection to the wheel edges from large but loose obstacles such as rocks. Width has protected my wheels more often than height.
I have driven this size on rocky roads with extreme summer tires, it will protect your wheels both with tire height and tire width, deflecting larger rocks from the wheel sides with its width as well as offering more height.
Get this size in a mud and snow and it will meet your needs better than any other size.
turboICE is offline   Reply With Quote
Old 08-11-2009, 03:06 PM   #11
Uncle Scotty
Member#: 16200
OK buy Nates beans
this is an all too often posted fantasy
tire PRESSURE is FAR-FAR more important on the street
lots and LOTS of total idiots run 30psi and bend wheels.....when 35psi(or 40psi) woulda made it a non-issue
off road is a totally different ballgame and you can not mix one with the other
which is why this whole idea is just chock full 'o fail
Old 08-11-2009, 03:47 PM   #12
turboICE
Member#: 33979
2006 STi,'11 OBS
WRB & Black/Silver
Yes, proper pressue is critical to wheel protection, but it does not negate the role tire height plays. I have had hits on roads that tore the interior of the sidewall leaving a bulge on the side of the tire and not damaged the wheels because of tire height and proper pressure.
The discussion was about tire sizes - pointing out the importance of tire pressure was helpful; the rest was the vanity of a narcissist. But saying it is fantasy and fail makes your argument unassailable and you clearly the much more informed person.
Old 08-11-2009, 04:23 PM   #13
Uncle Scotty
Member#: 16200
OK buy Nates beans
jesus ****ing christ
I have run 235/40 tires on 17x7.5 SSR comps---ya know the 12 pound ones!?!?!?!?!?! for 100+k miles on all sorts of roads and they are still ****ing straight
because I always run at least 35psi
now
I dont give a rats ass what anybody thinks.......but I see a LOT of bent wheel posts and mine are STRAIGHT
YOU tell ME what the ****ing issue REALLY is
Old 08-11-2009, 05:09 PM   #14
turboICE
Member#: 33979
2006 STi,'11 OBS
WRB & Black/Silver
now
Well apparently what the issue really is, isn't the topic of these forums.
I agreed that tire pressure is critical and you have a hissy fit.
But then again you are agreeing with me - because like it or not you are using tire height to protect your wheels 235/40 are anything but low profile. So tire height and tire pressure are protecting your wheels.
*Recommendations for all-weather tires for an '05 STi?* LaxSTi Tire & Wheel 0 12-14-2008 04:45 PM
WTB: Set of wheels and tires for my 06 sti for offroad use. beat-up? Don't care,PM ME Enchantor Private 'Wanted' Classifieds 0 05-07-2007 01:25 PM
Is the BPV for an 06 STi the same as an 02 wrx? breathinez Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 12-22-2006 08:17 PM
Looking for dash trim kits for an 06 STI Woot Interior & Exterior Modification 5 12-17-2006 08:10 PM
Help choosing tires for an 05 STi Optimus Prime Tire & Wheel 23 06-29-2005 11:25 PM
