Old 08-07-2009, 10:47 AM   #1
Rexican
Member#: 156229
Default Andrewtech Cocktail
Hello Everyone,
After reading reviews for a couple of weeks I have decided to go with the Andrewtech cocktail of 3qts Redline Lightweight Shockproof and 1 qt Motul 300. I'm currently at 70K and the tranny fluid has never been changed. Its getting rather difficult to put into reverse and almost impossible to get into first while during a slow roll.
So my questions is : What is the last oil to go in. Should I put the Motul in first or last? The transmission only takes 3.8 qts so one of the fluids has to have a little leftover.
Thanks for the help guys.
Chris
Rexican is online now   Reply With Quote
Old 08-07-2009, 10:57 AM   #2
AndrewtechAutomotive
Member#: 99694
2002 dogbox,'11 wrx
Doesn't really matter.
We typically do shockproof first, then top it off with Motul.
Phil
Andrewtech Automotive
AndrewtechAutomotive is online now   Reply With Quote
Old 08-07-2009, 10:31 PM   #3
DZnutz
Member#: 91837
what fluid do you recommend for an RS 5 speed making 400awtq?
DZnutz is offline   Reply With Quote
Old 08-07-2009, 10:33 PM   #4
darksc00by
Member#: 102140
2016 Herp Derping
Engineer For Hire, yo.
excellent left leg control.
I did the same thing, it held, with 180k on the box.
Just be nice to it. I am running OEM fluid, it is fine
darksc00by is offline   Reply With Quote
Old 08-08-2009, 12:38 PM   #5
Rudywrx04
Member#: 134273
04 VF 48 P&P
289 WHP 275 WTQ
I put in the Andrew Tech cocktail today and . Smooth as butter. I personally think it has to do with the shockproof being a thicker weight fluid.
Rudywrx04 is offline   Reply With Quote
Old 07-17-2010, 12:10 AM   #6
Aleksey
Member#: 23445
2007 STI
reviving the thread - is it recommended for both 5MT and 6MT?
Aleksey is offline   Reply With Quote
Old 07-17-2010, 10:40 AM   #7
shaggy-with scoobi
Member#: 207631
2002 XPT Stage 2 WRX
Fat Chicks love that ride
Ive tried both Uncle scotty's and Andrewtechs and by far i like no i love Andrewtechs cocktail far more
shaggy-with scoobi is offline   Reply With Quote
Old 07-17-2010, 02:10 PM   #8
100_Percent_Juice
Member#: 126042
2004 W Ŕ X
Straight lightweight shockproof has always been pretty great on its own.
100_Percent_Juice is offline   Reply With Quote
Old 07-17-2010, 04:21 PM   #9
feint05
Member#: 152984
2004 jewbaru
jewbuilt, polish tuned
cause .8qts motul makes all the difference right
feint05 is offline   Reply With Quote
Old 07-17-2010, 05:04 PM   #10
WRKX
Member#: 28402
2005 STI
CGM
6-speed cocktail thread
http://forums.nasioc.com/forums/show....php?t=1974185
I'd like to know how it works with Extra-S.
WRKX is offline   Reply With Quote
Old 07-18-2010, 01:50 AM   #11
Aleksey
Member#: 23445
2007 STI
Originally Posted by WRKX View Post
Thanks!
Old 08-24-2010, 08:43 PM   #12
raggedoutsti
Member#: 255714
2005 STi
psm
where can you get this cocktail?!
raggedoutsti is offline   Reply With Quote
Old 08-26-2010, 08:45 PM   #13
Team Scream
Member#: 121532
2006 FXT/STi 6MT
01 Aerosim GC8 Coupe
Um... at the local Subaru bar?
You buy 3 quarts of Redline shockproof gear oil, and 1 quart of Motul Gear 300,
Put the Redline in first and then fill the rest of the tranny with the Motul.
Your tranny will do the mixing for you, and if you are nice, might even spit out the olive you so desire????
Google is your friend when it comes to which vendors have the oil....sorry, too lazy to look it up for you bro.
fixed...
Team Scream is offline   Reply With Quote
Old 08-26-2010, 09:03 PM   #14
turbo sol
Member#: 245106
2004 WRX Wagon
San Remo
i believe its the other way around; 3qts Redline Lightweight Shockproof and 1 qt Motul 300 right?
[quote=Team Scream;31715562]Um... at the local Subaru bar?
You buy 3 quarts of Motul Gear 300, and 1 quart of Redline shockproof gear oil.
Put the Redline in first (the whole quart) and then fill the rest of the tranny with the Motul.
turbo sol is offline   Reply With Quote
Old 08-26-2010, 10:24 PM   #15
raggedoutsti
Member#: 255714
2005 STi
psm
is there an exact science to these who do i listen too!!!!
Old 08-26-2010, 10:30 PM   #16
Subie_Sleeper68
Member#: 166403
2006 Baja Turbo
Silver 340 AWHP 365 AWTQ
Wrench in the works time.
I have a PPG box in the Baja.
1-4 helicals
340/365 to the wheels.
I had the cocktail in my case & had a 3rd gear synchro grind, OFTEN.
Ryan, from Area1320 in Easton Pa. convinced me to flush it & run straight Amsoil gear oil.
It hasn't crunched since & it really does shift ultra smooth now.
Good luck.
Sent from my iPhone using Tapatalk
Subie_Sleeper68 is offline   Reply With Quote
Old 11-04-2010, 09:39 AM   #17
echo_kyle
Member#: 246397
just put this in my car! unreal difference! no more 4th gear grind! i can put it into first without being at a dead stop! and every gear is smooth as ky jelly :P
echo_kyle is offline   Reply With Quote
Old 11-04-2010, 11:08 AM   #18
Steve Nastoff
Member#: 52052
03 Subaru WRX
Midnight Black Pearl
My favorite to date.
Steve Nastoff is offline   Reply With Quote
Old 11-07-2010, 11:49 AM   #19
SubySal
Member#: 43011
2004 Impreza RS
PacificaBlue/BlackTarmacs
After trying several gear oils I decided to try this mix in an attempt to at least reduce my 4th gear grind and hopefully put off a synchro replacment for a few months. I wasn't sure what to expect, but to my surprise this stuff works great. It's like Liquid Schwartz! No more grind and the tranny shifts very smoothly. If this lasts I'm just going to leave the tranny alone. Thanks Andrewtech.
SubySal is offline   Reply With Quote
Old 11-07-2010, 11:59 AM   #20
thinde88
Member#: 244908
2004 Wrx Wagon
Red
Im in the process of buying the oils and I see there is a Motul Gear 300 and a Motul Gear 300 LS on fastwrx.com? Is one better than the other? I was also wondering if 4 quarts of the Redline Shockproof LW and 1 quart of the Motul is enough for both the tranny and rear diff. The winters in Chicago and get COLD so I was thinking of making sure I get in just under (save a bloop for the diff) a full quart of the Motul before I top it off with the Redline. Sound good? I just dont want this too be too thick going into winter and was wondering If I should mix a little different. Thanks
thinde88 is offline   Reply With Quote
Old 01-05-2011, 05:49 PM   #21
MARKSTIV8
Member#: 206393
2008 STI
BLUE
Haw a same question???
MARKSTIV8 is offline   Reply With Quote
Old 01-06-2011, 10:30 AM   #22
mneste8718
Member#: 51562
2004 WRX Sedan PSM
EJ205 [email protected] 300whp
Personally I have used Redline Heavyweight shockproof on my 5 speed and it drives smooth as butter. Perhaps I can't always shift as fast but I like it regardless. Anyone have anything against using the heavyweight? It also stopped my 5th gear grind. The oil also breaks down a bit after a while allowing for fast and smooth shifts up until my 5th gear starts grinding all over again.
on a side note, I thought that our tranny's can take 4.75L of oil... or maybe I'm thinking about engine oil.
mneste8718 is offline   Reply With Quote
Old 01-07-2011, 01:41 AM   #23
hybrid gti 2
Member#: 67004
02 vf30 pnp wagon
silver and cf
heavy weight
Old 01-07-2011, 01:51 AM   #24
MY EJ20T
Member#: 133324
2002 MBP Stg 2 Rally
MBP
2.0 engines take 4.8 us qts
MY EJ20T is offline   Reply With Quote
Old 01-07-2011, 01:59 AM   #25
UP2MTNS
Member#: 112405
2004 WRX Rally Car
Silver, Black, and Decals
Originally Posted by hybrid gti 2 View Post
heavy weight
http://www.redlineoil.com/product.aspx?pid=44&pcid=8
but not recommended for synchros.
UP2MTNS is offline   Reply With Quote
+1 again for AndrewTech!!! hopefully i don't in trouble for another AndrewTech thread siopao2000 Mid Atlantic Impreza Club -- MAIC 33 01-09-2007 10:51 PM
The Ballad of the Ice-Worm Cocktail Porter Off-Topic 5 12-21-2004 06:20 PM
Cocktail Table Arcade Game Unit 91 Southern California Impreza Club Forum -- SCIC 15 09-08-2004 08:38 PM
I need a cocktail TheRex Off-Topic 1 03-19-2004 01:46 AM
Tranny Cocktail Barry Transmission (AT/MT) & Driveline 13 01-22-2004 10:59 PM
