Welcome to the North American Subaru Impreza Owners Club Wednesday July 1, 2015
Old 05-02-2002, 09:42 PM   #1
corbeil
Member#: 12722
04 sti
wrb/gold
Default 200 rpm spike on fast shifts
After trading in my 2.5 rs for a new 02 wrx (turbo timer,redline oil in the tranny), I have noticed a 200 rpm spike when the clutch pedal is depressed .Do all wrx's do this ? Is the ecu doing this ? It never happened with the rs.
corbeil is offline   Reply With Quote
Old 05-02-2002, 09:54 PM   #2
WAlude
Member#: 17361
20 Urabus
XRW
Mine does it... is this because the BOV goes back into the intake track?
WAlude is offline   Reply With Quote
Old 05-02-2002, 09:58 PM   #3
corbeil
Member#: 12722
04 sti
wrb/gold
Possibly...I know it only happens on fast shifts.
Old 05-02-2002, 10:25 PM   #4
StevieD
Member#: 14029
Mine does it in 3rd all the time
StevieD is offline   Reply With Quote
Old 05-02-2002, 10:32 PM   #5
BamBooI
Member#: 10945
2006 Evolution IX
I think its because the turbo is still spooling a little bit. I get it too. I think if you do a search its been covered before though.
BamBooI is offline   Reply With Quote
Old 05-02-2002, 10:42 PM   #6
eric m.
Member#: 14872
99 Forester
mine does it too. i think it's normal.
eric m. is offline   Reply With Quote
Old 05-02-2002, 11:58 PM   #7
treybomb
Member#: 14908
2002 PSM WRX Sedan
Exhaust, IC Spray, RE92s
mine too....
possibly because the stock BOV isn't sensitive enough (i.e. doesn't have a low enough threshold) to release WOT boost pressure when the throttle is released for the shift?
it seems, however, that the "rpm spike" on fash shifts has diminished as I put more miles on the car... during the break-in period it annoyed the hell outta me, but now I don't even notice it. Either I've learned to control the engine a little better through the clutch, or for some reason now that it's more "worn in" it doesn't spike as much
- T
treybomb is offline   Reply With Quote
Old 05-03-2002, 01:13 AM   #8
Weedy
Member#: 12340
2002 WRX 2.5L Hybrid
I'm not sure, although I have heard that it it because the stock flywheel is so heavy. It has so much rotating mass that after you disengage the clutch, it takes a little time for it to slow down. I don't really see how this is possible, although that is what I remember being discussed.
Weedy is offline   Reply With Quote
Old 05-03-2002, 08:23 AM   #9
bvl
Member#: 9255
2002 WRX Wagon
This behavior seems to be ECU intervention to me.
Probably a bit of a blip from the ECU in an effort to slow the shift down.
Its not the FW....as the FW is interertial, so it would not spike the RPM as you see, rather it would simply stay where it is, or fall in time delta depending on the amount of inertia it has going for it (which is related to weight...)
BOV could only effect the RPM of the turbine: its not adding fuel/spark or playing with a throttle cable. Don't see how its going to boink RPM 2-300 RPM
when you lilft hard off the throttle
- b
bvl is offline   Reply With Quote
Old 05-03-2002, 09:11 AM   #10
WRX-Hellfire
Member#: 9978
2002 WRX Platinum
Tuned by I-Speed
Post
I thought it was designed that way by subaru to help with emissions. The extra rpms were to help burn off the excess fuel since it runs so rich stock.
WRX-Hellfire is offline   Reply With Quote
Old 05-03-2002, 11:40 AM   #11
blackrex
Member#: 10493
2002 WRX Samco Hoses
D 5000sITG TurboXs Stage1
Hellfire's right it is for emissions.
blackrex is offline   Reply With Quote
Old 05-03-2002, 11:57 AM   #12
mtb_dude
Member#: 12619
02 WRX Wagon
#47 SM w/RA gears
I though it was because the BOV vents to the intake and therefore even after you let up on the throttle, the intake is still partially pressurized for a moment. Does anyone with a atmoshphere vent BOV see this spike?
mtb_dude is offline   Reply With Quote
Old 05-03-2002, 12:49 PM   #13
angus
Member#: 10664
2002 WRX Wagon
the ecu definitely controls this. emissions. my rpm's stick SO late after i let off it's aggravating. i thought someone somewhere was working on a fix for this?
angus is offline   Reply With Quote
Old 05-03-2002, 02:16 PM   #14
TerenceT
Member#: 9510
04 FX35
Pearl White
same feeling
sometimes actualy dangerous if you are trying to let the engine brake
Yes, it's for emissions per Heilfire's explanation
TerenceT is offline   Reply With Quote
RPM spikes when shifting apak123 Newbies & FAQs 9 08-24-2005 02:15 PM
RPM spike SSsleeper96 Newbies & FAQs 5 03-03-2004 10:59 PM
Ok what's with the rpm spike when foot's off the gas? Undepelo General Community 38 02-02-2004 10:26 AM
Does the STi clunks on fast shifts? gtr STi Forum Archive 5 01-09-2003 07:56 AM
RPMs spike when shifting? quynce Newbies & FAQs 15 06-21-2002 05:42 PM
