Old 08-08-2009, 11:16 AM   #1
Nitrousspeed
Member#: 183192
2007 STI
World Rally Blue
Default Replacing Upper Coolant Hose
Hey all,
Just looking for some advice. My cooling fan somehow manages to slice my coolant hose on my 2002 WRX. I think the coolant hose got pulled out a little bit when installing the turbo inlet... Anyways, I bought the new hose, now I need to install it. The obvious is that I need to undo the clamps on the hose, pull it out and install it, however, this will create an air bubble in the coolant system. I also bought a jug of coolant from Subaru. My question is, what do I need to do to top off the coolant system.
Just from watching other people... Im assuming have the car on a flat surface, open the top of the coolant resevour and top the system off, then start the car and as the level drops, add more coolant. keep doing this until the thermostate opens, and keep doing this...
my question is, how long do I need to run the car? and when do I know Im done?
Any help would definately be appreciated!
Thank you!
Nitrousspeed is offline   Reply With Quote
Old 08-08-2009, 05:30 PM   #2
DrD
Member#: 22412
2012 Legacy 2.5GT
Ice Silver Metallic
Upper radiator hose replacement: Coolant flush necessary? 8-pointer Newbies & FAQs 3 09-22-2009 08:28 PM
Melted coolant hose....silicone replacement? (i read cooling faq) JDMFLCL Newbies & FAQs 1 08-11-2009 03:25 PM
fast way to replace upper radiator hose? sicminded Factory 2.0L Turbo Powertrain 4 07-18-2006 03:29 AM
WTB: radiator hose kit, and coolant hose kitboth in blue. AudiobahnSTI Private 'Wanted' Classifieds 0 03-30-2006 01:25 AM
02 WRX Upper Radiator Hose Coolant Leak! wrxmechman Service & Maintenance 3 03-13-2005 01:56 AM
Message Board Statistics All times are GMT -4. The time now is 10:55 PM.
