Old 08-08-2009, 09:04 PM   #1
subiboi624
Member#: 198889
02 SLAMMED WRX
01 FORESTER both Silver
Default Rear Camber
So i just installed my new BC coilovers Br series and did my alignment I am running 225 45 17 tires 17 x 7.5 Rota Tarmac III and came to this
Front
Camber
-.5 L -.5 R
Caster
3.5 L 3.8 R
Toe
0 L 0 R
Rear
Camber
-2.4 L - 3.4 R
Toe
.5 L .5 R
I tried taking a TOMCAT bag to push out the strut but couldn't get any less than a 1 degree spread of camber in the rear there are no cmber plates in the rear.
So my question is am I going to need rear camber bolts or camber plates to eliminate this problem or should I be ok if I just rotated my tires more frequent?
Thanks
subiboi624 is offline   Reply With Quote
Old 08-08-2009, 09:18 PM   #2
nhat
Member#: 140163
03 STi
hellaflunctional
-0.5* up front? and -2.4*/-3.4 in back?
go get a professional alignment and corner balancing. the money spent there will save your tires and allow your car to handle much better.
Old 08-08-2009, 09:25 PM   #3
subiboi624
Member#: 198889
02 SLAMMED WRX
Well the reason that the rear is like that is bc i can not get it to come in anymore
hence the reason I had set this up I don't race just my DD I only drive this car around town so........
can anyone help me with what i should do to bring this camber in
also I am a service center manager and I am a working manager so this in my opinion is a professional alignment
Old 08-12-2009, 12:34 AM   #4
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
raise the car a bit
that usually lessens rear camber or ya got something bent
and you want -1.5 camber in front---at least
and kill the toe in back....THAT will eat tires in a heartbeat
Old 08-12-2009, 12:35 AM   #5
Uncle Scotty
Member#: 16200
OK buy Nates beans
son....ya doin it wrong and that is NOT in any way any sort of 'professional' alignment for any subaru
Old 08-12-2009, 07:15 AM   #6
05-rsx
Member#: 101188
MY07 WRX Wagon
+1 to Scott the Uncle.
-2.5L, -3.5R says to me either a)something didn't go together properly, or; b) something's bent.
If you're getting those kinda numbers in the rear, you must be pretty low, so dial in some more front camber. Even with my -35mm H&Rs I can get -1* in the front (with -1.5* fixed in the rear, for the moment).
Dial out some rear camber. If you can't do it with the stock bolts, get some aftermarkets ones.
What are your ride heights F/R?
05-rsx is offline   Reply With Quote
whacky rear camber settings...rear camber bolts a good fix? IIdiceII Brakes, Steering & Suspension 5 06-13-2006 02:33 PM
What rear camber setting with lowering springs and camber bolts? kestrel Brakes, Steering & Suspension 3 10-11-2003 02:54 PM
Removing Negative Rear Camber with camber bolts? NicGordon Brakes, Steering & Suspension 1 08-15-2003 12:39 AM
Rear +camber adjustment and camber plates. Assistance needed. ebeck Brakes, Steering & Suspension 13 07-23-2003 08:17 AM
rear camber bolts = front camber bolts? Penguinking Brakes, Steering & Suspension 1 07-12-2003 10:01 PM
