Old 08-09-2009, 11:03 AM   #1
moorebl
Member#: 59238
Default deadbolt monster TD04 or BLOUCH 19t td04 for 2.0 wrx
i want to juice my 2002 wrx with a little more power. i know deadbolt isnt around anymore but there turbos still lurk. so the wuestion is do i get a TD04. PnP housings Upgraded Compressor wheel and Clipped turbine wheel or do i get the tdo4 19t upgrade from blouch. looking for the most power more efficient and well rounded turbo on the 2.0. the above two is what i want to stay around because they are both cheap. chime in if you know info or own one. post results if you can. thanks
moorebl is offline   Reply With Quote
Old 08-09-2009, 11:18 AM   #2
2gnt2wrx
Member#: 123625
2015 WRX
Galaxy Blue
2gnt2wrx is offline   Reply With Quote
Old 08-09-2009, 11:25 AM   #3
Strider327
Member#: 131280
2004 Impreza WRX
Between the two I would get the Blouch 19T. But if I was gonna spend that amount of money, I would get the Blouch Standard 16G. You'll have to do the fuel pump and injectors, some kind of boost controller and a tune no matter which route you go. Good Luck. I've ridden in both and I believe the 16G is more worth the money.
Strider327 is offline   Reply With Quote
Old 08-09-2009, 01:15 PM   #4
jason miller
Member#: 158313
2003 WRX
that's exactly what the 19t is...
jason miller is offline   Reply With Quote
Old 08-09-2009, 01:32 PM   #5
Thom
Member#: 152775
2004 Wrx
Java Black Pearl
why is the 16g worth it more? because it has more top end? my question is can the 16g spool as quick as the 19t?
Thom is offline   Reply With Quote
Old 08-09-2009, 02:13 PM   #6
sanremo_russ
Member#: 56465
2004 WRX - VF34
SRR
Given the same configuration except for the turbo a TD04 will always outspool a TD05.
sanremo_russ is offline   Reply With Quote
Old 08-09-2009, 02:23 PM   #7
Waking The Fallen
Member#: 125950
2010 BMW 135i/05 Sti
7.3 F350/06 Audi A4
fp green hta ftw
Waking The Fallen is offline   Reply With Quote
Old 08-10-2009, 02:13 PM   #8
jrobinson
Member#: 190786
Sedona Red
So the compressor wheel on the Deadbolt Monster TD04 is a 19t? I've been curious about that for some time. Deadbolts old website doesn't clarify.
jrobinson is offline   Reply With Quote
Old 08-10-2009, 03:02 PM   #9
Thom
Member#: 152775
2004 Wrx
Java Black Pearl
i thought there monster TDO4 was just pnp.
Old 08-10-2009, 03:12 PM   #10
Haelan
Member#: 151045
2013 Subaru STI
CBP
Yes, but they did offer a compressor wheel upgrade and clipped turbine blades as options. I'm not sure of the wheel size though...
Haelan is offline   Reply With Quote
Old 08-10-2009, 04:58 PM   #11
jason miller
Member#: 158313
2003 WRX
The standard "monster td04" was ported and polished like crazy, and had turbine clipping or compressor upgrading as available options- but the porting was all that was standard.
The Blouch unit is just a rebuilt td04 with the upgraded compressor wheel and an "extreme duty thrust bearing". Also, Mike at Blouch has told me over the phone that Deadbolt's "monster" or "zilla" porting was more marketing than actual performance enhancer.
Blouch also has brand spankin' new 16g's on sale for $649 right now, btw. That's a pretty good price for the performance.
Old 08-10-2009, 05:11 PM   #12
moorebl
Member#: 59238
so everyone seems like the blouch is more efficient and will produce the most power. .
Old 08-10-2009, 07:48 PM   #13
quazimoto
Member#: 70395
Right and that is why Blouch offers optional porting for $95. So is that just for marketing too? Porting turbos does work,just like porting heads or exhaust manifolds works..................
quazimoto is offline   Reply With Quote
Old 08-10-2009, 08:09 PM   #14
jason miller
Member#: 158313
2003 WRX
I think the idea was that there was nothing special about Deadbolt's porting versus any standard porting...
Old 08-10-2009, 09:31 PM   #15
Strider327
Member#: 131280
2004 Impreza WRX
Its marketing what can you say.
Old 09-19-2009, 06:56 PM   #16
scoobyWRXlove
Member#: 222927
So which way is better deadbolt zila or Blouch 19t?, and if I go from stage 2 to 19t I am gona need injectors, protune, and do I need bigger intercooler?
scoobyWRXlove is offline   Reply With Quote
Old 09-20-2009, 01:56 AM   #17
jcbluescooby
Member#: 113012
'04 XT red LIFTED
'15 XV CROSSTREK LIFTED
deadbolt monster td04 will spool faster since its just a pnp td04..blouch 19t will get you more compressore due to the compressor upgrade however you will spool a tad slower..deadbolt td04 you can just bolt on..blouch 19t you need injectors and a protune
jcbluescooby is offline   Reply With Quote
Old 09-20-2009, 12:26 PM   #18
dsmtowrx
Member#: 48879
2010 STi 2.5xtr hsf6
Grey Stocker
Definitely go 16G. Or VF34. You wont be happy with the small jump in power on those tiny guys for going to the trouble of changing turbo's!
dsmtowrx is offline   Reply With Quote
Old 09-20-2009, 02:35 PM   #19
SacksLax
Member#: 193949
EVO III 16g. Just bought mine, cannot wait to get it tuned. Read up on it, best 2.0 turbo...this is backed by mods and many tuners
SacksLax is offline   Reply With Quote
Old 09-20-2009, 02:51 PM   #20
novacivic
Member#: 117980
2005 sti
wr blue
what about the hta68. from what ive heard better spool and more power than a 16g
novacivic is offline   Reply With Quote
Old 09-20-2009, 03:54 PM   #21
SacksLax
Member#: 193949
On a 2.5...2.0 they spool much too late
All the comparisons have been done at a 2.5.
Old 09-20-2009, 11:05 PM   #22
dinosmash
Member#: 143598
05 lgt
i just swapped a small 16g for a 19t.with a mbc the 16g hit full boost at 3700 and the 19t does it at 2700.theres no waiting for boost on the 19t.on the 16g it held 20 psi to redline.the 19t dips to 17 past 6400 but you wouldnt know it.ill be tracking my car next week and show some results here.im an advocate for the 19t because its the best driving experience youll get on the 2.0.the power is always there.waiting for power sucks.i went from 16g to stage2 to 19t.it was the right move for me
dinosmash is offline   Reply With Quote
Old 09-20-2009, 11:17 PM   #23
N/A_junkie
Member#: 99961
03 Super Obnoxious
Wrx. A rare blue one.
i'm posting here to see your results later...i've been doing some turbo browsing as well
N/A_junkie is offline   Reply With Quote
Old 09-20-2009, 11:28 PM   #24
neversummer489
Member#: 153729
PSM Bugeye
Missing rod bearing??
I agree boost comes in late with the hta68 but man does it pull hard I love mine
neversummer489 is offline   Reply With Quote
Old 09-21-2009, 01:19 AM   #25
jcbluescooby
Member#: 113012
'04 XT red LIFTED
waiting for your update..im stage 2 right now and thinking of going 19t just caus i want a fun daily driver and something that spools as soon as you step on it
WTB: Deadbolt Td04 or Blouch 19t speedymaker Private 'Wanted' Classifieds 0 12-16-2009 04:11 PM
FS in MA: AccessPort Version 2 for 2.0 WRX (2002-2005) fish917 NESIC Private Classifieds 3 08-15-2009 01:32 PM
2 Utecs one for 2.0 wrx one for STi turboedracer NWIC Private Classifieds 0 01-04-2009 03:17 AM
VISHNU STAGE ZERO for 2.0 WRX $199 NaSTI25 Engine/Power/Exhaust 0 03-09-2007 04:25 PM
Oil line and intake manifolds for 2.0 WRX sfjohnson Private 'For Sale' Classifieds 0 12-09-2005 09:06 PM
