Welcome to the North American Subaru Impreza Owners Club Tuesday May 26, 2015
Go Back   NASIOC > NASIOC Classifieds > Private Vehicle 'For Sale' Classifieds
Old 08-09-2009, 06:51 PM   #1
awdrev
Member#: 148469
Exclamation FS: MD/DC/VA - 2004 WRX with elite sound system,DVD,Navi plus more!
Hello.
I’m selling my 2004 Impreza WRX with close to 95000 miles.
I’m the second owner of this very nice car and I will give you some insight as to the history of the car.
The first owner was an old lady and did not touch or modify the car at all, it seems to me that she only used the car and did whatever maintenance required to it. I bought it in 2007 with about 65000 miles and in prestige condition with some obvious wear/tear normal issues.
As soon as it was in my possession,(May 2007) I did all maintenance and extended maintenance to the essential components: Transmission and Engine. I flushed both differential fluid and filled it with OEM Specified lubricant. Spark plugs have been changed to Iridium for a better combustion. Moreover, I did an oil change starting the day I bought it and every 3500 miles or so using FULLY SYNTHETIC OIL. (I have some pictures of when I did it)
Please note: MOBIL ONE doesn’t work well with this car, it seems to burn it quite fast. I’ve been using Castrol and it works flawlessly.
MODIFICATIONS:
Please note that no “MAJOR” modifications have been done to the car. I personally only wanted a car that could be fast when needed, that was comfortable, and that it had a really clean sound. (Emphasis on really clean)
UNDER THE HOOD MODIFICATIONS:
Intake – Iridium Spark Plugs – YELLOW TOP Optima Battery (Optimal efficiency for the stereo system)
INSIDE CAR ENTERTAINMENT (ICE)
I will try to make this section as short as possible. I wanted quality, efficient and clean sound without sacrificing everything in my trunk or my wallet.
Electronic List:
* Alpine Amp - MRP-M500
* Alpine Amp - 2/3/4 Way - MRP-F30
* Alpine 12" Subwoofer - SWR-1242D
* Pioneer - Avic D3
* Rockford Fosgate - 1 Farad Capacitor -
* 6-1/2" Type R Alpine Component Set
* 12" Subwoofer Enclosure "Perfect Fit" for WRX
Made by Audio Integrations
I hate $hitty jobs so I decided to do this myself 100%. I did a walkthrough that has been used by many people and has been posted online in many different websites. Follow this link and you can see it in one of the forums:
http://www.clubwrx.net/forums/interi...-even-try.html
As you can see, I took my time and did everything to maximize space in the trunk. It is probably one of the cleanest sounds you can achieve in a car and I’m pleased with the setup. Both music and movies sound phenomenally clean and sharp, exactly what I wanted. Moreover, I added a YELLOW TOP OPTIMA BATTERY that maximizes the potential of the system and takes some stress off the alternator. As you can see, I further even made the system better with a 1-farad capacitor and only used 4 gauge wiring for main POWER LINES and 8 gauge after the distribution block. Again, take a look at the pics so you can see this well-done job. In conclusion, if you’re looking for a very nice sound, this car is for you. If you’re looking for a car that rattles everywhere and has a distorting sound, please close this window. Everyone wants a nice system with a clean sound, I’d suggest listening to this setup before making judgments!
EVERY SOUND SYSTEM COMPONENT HAS A 4 YEAR WARRANTY FROM BEST BUY.
This includes the HEAD UNIT, AMPS, SUB AND CAPACITOR. This warranty is fully transferable to the new owner!
MORE ELECTRONICS:
ATI Triple Pod with STRi Gauges
Boost / Oil Pressure / Oil Temperature
FULLY FUNCTIONAL / Opening Curtain feature / You'll also get the stock clock
IN CAR SECURITY
The car’s alarm is one of the most well-known and secured ones. I installed the 2-way VIPER SYSTEM VX791.
You will receive TWO REMOTES (not one) and they both work flawlessly. In addition, I installed TWO AUXILIARY ports to the alarm. First, I installed an automatic window unit, with the press of a button you can put the FRONT windows up and down from a far distance; furthermore, when you lock the car the front windows automatically go up! It’s really awesome actually.
The second port I installed was a PROXIMITY SENSOR. It’s adjustable and you can change the setting, but pretty much if someone gets really close to the car and tries to peek into the window, the car will WARN them away with a series of chirps. You will get a notification of that in your remotes also.
Last but NOT least, the ultimate and most annoying feature of the car’s alarm system: Indoor siren. This cost me about 150 bucks or so and it’s located inside the AC panel. If the alarm goes off this ridiculously loud and annoying siren will kick you out of the car running, it’s so well positioned that if the alarm goes off and you’re by the steering wheel, I’ll give you about 6 seconds before you give up doing anything inside.
What I’m looking for:
I’m looking to sell the car to someone that would really take care of it. I’ve spent thousands of dollars in this car and it’s in a really pristine condition. Furthermore, I have EVERY SINGLE STOCK PART for this car and you will get the following:
• Stock Intake Box
• Stock Exhaust
ASKING PRICE – 11,300.00 NEGOTIABLE - I'm not selling it because I have to get rid of it, but long term (school wise) I will not be able to keep it. I may be moving across the country sometime next year and I will not be needing a car. I will reiterate my goal: Letting it go for a fair price to an educated and realistic person that will keep its legacy!
If you’re interested – You are to EMAIL ME WITH YOUR INQUIRIES -
- YOU ARE WELCOME TO SEE THE CAR AT ANYTIME -
I WILL NOT PART OUT THE SOUND SYSTEM SO PLEASE DO NOT ASK
PLEASE NOTE - Gold rims are NO LONGER AVAILABLE AS I HAVE TAKEN THEM OFF THE CAR AND THEY'RE BEING USED IN ANOTHER ONE.
Car will come ONLY with stock rims - email if you have any questions
EMAIL
2004wrxsale@gmail.com
I got tons of pics - Please check this link for pics!
http://photobucket.com/2004wrxsoundsystem
http://s2.photobucket.com/albums/y37/awdrev/CARPICS2/
awdrev is offline   Reply With Quote
Old 08-09-2009, 07:58 PM   #2
ahendrickson
Member Sales Rating: (2)
Member#: 164625
2007 WRX Wagon 20g
External Wastegate
Damn, you got alotta graduation pics.
ahendrickson is offline   Reply With Quote
Old 08-09-2009, 08:11 PM   #3
awdrev
Member#: 148469
haha fixed, you freeking peeping toms! lol
Old 08-11-2009, 03:40 PM   #4
awdrev
Member#: 148469
bumpity bump!
Old 08-12-2009, 07:01 PM   #5
awdrev
Member#: 148469
bump!
Old 08-13-2009, 06:56 AM   #6
IamRascal
Member#: 73749
2003 Pontiac
got any pics that aren't in the pitch black of night?
IamRascal is offline   Reply With Quote
Old 08-13-2009, 11:15 AM   #7
java09
Member#: 220312
contact me757 513 2363
java09 is offline   Reply With Quote
Old 09-01-2009, 03:42 PM   #8
awdrev
Member#: 148469
BUMP! I added a third link with more pics!
Old 09-13-2009, 11:46 AM   #9
awdrev
Member#: 148469
Bump!
Old 11-20-2009, 11:50 PM   #10
awdrev
Member#: 148469
bumpy!
Old 11-23-2009, 11:25 AM   #11
awdrev
Member#: 148469
Bump!!!
Old 11-23-2009, 01:20 PM   #12
richy_21
Member Sales Rating: (200)
Member#: 58670
2005 got muuuuu?
bump for a 12" Subwoofer Enclosure "Perfect Fit" for WRX
richy_21 is offline   Reply With Quote
Old 11-24-2009, 01:40 PM   #13
awdrev
Member#: 148469
I still have like 80% of my trunk to use though!
AND BUMP!!
Old 11-25-2009, 09:39 AM   #14
awdrev
Member#: 148469
Bump!
Old 12-04-2009, 10:40 AM   #15
awdrev
Member#: 148469
Bump - Price Is Negotiable!!!
Old 12-04-2009, 12:35 PM   #16
richy_21
Member#: 58670
2005 got muuuuu?
sell me the sub box!!!!!!!!!!!
Old 12-10-2009, 09:06 AM   #17
awdrev
Member#: 148469
Bump!!!!!
Old 12-10-2009, 10:31 AM   #18
kreitz3
Member Sales Rating: (3)
Member#: 100242
Wow. You play a lot of WOW.
kreitz3 is offline   Reply With Quote
Old 12-10-2009, 10:54 AM   #19
awdrev
Member#: 148469
2 years ago, yes
but thanks for trolling
BUMP
Old 12-15-2009, 06:27 PM   #20
awdrev
Member#: 148469
BUMP - You can see the car now!
Old 12-17-2009, 12:32 PM   #21
awdrev
Member#: 148469
bump!!
Car can be seen at anytime!
Old 12-29-2009, 10:33 PM   #22
awdrev
Member#: 148469
Bumpity Bump!
Get it for new years!
FS: COBB AccessPort V1. 2004 WRX with StreetTuner Software $325 Shipped via PayPal! ScoobyNubieToo! Engine/Power/Exhaust 7 05-28-2009 10:43 PM
WTB: MD/DC/NoVA - 2004+ WRX/STi/Legacy CRedfield Private 'Wanted' Classifieds 6 01-22-2008 01:06 AM
Fs: Md/dc/va Aps Tmic Bov New sgt Engine/Power/Exhaust 12 05-07-2007 03:10 PM
FS: MD/DC/VA - 2004 PSM WRX Wagon 5spd sjw Private Vehicle 'For Sale' Classifieds 6 11-18-2006 01:03 PM
FS: Md,DC,Va 17x7.5 Rota Subzeros/Toyo T1-S Plus free gift SilverBoosted Private 'For Sale' Classifieds 2 01-23-2004 08:11 PM
