Welcome to the North American Subaru Impreza Owners Club Thursday May 28, 2015
Old 08-09-2009, 07:39 PM   #1
jasmine008
Member#: 148529
98 Outback wagon
Glacier white
Default Low fuel light goes on and off at 1/4 tank
Hi,
Driving today (98 outback), my gas light came on much earlier than expected. I can usually get about 300 miles before my gas light comes on, but today it came on after about 245 miles. The gas gauge read 1/4 tank when the light came on.
The light stayed on for a few miles (I was more or less driving straight over a bridge), then went off. About 10 miles later it did the same thing (on then off). My car's pretty consistent about when the gas light comes on, so this was pretty odd today. Especially when it kept going on and off.
Any ideas?
Jennifer
jasmine008 is offline   Reply With Quote
Old 08-09-2009, 11:23 PM   #2
Cougar4
Member#: 53443
2001 LL Bean Outback
Winestone
The light is controlled by a thermistor mounted in the gas tank. As the fuel level drops below the thermistor it warms up and changes resistance and the circuit turns on the light. There may be some trouble with the accuracy of the fuel tank level gauge and it is showing a little more fuel than there really is in the tank. Cleaning the contacts on the level sensor may help. I don't think the thermistor position can or would change.
Old 08-10-2009, 11:05 AM   #3
jasmine008
Member#: 148529
98 Outback wagon
Glacier white
I'll give it a try. Thanks.
Old 08-10-2009, 11:29 AM   #4
Cougar4
Member#: 53443
Winestone
Chevron makes a product called Techron that is used to clean fuel systems. Some folks have had success cleaning the sensor contacts for the fuel gauge by adding a bottle to the fuel tank before a fill up. It may help you also if the sensor contacts are dirty. It is a lot easier than pulling the sensors (2 of them) out of the tank.
Old 08-29-2009, 08:40 AM   #5
jmorgan3312
Member#: 221946
1993 impreza
white
techron is the best stuff in my oppinion i use it at every oil change and never had and fuel problems
jmorgan3312 is offline   Reply With Quote
Old 08-29-2009, 10:08 AM   #6
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
the op may have got contaminated fuel
Old 04-26-2010, 10:28 AM   #7
evil girl
Member#: 61196
2002 wrb wagon
mmmm. I had the same problem on my 02 bugeye. I'll try the fuel additive too see if that helps.
evil girl is offline   Reply With Quote
Old 05-02-2010, 02:49 PM   #8
mat0872
Member#: 245731
Hopefully you don't have happen to you what happened to me
Going down the road, low fuel light cuts on, three minutes later the car died
Bad luck, lol
mat0872 is offline   Reply With Quote
Old 05-03-2010, 09:56 AM   #9
Davidwrx
Member#: 141028
2002 WRX Wagon
My '02 had trouble and it triggered a CEL. I replaced both fuel sensors (1 for each side of the tank) and problem was solved.
Davidwrx is offline   Reply With Quote
High coolant temp, cel, oil pressure light goes on and off? wtf cazwrx187 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 2 03-05-2010 03:25 PM
High coolant temp, cel, oil pressure light goes on and off? wtf cazwrx187 Electrical & Lighting 1 02-14-2010 12:58 AM
Abs Light Comes On And Off At Certain Times dmoney1770 Service & Maintenance 1 10-28-2008 05:14 PM
E-Brake Light Goes on and off? NycFox Brakes, Steering & Suspension 9 05-20-2007 11:38 AM
"brake" light comes on and off at random OneArmedScissor Brakes, Steering & Suspension 5 08-13-2003 10:09 PM
