Old 08-09-2009, 08:04 PM   #1
acemyles2.5i
Member#: 151012
2007 impreza 2.5i
urban
Default engine
whats a good writeup that breaks down the boxer engine, specifically the 06-07 series, im looking to go boost on mine considering a swap is out of my range, and i can get the parts for the setup for fairly cheap, but i know theres alot more than just slapping on a turbo kit, i want to know what exactly needs to be replaced to handle about 10psi or so, ive been talking about it with a mechanic friend of mine and hes positive i could do it by beefing up the block and running low boost, but i want the specifics....thanks
acemyles2.5i is offline   Reply With Quote
Old 08-10-2009, 12:26 AM   #2
anothernord
Member#: 193703
You want to lower the compression ratio to allow more boost to be used. Either a thicker headgasket or just turbo pistons/rod/crank.
anothernord is offline   Reply With Quote
Old 08-10-2009, 05:23 PM   #3
acemyles2.5i
Member#: 151012
2007 impreza 2.5i
urban
well i was gonna go with wrx rods, piston and crank, but wasnt sure if they will just swap over, im thinking of just buying a manual for my car and reading up the differences between mine and the same year (06-07) wrx, i was thinking of doing a complete swap, but then again i was gonna see if i could run low boost, but the horror stories on here scare the living **** out of me haha im not the richest guy but i got some money to do this project, but only once lol im just kind of stuck, more reading for now i guess though....thnx
Old 08-10-2009, 07:42 PM   #4
Tradewind
Member#: 159312
2005 Subaru Impreza
Aqua Blue
Run the right SC/ECU and you can go up to 6psi with no horror stories at all.
There could be a 3-4psi kit coming out for your model which bolts right on and gets you going
Tradewind is offline   Reply With Quote
Old 08-13-2009, 10:51 AM   #5
jey
Member#: 32503
2011 Tribeca
1995 Legacy Wagon
Another option: a beefier preassembled block already exists. The EJ257 STi block bolts right up to your heads.
jey is offline   Reply With Quote
Old 08-13-2009, 11:43 AM   #6
Harenil
Member#: 93071
1995 Impreza L EJ22G
(Hybrid EJ22T/EG20G)
Another option - I have to suggest this. Sell the 2.5i and get a WRX.
Otherwise, I agree with jey, EJ257 would be a definite good bet, that way you could run a significant amount of boost with little risk.
Harenil is offline   Reply With Quote
Old 08-13-2009, 11:44 AM   #7
PA-Outback2000
Member#: 161832
2000 Outback Limited
for 10psi, like Jey said, u need a stronger block and lower compression pistons. stock, u can do 6psi no problem, but u need a new/piggy-back ECU and someone that can tune the car well so it won't blow up. AVO has a kit that bolts onto the 2.5L engine. how much do u want to spend?
PA-Outback2000 is offline   Reply With Quote
Old 08-13-2009, 02:44 PM   #8
subiidude
Member#: 141472
2008 shagg wgn STI
OG FP20g+e85 corn booze
the crank in the 2.5 i/rs is the same as the sti, only need sti rods and pistons to make it sufficiently beefy
subiidude is offline   Reply With Quote
Old 08-14-2009, 01:14 PM   #9
SUBYAWD85
Member#: 208228
2007 Impreza 2.5i
Newport Blue
AVO is designing a kit right now that will run 6psi safely. It will bolt up to the 06-07 2.5 engine with running stock internals. If you beef up the internals with forged pistons, etc, you can probably run more.
SUBYAWD85 is offline   Reply With Quote
Old 08-15-2009, 08:38 AM   #10
VIsubi
Member#: 187834
06 2.5i impreza
Red
OK people whats wrong with you....to do 10 psi you would need a good tune and stock internals can do it..theres a guy on here that ran 10 psi all day the nwent to 14 psi on a lagacy only to blow up the motor due to experimentation on the tune at 14 psi... the WRX pistons aren't even forged neither are the USDM STI pistons on that year 06-07 hawk eye there silica treated..all you would need is pistons the rods on the 2.5i are already forged shared by the wrx rods and like stated all three share the same crank which is also forged...so to answer your question some forged pistons of the same compression ratio 10:1 with that 10 psi of boost to make the same power a wrx would need to run 4-5 more psi of pressure...I tell everyone that low compression pistons are very much overated and just make your turbo work more at spooling up or half that with big power. Yes your heads can handle 350 hp to the wheels. Maybe add some stronger head gaskets not so much to lower the compression..
VIsubi is offline   Reply With Quote
Old 08-15-2009, 07:13 PM   #11
koester95
Member#: 219059
Hey, I have put a turbo kit on my 07 2.5i. Its runs good outside of WOT. I have it external gated at 4 psi. Outside WOT, it will hit 3 psi, but at WOT it only do 1 psi. I was thinking it was going lean, so i got an FMU 12:1. Now the problem is that it when it hits 1 psi, the car dies. I have to crank and crank to get it to start again. I'm thinking it is going into fuel shutoff if it has that, but not sure. Any ideas? Any help would be nice. And by the way I have less than 800 dollars in my kit and I installed it my self (cert. tech, 26 hours to install with my factory cats still in it).
koester95 is offline   Reply With Quote
FS : CUSCO Engine Mounts xdrian Engine/Power/Exhaust 6 06-20-2010 08:37 PM
Is there engine problem with the 2011 STI? speed12sil Warranty Issues & SOA Problems 19 06-14-2010 11:10 AM
BMW’s 500cc per cylinder powerplant : A New Base in Engine Design AVANTI R5 Non-Subaru News & Rumors 14 06-07-2010 10:59 AM
SOLD ME- RC Engineering 02 650cc Injectors dlewis Engine/Power/Exhaust 23 05-31-2010 06:48 PM
SOLD ME-RC Engineering 650cc Injectors dlewis NESIC Private Classifieds 21 05-31-2010 06:42 PM
Message Board Statistics All times are GMT -4. The time now is 07:16 AM.
