08-10-2009, 08:44 AM | #1 |
Member#: 63294
E. Canada
Vehicle:2002 WRX Wagon Blue |
CPU reprogram/O2 sensor replaced question
I recently replaced my front O2 sensor but the Check Engine light still comes on after I clear it. I was told by the dealer that I need to have it reprogrammed but it'll take an hour to do it and cost me $110.
Is there any way I can do this myself? I have a Cobb Access Port, if I reprogram the MAP to stock, would this do it? alwrxwu
08-10-2009, 10:13 AM | #2 |
Member#: 21808
E. Canada
Vehicle:02 GroceryGettAr Nonemore Black |
I don't think any reprogramming should be required
What code(s) caused you to replace the O2, what code(s) are you pulling now, and what mods do you have? |
08-10-2009, 10:32 AM | #3 |
Member#: 63294
E. Canada
I'm getting a P0171 lean code. I orginally brought it to another dealer (while on vacation) and they told me that the front O2 sensor needed replacing. So I ordered one and replaced it myself and it's still throwing the code. My usual dealer said I need to reprogram the CPU if I replace the O2 sensor so that's why I'm brining it in since the code keeps coming back.
Mods are Lightened pulley Inlet pipe Cobb Access Port alwrxwu |
08-10-2009, 10:58 AM | #4 |
Member#: 1847
Vehicle:Team Broken: V6 GF rallyarmor.com |
You should check for vacuum leaks. I bet you have one, check that inlet hose. Intake gaskets.
It could also be a bad MAF sensor. 171 = faulty 02 sensor very rarly |
08-10-2009, 11:27 AM | #5 |
Member#: 21808
E. Canada
what kind exactly? intakes can cause the P0171 code by messing with the MAF readings
P0171 CEL Thread - Everything you ever wanted to know |
08-10-2009, 03:05 PM | #6 | |
Member#: 63294
E. Canada
Perrin
It's a Samco turbo inlet pipe.
All right, it seemed odd that the dealer kept telling me that I have to have them reprogram the CPU but I thought maybe it was to reset to factory defaults or something. Quote:
08-10-2009, 03:14 PM | #7 |
Member#: 63294
E. Canada
The only thing is I'm not really getting bad mileage although that's when the CEL would get thrown. It's typically when I'm cruising on the highway for a few minutes. I'll check all my hoses again.
"In his case, with the "bad" o2 sensor, the CEL would disappear after resetting the ECU, but would come back on after shutting the car off and cruising on the highway for a few minutes. When the CEL was on, the car would run extremely rich and dump fuel like crazy. I think he said he would see anywhere from 325-350 miles to a tank with conservative driving, and he was seeing something like 200-250 miles to the tank when the CEL was on." |
08-12-2009, 06:39 PM | #8 | |
Member#: 16200
Vehicle:OK buy Nates beans westcoastroasting.com |
ya got a leak |
08-12-2009, 08:40 PM | #9 |
Member#: 30669
Vehicle:1998 Legacy 2.5GT Silver Sleeper BK, 5MT |
+1, there is NO need to "reprogram" the ECU because you replaced a sensor.
You can do a hard ECU reset (disconnect battery, yada yada yada...), do a reset via the AP, or just drive it to clear any "CEL's" from the bad O2 sensor (that is now replaced). The inlet pipe should have no real bearing on how the car runs. An aftermarket intake probably would. As others have stated, check for leaks. |
08-12-2009, 08:57 PM | #10 |
Member#: 21808
E. Canada
yeah my bad I read 'inlet pipe' as 'intake pipe' in the earlier post
one often overlooked possibility is an *exhaust* leak near the front O2 sensor - because the sensor works relative to ambient O2 if exhaust fumes get around it, the outside can look 'rich' (low O2) making the actual reading *appear* lean |
O2 sensor replacement | henryh | Vancouver Impreza Club Forum -- VIC | 20 | 01-06-2003 08:03 AM |
Front O2 sensor replacement Question | Peaty | Normally Aspirated Powertrain | 1 | 11-16-2002 02:00 AM |
CEL again after O2 sensor replacement | FuJi K | Normally Aspirated Powertrain | 5 | 06-27-2002 03:03 PM |
how important is it to get the front o2 sensor replaced? | inpreza kid | Canada Region Forum | 1 | 08-02-2001 02:35 PM |
O2 Sensor replaced.....finally! Info + Rant | FargoRS | General Forum Archive | 15 | 01-19-2001 08:52 PM |
