Old 08-10-2009, 09:20 AM   #1
Ammadien
Member#: 100370
2005 Stage 2 sti
Default Linseed oil? sti rear end WTF?!
So I called the dealer looking for some rear end fluid for my 2005 sti.
One says they only have it in bulk, and I don't want to buy 100 bucks worth of oil for a change I might do 3-4 times in the life of the rear end.
The other says it's linseed oil...? and it's 24 bucks a quart. Anybody hear this before? Should I ask specifically for the oil I need? I didn't have the owners manual with me when I called so I wasn't sure what it was called specifically. Any help would be great.
Nate
Ammadien is offline   Reply With Quote
Old 08-10-2009, 09:55 AM   #2
UkNuck
Member#: 21808
02 GroceryGettAr
Nonemore Black
LSD... LSD oil... not linseed oil
UkNuck is offline   Reply With Quote
Old 08-10-2009, 10:42 AM   #3
09rexwagon
Member#: 216135
2011 Civic SI
STX #66, 06 S2000 STR 180
Linseed oil is for high temp frying...of food .
EDIT: Nevermind, linseed oil is a flax oil nutritional supplement....I was thinking grapeseed oil...but still, that guy was a bit off with his wording .
09rexwagon is offline   Reply With Quote
Old 08-10-2009, 11:00 AM   #4
Ammadien
Member#: 100370
2005 Stage 2 sti
So the tech was off his rocker?
He specifically said linseed, at first he said, "is that that some sort of seed oil?"
*sigh* I'll check with the other dealer again.
Thanks for the replies.
Nate
Old 08-10-2009, 11:21 AM   #5
UkNuck
Member#: 21808
02 GroceryGettAr
Nonemore Black
Old 08-10-2009, 01:22 PM   #6
Ammadien
Member#: 100370
2005 Stage 2 sti
Thanks for the link, pretty expensive stuff.
Nate
Old 08-10-2009, 03:50 PM   #7
bulwnkl
Member#: 41070
2005 Black Tiger
(Black Turbo Baja)
As said, NOT linseed oil.
The dealer that 'only has it in bulk' should be just what you need, unless they want to be un-helpful. If they truly have it in bulk (which would normally mean in a 275 gallon shuttle tank or larger, but sometimes places with drums call them 'bulk'), they must go through a lot of it, and they should be willing to sell you a quart or a gallon or whatever right out of their container.
However, some places mistakenly refer to 35-lb. pails (sometimes called 5-gallon buckets) or even gallon containers as 'bulk.' Aside from the fact that those places don't know jack about oils & lubes, they're almost certainly not going to open a container just to sell you a quart or two.
OTOH, I've never seen anything anywhere that someone was able to show that the Subaru fluid is actually special or different in any way whatsoever. So, go get yourself whatever you want.
bulwnkl is offline   Reply With Quote
Old 08-10-2009, 03:57 PM   #8
JamesHenry
Member#: 137819
1999 Subaru Impreza
2.5RS w/ WRX Swap
LOL @ linseed oil.
JamesHenry is offline   Reply With Quote
Old 08-10-2009, 04:33 PM   #9
Ammadien
Member#: 100370
2005 Stage 2 sti
Thanks for the replies all. Think I have it worked out!
Nate
trade: 04 psm sti rear end for 02-03 psm rear end password:ej20 TXIC Private Classifieds 6 05-01-2010 12:24 AM
FS:(CO) STI rear end cover from 05' STI BishopCO Drivetrain 2 06-23-2009 10:34 AM
07 STI rear end (crossmember, trailing arms/lateral links, etc) into non-STI? silentt Brakes, Steering & Suspension 2 04-06-2008 11:58 PM
converting my 02 rear to 05 STi rear end vvafivv Interior & Exterior Modification 12 02-18-2007 02:51 PM
sti rear end gear oil ImprezaRSfan! Transmission (AT/MT) & Driveline 10 07-23-2004 07:31 PM
