Old 08-10-2009, 01:53 PM   #1
jasonhealy
Member#: 219894
Default having trouble splitting crank case halves
do i need to take the piston pin clips out to split the halves?
jasonhealy is offline   Reply With Quote
Old 08-10-2009, 02:28 PM   #2
ciper
Member#: 15543
90BJ Legacy LS ABS
AWD 946 Rio Red Jpn built
No you do not.
Old 08-11-2009, 02:55 PM   #3
crampfan
Member#: 74321
2004 wrx wag
black UTEC stg 4
you need to remove the wrist pins from the pistons or the pistons will bottom on the mains when the cases are split.
crampfan is offline   Reply With Quote
Old 08-11-2009, 04:07 PM   #4
yarrgh
Member#: 80465
2001 2.5RS
Black Diamond Pearl
Search! It's been covered. you do need to remove wrist pins, and if it's not splitting nicely, look for any missed bolts. You can try a rubber mallet against the bellhousing to try to "help" it separate. It has to be done evenly, the locating dowels don't take too kindly to anything but straight removal.
Old 08-11-2009, 04:37 PM   #5
Mechie3
Member#: 120152
Mechie3 is offline   Reply With Quote
Old 08-24-2009, 05:28 AM   #6
ttiimmff
Member#: 219575
And make sure to get all the bolts out. A few that may not be obvious at first are a couple in the back bell housing area, recessed in some ribbing, and a small bolt in the oil pan area.
ttiimmff is offline   Reply With Quote
IL: ej205 case halves evoboy88 Engine/Power/Exhaust 6 04-05-2010 10:56 PM
Sealing transmission case halves? kami333 Transmission (AT/MT) & Driveline 1 11-22-2009 03:29 PM
what do you use to clean the short block case halves methaddict Built Motor Discussion 2 06-03-2009 08:10 AM
Tranny case halve swap Feign Transmission (AT/MT) & Driveline 6 12-16-2008 11:34 PM
FS: *EJ22t Closed Deck Case halves Only* Sogonerg Engine/Power/Exhaust 7 06-25-2007 11:55 PM
