Notices
Old 05-03-2002, 01:51 AM   #1
DJ 9iron
Member#: 11349
2016 Mustang GT
Question BPM & Ludespeed
I have a few questions,
1. Does anyone know if a BPM turbo back system (prefer Twister) is compatible with a Ludespeed turbo kit?
2. What fitment issues are there?
3. How are they solved?
I don't have a kit yet, but when the time comes, I would like the BPM MkII. I just want to know if it will even work.
If it doesn't work, is there a Loud 3" turbo back system for the GC8 that you could recommend?
Thank you.
DJ 9iron is offline   Reply With Quote
Old 05-03-2002, 02:36 AM   #2
KillerTHC
Member#: 4942
01 SRP 2.5 RS-T
Ludespeed Stage 3 Link'd
if it bolts up to the stock cat, then it will work with the Ludespeed down pipe. the only issue we had (N1 not BPM) was that it was off by like an inch but we unhooked the exhaust and rotated it manually and then just stretched the hangers a bit.
KillerTHC is offline   Reply With Quote
F/S Ludespeed stg.3 turbo kit & ACT clutch wighti Tri-State Area Forum 6 10-07-2004 08:00 PM
Max Boost on Ludespeed kit & 2???? nativo Normally Aspirated with bolt-on Forced Induction Powertrain 3 09-23-2003 10:40 AM
BPM Twister MKiii Exhaust & O2 Sensor YonkerzImpreza Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 03-18-2003 11:49 PM
springs & struts r on the way! should I get new top mounts or BPMs? wighti Brakes, Steering & Suspension 5 05-08-2002 10:37 AM
Two Questions on LudeSPEED Turbo Kit: Strut Tower & Octane Grade bensonwrx Normally Aspirated with bolt-on Forced Induction Powertrain 23 04-28-2002 01:09 PM
