Welcome to the North American Subaru Impreza Owners Club Sunday April 26, 2015
Old 08-11-2009, 07:36 AM   #1
austria impreza
Member#: 96699
Default knock at low load?
Can anybody tell when our engines begin to knock at low load, when cruising at AFR 14.7? What is the normal ignition that our engines like there?
I have dialed in about 40, should I advance it a bit further?
Please let me know, your opinion!
austria impreza is offline   Reply With Quote
Old 08-11-2009, 04:20 PM   #2
Disaster646
Member#: 135382
02 6spd hybrid wrx
fpgreen+E85 ftw 7.5@95.7
what engine is this for? sti, wrx? 2.0? 2.5L?..
many sti run around 40-45 degrees or even more.. i have a 2.5liter with 2.0 heads and my timing while cruising on low rpms is around 42
Disaster646 is offline   Reply With Quote
Old 08-12-2009, 02:02 AM   #3
austria impreza
Member#: 96699
My engine is an EJ22t with STI V5/6 heads and forged internals, so I should be able to run about 43 at least.
Any other opinions and real life numbers?!
Old 08-17-2009, 09:58 AM   #4
austria impreza
Member#: 96699
bump!
Old 10-09-2009, 08:04 AM   #5
austria impreza
Member#: 96699
I observed something strange.
Took the car for some testruns onto the Autobahn and noticed, that I had some strange noise (seemed to sound like pinging though the detcans) at low throttle and cruisespeed at about 80mph, running about 42 IGN and AFR 14.5
Never noticed this noise when I drove with higher IGN (e.g. 45 at them same AFR)
Is it possible to be too retarded with ignitionvalues to make the engine unhappy???
Old 10-09-2009, 11:48 AM   #6
elevenpoint7five
Member#: 187798
04 2 liters of
AWESOME!
Yes it is possible, but keep in mind that RPM plays a roll in this as well, not just load. I have no idea what gearset you have, so no idea what RPM you were at, but just because load is low, doesn't mean RPM is.
elevenpoint7five is offline   Reply With Quote
Old 10-09-2009, 05:07 PM   #7
austria impreza
Member#: 96699
Sorry forgot to mention, I have a 6 speeder from an EU/UK STI in my classic and the rpm was at about 3000rpm and it was the same at low speed in 2nd and 3rd gear as well.
Might this be some noise from the hard engine- and gearboxmountings?
Old 10-10-2009, 01:51 AM   #8
NSFW
Member#: 140444
05 Stage Free LGT
ATP 3076, 6MT, AVO FMIC
The stock tune on my car ran 45 degrees at 3200+ rpm and .6 load, and 4800+ / .9 load. I have noticed a tendency for the ECU to detect knock when I drive in that area (low throttle, high rev) and then add throttle. I was turning it down a degree at a time until ride5000 said a couple days ago that he runs mid-30s in that corner of the timing table. So I dropped mine to 40 degrees, still got some knock, and just flashed a map with 38.6 degrees. Driveability is no worse, but I'm thinking about adding fuel now instead of subtracting timing, if the problem persists.
Old 10-10-2009, 03:22 AM   #9
austria impreza
Member#: 96699
Which engine do you have? I have got a 2.2l with forged internals.
I read the answer from Ride500 as well and wondered, because I never heared about such low IGN in the low load area...
Will try to lower it as well.
I also wonder if this "pinging" comes from the forged internals?!?
Old 10-10-2009, 02:25 PM   #10
NSFW
Member#: 140444
05 Stage Free LGT
2.5L, totally stock
Knock at low RPMs and load fenix-silver Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 13 05-17-2010 12:51 PM
knock logged at low load??? gto7419 Open Source Reflashes 24 10-10-2008 09:57 AM
is my car really detonating at low loads? WrXwaBBit AccessPort 1 06-01-2007 12:19 PM
High A/F at low load question (UTEC) z0s0 Engine Management & Tuning 0 01-25-2004 12:21 PM
Timing at low load/high RPM sites Kha0S Engine Management & Tuning 6 01-08-2004 08:34 PM
