Old 08-11-2009, 12:32 PM   #1
jeffdg
Member#: 220072
2004 WRX
"Arrest me" Red
Default clutch not disengaging, normal pedal
Not seeing these symptoms in the search...
The car: '04 WRX wagon, 63k mi, stock and original drivetrain. Even when driven spiritedly, I'm very gentle while shifting, never pop the clutch and never power shift, always rev match. Clutch has always grabbed well, no noticeable changes in friction point and no slipping.
The symptoms: Clutch pedal feels fine, totally normal. I can see no evidence of fluid on the master or slave cylinders. If the car is off, I can change gears. If I start the car (in neutral), I can not get the car into gear. If i put the car into 1st gear (while off) and start the car, the starter will 'drive' the car. Okay, so the clutch isn't releasing despite a normal pedal feel. Finally, when the car is idling in neutral, there are no 'new' or 'extra' noises and no changes in sound when the clutch is pressed.
The story: Trip to VA this past weekend, no incidents, just a normal road trip. As I was pulling into my driveway (oh the luck in timing!) as I got home (steepish driveway) I was going too slow to make it all the way up in 2nd. So as I rolled to a stop (and before rolling backwards), I shifted into 1st and went to accelerate, the car revved up and chirped as I let off the clutch - I don't recall having botched it and was surprised by that. As I parked the car, I had a hard time getting it out of gear... basically, whatever happened, happened right then.
Please help. What is the likely culprit here?
Thanks a lot! -Jeff
jeffdg is offline   Reply With Quote
Old 08-11-2009, 09:55 PM   #2
jasv11
Member#: 117862
2006 STi [email protected]
96 impreza 9.55e.t.146mph
it sounds like you broke a chunk of clutch material off the clutch and it has gotten wedged between the clutch and the flywheel.
Or you welded the clutch to the flywheel but \i have never heard of anyone doing this with a stock clutch before.
I have had what your describing happen to me twice but with a act 6 puck clutch under agressive launches while slipping the clutch exesively.
jasv11 is offline   Reply With Quote
Old 08-11-2009, 10:36 PM   #3
jeffdg
Member#: 220072
2004 WRX
"Arrest me" Red
hmm... interesting. I see what you're saying, but I only had it at maybe 1/4 throttle, just didn't catch where i thought it would. Just seems like a very small incident for this to happen. such a mystery!!
Old 08-12-2009, 01:54 PM   #4
jeffdg
Member#: 220072
2004 WRX
"Arrest me" Red
Default master/slave cyl appear fine
Okay, so I had someone come over and push the clutch pedal a few times, and I can see the slave cylinder doing its thing beautifully...
Other thoughts??
Thanks.
clutch not disengaging! ride918 Transmission (AT/MT) & Driveline 33 02-25-2015 06:39 PM
Clutch not disengaging Douginss Transmission (AT/MT) & Driveline 0 05-23-2007 03:24 PM
Clutch not disengaging? ezoq Transmission (AT/MT) & Driveline 3 07-02-2006 03:14 AM
Help, clutch will not disengage BADWRX Transmission (AT/MT) & Driveline 4 08-20-2002 02:56 AM
Clutch will not disengage?! dead-eye Transmission (AT/MT) & Driveline 10 09-22-2001 01:27 PM
