Welcome to the North American Subaru Impreza Owners Club Saturday February 6, 2016
Closed Thread
Old 08-11-2009, 04:18 PM   #1
TEK112
Member#: 218140
2009 WRX Prm Sed DGM
Know my friend Hiram?
Default 09 WRX turboxs CBE.....anything else needed?
I was going to put the SPT exhaust on my car, because I know there is no tune needed, it comes factory if you want it.
Does anyone know personally about the turboxs CBE?
Can I run it on a stock engine without consequence?
Any help is greatly appreciated.
TEK112 is offline
Old 08-11-2009, 05:26 PM   #2
08EJ25
Member#: 174022
2008 WRX
Lightning Red
You can run any CBE, they are typically only noise makers. You will get some power, but the noticable power will come from a DP and tune.
08EJ25 is offline
Old 08-26-2009, 11:50 PM   #3
SnakeFart
Member#: 217632
2009 Impreza WRX
Dark Grey Metalliac
I actually just got mine in today and installed it. Some small fitment issues but nothing to call up the company and complain.
I took off the stock cbe and laid it side by side. The sheer size difference and weight of the muffler its insane. The stock muffler weighs as much as the complete txs cbe.
Mounting. Hung the muffler first to see how it lined up. Its perfect. Loosely bolted the new piping together, then ran into 3 problems.
1: The Pipe is so large now it actually sits against the heat shield under the drive shaft/shift linkage.
2: The stock mating flange at the cat has a different size hole drilled than on the stock cbe than on the downpipe. I had to either drill the hole bigger or tap the hole to thread the bolt thru and then back it up with a nut. I did the latter.
3: The stock mating flange just behind the cat has a large bevel to it so the new pipe wont sit "flush" but when bolts are tight, no "air movement" is coming from the connection. (tested with a smoking piece of paper)
Looks pretty good and sounds great. A little rumble at idle and talks to you when your driving "sporty"
SnakeFart is offline
Old 08-27-2009, 02:31 PM   #4
JohnnyG
Member#: 164671
2009 WRX 265
Does your license plate say "SNAKE FART?"
JohnnyG is offline
Old 08-27-2009, 04:41 PM   #5
kwiksilverwrx
Member#: 221150
09 WRX
sparkling silver
hahahaha interesting
kwiksilverwrx is offline
Old 08-27-2009, 04:49 PM   #6
JDHolliday27
Member#: 208688
09 GH
I also have the TXS CBE on my 09. Ran into similar problems but luckily my good friend works at TXS. Helped me with the install and was done in about 25 minutes. I ended up completely removing the heat shield because there was some rattling due to the pipe rubbing against it. Sounds great has a nice rumble and plan to add their downpipe and midpipe here soon.
JDHolliday27 is online now
Old 08-27-2009, 11:35 PM   #7
SnakeFart
Member#: 217632
2009 Impreza WRX
Dark Grey Metalliac
Yep the plates stands for SnakeFart. In texas we only get 6 characters to use. It was the best way I could spell it.
Can't wait to get me a bellmouth downpipe... ill look for the txs version if they make it. Do they?
Old 08-27-2009, 11:35 PM   #8
SnakeFart
Member#: 217632
2009 Impreza WRX
Dark Grey Metalliac
Also I was suggested not to remove the heatshield due to a possible problem with a soft rubber bushing on the shift linkage. Not sure it that problem was addressed but it still concerns me.
Old 08-31-2009, 11:11 AM   #9
TEK112
Member#: 218140
Thanks for the info guys. I'm not liking the fit and finish of this product too much. These are the concerns I have that only the fine people at NASIOC can answer. So, I guess I'll keep looking. I may just do an SPT exhaust and be happy with myself. No fitment issues, but less burble.
TEK112 is offline
Old 08-31-2009, 11:56 AM   #10
howweirdo
Member#: 186257
2015 WRX Premium
CBS
sorry, dont mean to hijack the thread. i also have a turbo xs cbe that makes an incredible amount of rattle on a cold start. does removing the heat shield cause any problems?
OP, i've had the spt cbe and i am much happier with the turbo xs. its louder but not overwhelming and it doesn't hang low to the ground. just fyi... good luck.
howweirdo is offline
Old 08-31-2009, 01:58 PM   #11
WrxRcr
Member#: 218050
2009 Wrx sedan
Heat shielding is probably your problem howwierdo, you can remove it with very little consequences. Or you could just try bending it away from the contact points. Also you might want to check your hangers to make sure the exhaust is seated properly.
WrxRcr is offline
Closed Thread
Best Priced Accessports!! Turboxs Aem Anything You Need!!! BEST PRICES BY FAR!! DNA Motoring Engine Management 96 07-13-2010 02:36 PM
Feeler: 08-09 WRX SPT CBE Zordos VIC Private Classifieds 3 08-18-2009 05:34 PM
FS PDX: Stock 09 WRX wagon CBE osuRexWagon NWIC Private Classifieds 0 08-13-2009 12:29 PM
5th Gear Fork Broken - Anything Else Need Replacement? dimunation Transmission (AT/MT) & Driveline 5 11-27-2006 12:46 PM
Adding VF34 to stock 04 STi, anything else needed? adamnquickcivic Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 37 02-20-2005 06:00 PM
