#1 |
Member#: 209633
RMIC
Vehicle:2002 wrx silver |
So i was driving yesterday and my temp gauge went above the red line for hot so i stopped checked all my fluids my coolant was full along with all the other ones. so what is causing me to over heat so bad.
i have an 02 bugeye with 114000mi cai intake uppipe tbe i just recently unmarried my accesport could this be causing it? or could it be my thermostat failed? thanks aaron
#2 |
Member#: 170212
RMIC
Vehicle:02 WRX Sedan MBP |
have you done the 105k service?
and it could be a few things could be a clogged radiator, could need to flush your system, could be your thermostat or it could be your engine is messed up and is actually overheating PS. no, unmarrying your AP will not do this |
#3 |
Member#: 171448
RMIC
Vehicle:2003 wrx psm |
if your car was in the red how did you check ur coolant? it would have sprayed everywhere if it had the correct amount in it. check it when its cold
#4 | |
Member#: 170212
RMIC
that gets me to thinking....you arent just checking your overflow are you? the overflow is the one right next to the radiator, the actual coolant resevoir is up next to the engine |
#5 |
Member#: 93992
RMIC
Vehicle:'06 EVO MR, '89 240SX, '07 Yaris |
#6 |
Member#: 209633
RMIC
#7 |
Member#: 209633
RMIC
the resevoir is completley full still
#8 |
Member#: 164437
RMIC
Vehicle:EVO IX - Track Car 2.5RS Coupe - Daily |
check the level in the resevoir and also the radiator itself.
#9 |
Member#: 43128
Vehicle:92 RWD, 96 FWD 05 AWD |
#10 |
Member#: 92372
RMIC
Vehicle:2008 Black on Black |
and if they are both full, Im going to go with clogged radiator or thermostat.
#11 |
Member#: 209633
RMIC
would this also cause a leak if the overflow resevoir is to full because i have antifreeze leaking but i cant tell where and it only leaks after the car is overheated
#12 |
Member#: 164437
RMIC
holy triple post haha. if the overflow reservoir if overfull, when the car is overheating (unrelated) it will push coolant into the overflow, but if it's already full then it will just overflow.. the overflow. i think that makes sense? that reservoir wouldn't have an impact on the overheating issue though. i'd check your thermostat first.
#13 |
Member#: 209633
RMIC
i know on the triple post i pushed it like 5 times haha but i am pretty sure its the thermostat because if it was still working with as many leaks as i have had everything would be empty and they are full
#14 |
Member#: 209633
RMIC
all the coolant is draining now to just remove everything
#15 |
n00b Moderator
Moderator Member#: 99397
RMIC
Vehicle:'13 BRZ, '13 STi SRs13 '83 Skyline '93 GTR |
get a leakdown test done. maybe its your head gasket.
#16 |
Member#: 92372
RMIC
I thought about a head gasket too, but the coolant would look like a chocolate milkshake and/or he would be burning coolant and his exhaust would smell sweet from burning the glycol in the anit-freeze.
#17 |
n00b Moderator
RMIC
not always. a lot of the times the coolant can leak into the oil.
Also make sure your fans are working as well. I had a fuse blow before. |
#18 |
Member#: 209633
RMIC
my fans work and nothing is burning at all the problem now is that i snapped one of the two thermastat bolts in half so its stuck in there i gotta go roto extracto style
| Thread Tools | |
| Display Modes | |
| Help me pick a Head unit for the little lady... | nperkins | Car Audio, Video & Security | 10 | 06-04-2010 05:50 PM |
| Help Me, Help Me, Help Me! | againstdan | Newbies & FAQs | 9 | 11-11-2005 10:26 PM |
| I need to get a sound clip from ATHF... help me Obi W... I mean help me OT! | Asinine | Off-Topic | 7 | 03-03-2005 12:33 PM |
| Help Me! Help Me Please! | wrxxxappeal | Factory 2.0L Turbo Powertrain | 8 | 05-10-2003 11:14 AM |
| Help me/Help YOu/Help ME | MichiganRS | General Forum Archive | 7 | 12-15-2000 08:54 AM |
