Old 08-11-2009, 09:38 PM   #1
boosted lego
Member#: 218987
1998 gc8 coupe
white
Default cam gear bolts, crank bolt stuck
(working on an ej25) ive been trying to get the cam bolts off to remove the cam gears off and also the crank bolt, so far ive only gotten one cam bolt off (when i use the breaker bar on the cam bolts the timing belt just slips under pressure), ive used an impact gun and breaker bar but nothing is really working, any good tips on how to get them off?
boosted lego is offline   Reply With Quote
Old 08-12-2009, 12:22 AM   #2
92SVXMAN
Member#: 77834
1992 SVX
Claret
Cool Ther is a tool for that
It has 2 finger like things that hold the cam drive from the timing belt, which hold the drive so you can brake the bolt loose. As for the crank bolt I go with the breaker bar on the bolt under the car, and then hit the starter ( don't start it just the shortest hit it will break it loose).
92SVXMAN is offline   Reply With Quote
Old 08-12-2009, 02:05 AM   #3
boosted lego
Member#: 218987
1998 gc8 coupe
white
what has 2 finger like things that hold the cam gears? and the engine is out of the car so breaking the crank bolt by starting it isnt an option
Old 08-12-2009, 10:04 AM   #4
AndrewtechAutomotive
Member#: 99694
2002 dogbox,'11 wrx
It is not uncommon to have to cut cam bolts off.
I like the starter trick with the crank bolt. Works like a charm.
I don't think this is a drivetrain question.
Phil
Andrewtech Automotive
AndrewtechAutomotive is offline   Reply With Quote
Old 08-12-2009, 02:19 PM   #5
ciper
Member#: 15543
90BJ Legacy LS ABS
AWD 946 Rio Red Jpn built
If you have a junk timing belt you can use it to make a cam holding tool. Cut it, drill a hole about 1 inch from the end and then 5 inches from the end and run a bolt with washers through it to make a loop. Put this loop over one of the idler pulleys and wrap the other part of the belt around that cam, shoving a little extra underneath the belt after a full wrap.
Worst case just remove the cam from the engine and remove the gear in a vice. Ive never had to cut one off.
Old 08-19-2009, 06:31 AM   #6
Imaudi
Member#: 202084
you cant get the cams out without removing the cam gear.
Imaudi is offline   Reply With Quote
Old 08-19-2009, 10:04 AM   #7
Member#: 99694
2002 dogbox,'11 wrx
That depends on which side of the motor you are talking about.
I know more about transmissions than I do about motors, but I seem to recall that you can remove the drivers cams with the gears installed, but not the passenger side cams (at least on some of the cars).
Seriously, the easiest way is to cut the head off the cam bolt, pull the gear off, then pull out the rest of the bolt. Replace the bolt with a new OEM one, and call it a day!
Phil
Old 08-19-2009, 05:27 PM   #8
PSolbergfan
Member#: 112612
2010 Legacy 2.5 CBS
2002 Impreza WRX WRB
I'm going to assume it's DOHC engine. Remove the valve covers. The cams have hex's cast into them. The hex is located close to the cam gears underneith the valve covers. Hold the cam on the hex with the wrench( I' don't remember what size it is) and use a breaker bar on the cam bolt. You'll need to figure out a cheater bar for the wrench. I have a peice of oval shaped tube that I use. This useally works for me. If you strip out the cam bolt head just drill it out and there should be enough shank to get a vise grips on and remove the theaded section. Just drill enough to break off the head!
PSolbergfan is offline   Reply With Quote
Old 08-19-2009, 05:30 PM   #9
PSolbergfan
Member#: 112612
2010 Legacy 2.5 CBS
For the pulley bolt I have an old section of timing belt that I use to wrap around it. I then use a wrench to grip it. Works for me every time. When you re-install the bolt don't forget to apply engine oil on the threads and seat.
Old 11-20-2010, 03:51 PM   #10
unkachabull
Member#: 241491
2005 wrx
v7 ej207- stimikey tuned
Do you need to remove the motor to drill out the bolt? how do you get enough room for that? please explain im in this situation right now and this is my daily driver and if i need to pull the motor i will but i really dont want to have to.
unkachabull is offline   Reply With Quote
Old 11-20-2010, 04:40 PM   #11
Storm
Member#: 5218
96L Most Over-
Developed Beater
Depends on what kind of drill you have. More than likely, you'll need to pull the motor to do this correctly. You're going to have to step up to a 1/2" drill bit....and the bolts are hardened. Last time I did this on an 06 WRX motor, we went through 3 or 4 bits....just burning them up.
Old 11-20-2010, 05:08 PM   #12
Jessekrs123
Member#: 236927
2015 BRZ, 93 Legacy,
1984 BRAT
If you have the motor out of the car, just have somebody stick a crowbar or something similar into the flywheel to keep the crankshaft from moving. That's how I got my crank sprocket out when I noticed the key notch thing was all chewed up. (This took like 2 hours of wiggling and spinning to get it out)
If the motor is in the car, put it in gear and have someone on the brakes just in case. It's pretty hard to spin the engine when it's in gear and someone is on the brakes.
Jessekrs123 is offline   Reply With Quote
Old 11-20-2010, 08:21 PM   #13
unkachabull
Member#: 241491
2005 wrx
Well i ended up dremeling the head of the bolt off. took about 1 1/2 hours and all my cutting bits but its off... also was wondering is there is any common oil leaks on wrx. i have oil going onto my timingbelt but i see oil at one of the cam shaft seals as well as around the tensioner... im replacing the camshaft seals and if anything ill jsut take it all apart. just wondering for heads up on what to look for.
Old 11-21-2010, 12:03 PM   #14
Storm
Member#: 5218
96L Most Over-
Developed Beater
Hey, you thought to buy some replacement bolts, right?
Common leak spots would be the cam seals and the front crank seal. Since you see oil residue behind the tensioner, I would suspect the piston pin acess cover or the tensioner itself, but you won't know until you take things apart to find the source.
Jay
Old 11-23-2010, 08:33 AM   #15
Turn in Concepts
Member#: 93646
Many Track Records
Let us help you go fast!
You want these. They make removing those bolts much easier.
Old 04-05-2011, 01:54 PM   #16
g_julius
Member#: 274013
2013 Sti
Oo0, where at and how much?
g_julius is offline   Reply With Quote
Old 04-13-2011, 10:11 PM   #17
white guys wrx
Member#: 223316
2005 STi
& 02 WRX
Hmmm I need too lol
white guys wrx is offline   Reply With Quote
WTB 02 wrx left exhaust cam gear and crank timing gear 316 honda tech Private 'Wanted' Classifieds 0 03-30-2010 08:45 AM
Crank Pulley Stuck- NOT Crank Pulley Bolt SubieNOVA Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 20 01-23-2008 12:36 PM
Crank pulley bolt/Cam gear bolt Starkiller Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 06-17-2007 01:55 PM
stuck cam gear bolt... jbwrx Built Motor Discussion 12 01-28-2007 07:45 PM
Cam gear bolts always a pita kaos200 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 06-13-2004 07:58 AM
