Old 05-03-2002, 11:04 AM   #1
scoobyguy
Member#: 18374
2002 2.5RS
Blue Ridge Pearl
Post How to install Unorthedox Pulley kit
What tools are needed to remove the crank pulley on the Ej25?
I had heard some where that that it is pressure fitted but I don't want to take it to the shop to have it done.
scoobyguy is offline   Reply With Quote
Old 05-03-2002, 11:14 AM   #2
jeffg
Member#: 2958
2001 6.0?RS
The Crank Pulley is held on by a single bolt, and a keyed area. It is fairly easy to remove and install the new one. No need to take it to a shop.
1. remove the radiator overflow bottle (bolts on top)
2. remove the radiator fans (bolts on top, tabs on the bottom)
3. Make sure you unplug the fans before you pull them out.
4. remove the alternator and AC belts. There are 2 adjustment bolts. Loosen and remove the belts.
5. Get a 22mm? socket and place it on the end of the longest breaker bar you can find 1/2" drive recommended. put some pipe on the end of the breaker bar.
6. get a friend to sit in the car. place the car in 4th gear, and hold hte brakes down.
7. Loosen the crank pulley bolt. Just keep trying, I think the factory torque spec is like 140lbs/in.
8. Install is the reverse of above. Make sure you plug the fans back in.
jeffg is offline   Reply With Quote
Old 05-03-2002, 02:35 PM   #3
Stealthbmbr
Member#: 13823
2009 Legacy 2.5i SE
C A P S CAPS CAPS CAPS
I removed the overflow bottle and nothing else. Put the socket on the nut and turned motor till the breaker bar rested on top of the frame rail next to the battery. Then have someone bump the key. DO NOT start the motor. No strain on your back at all.
Stealthbmbr is offline   Reply With Quote
Old 05-03-2002, 02:40 PM   #4
scoobyguy
Member#: 18374
2002 2.5RS
Blue Ridge Pearl
I tried option one. Work just fine plus it will help me when i go to install a large capacity radiator, thanks for all the help.
Old 05-04-2002, 09:18 AM   #5
Stealthbmbr
Member#: 13823
2009 Legacy 2.5i SE
Any time.
Question How to install grounding kit? sti-bullet Vancouver Impreza Club Forum -- VIC 4 03-24-2006 01:28 PM
How to install brightstar HID H1 kit in 2002-03 EDM/JDM projectors file_id Electrical & Lighting 0 04-19-2004 12:34 AM
GFB pulley kits, pros and cons and how to install Imprezanize Normally Aspirated Powertrain 1 04-06-2004 10:39 AM
Instruction on how to install Perrin Pulley? WRXVII Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 12-09-2002 12:30 PM
Who knows how to install the C-west WRX Kit? Gypsum2 Interior & Exterior Modification 0 11-05-2001 10:58 PM
