Old 08-12-2009, 11:08 AM   #1
Turn in Concepts
Member#: 93646
Many Track Records
Let us help you go fast!
Default Any aero engineers on here?
I have a question I can't seem to find the answer to, and I'm hoping someone can help me.
Let's say I have a wing shape. We'll keep it simple in terms of the shape - one side flat, one side curved.
Now, lets say I have a way of artificially injecting a stream of air so the wing sees more flow than just being pushed through the air while attached to the car.
My question is this - what side of the wing would I want to inject the air on to to see a greater drop in pressure along the curved surface?
Supplementary question would be as follows -
Would it be best to inject the air into the stream along one surface of the wing or would it be best to inject the air in front of the wing and let it do it's thing as is?
Old 08-12-2009, 11:26 AM   #2
racerjon1
Member#: 43612
I think there are some discussions and tests on this in the right places..
Jon
racerjon1 is offline   Reply With Quote
Old 08-12-2009, 11:32 AM   #3
saintsfan1483
Member#: 210651
2012 WRX 5door
PBP (RIP 09 SWP WRX)
First of all, the velocity of the air is going to be just as important as the volume your putting out (Reynold's Equation). Im not sure what the application in this case is but if your trying to increase downforce across a wing or air splitter like on an STi you usually tweak the angle of attack and redesign the air foil's shape (chord length, AR, coeff of drag of surface materials). You would increase your fluid volume, in this case air, by going faster. Although it would be pretty impractical in the case of a Subie, blasting a jet of air at a higher velocity (much higher to see any real difference) than the air naturally moving over the wing would increase its downforce. The air jet would have to evenly distribute the air or you risk compromising structural integrity. So short answer long, yes this would work but it would be very impractical.
saintsfan1483 is offline   Reply With Quote
Old 08-12-2009, 11:34 AM   #4
TopSpeed
Member#: 78884
Go faster
at TopSpeed
Might be some useful info here, we had thought about using similar ideas but scrapped them.
http://www.wikipatents.com/6109565.html
Doug
TopSpeed is offline   Reply With Quote
Old 08-12-2009, 11:36 AM   #5
FromageTheDog
Member#: 81095
2005 WRX sedan kid-
bus. OS self-tuned!
Based on the wording of your question, I suspect you know the answer already.
The short answer is, inject the air at the leading edge such that the accelerated flow travels over the curved section. By speeding up the flow, you drop the pressure, and bingo, more lift (downforce depending on orientation of the wing).
Just run a search on "incompressible Bernoulli equation" to be able to do your own back of the envelope stuff. How you inject that flow without disrupting the existing flow and killing your lift is an interesting engineering problem. You'd at a minimum want some separate device placed ahead of the leading edge of the wing doing your flow injection for you.
What you're talking about, by the way, is powered lift via the Coanda effect. This takes enormous amounts of energy input to produce any really meaningful benefit, so if this is for a racecar, I daresay your time and money would be better spent on other things...
Another interesting approach is active sucking to keep the flow attached at angles of attack beyond the stall limit of your airfoil. The drag penalty here would be huge, though.
FromageTheDog is offline   Reply With Quote
Old 08-12-2009, 11:37 AM   #6
racerjon1
Member#: 43612
Doug
^^^ You can tell the people who have already been thinking in this direction...
Old 08-12-2009, 11:39 AM   #7
Turn in Concepts
Member#: 93646
Many Track Records
Lets say that length, pitch, and chord are all fixed, and cannot be changed.
Lets also say that I just happen to have some extra air that right now is just being dumped outside the car. The air is going to be dumped regardless as there's no choice in the matter, but I'm wondering if there's any way that I can use this air to enhance the flow over a wing so that it sees more than just the air that's pushed over it by the car moving forward.
As for impractical - that's what I'm trying to figure out. Given that I have no choice but to dump this air any gain in flow over a wing, no matter how small would be a benefit.
Old 08-12-2009, 11:40 AM   #8
Turn in Concepts
Member#: 93646
Many Track Records
Jon
Hey Jon - problem is I don't know those places. I tend to be a loner on odd stuff like this.
Old 08-12-2009, 11:40 AM   #9
racerjon1
Member#: 43612
There is info on this out there.. see PM.
Jon
Old 08-12-2009, 11:41 AM   #10
Turn in Concepts
Member#: 93646
Many Track Records
Doug
Thank you for the link. I'll check it out.
Old 08-12-2009, 11:44 AM   #11
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
If you are just looking to dump air in a manner to help air flow or downforce; I'd place it at the base of the rear window/trunk in manner flowing along the trunk lid.
Been discussed and I actually kicked this idea towards Doug last summer when he had mentioned some Chapparal'esque aero ideas...but the sucker setup never came to being for whatever reason...
I know in the windtunnel we had done similar testing (just cockpit flow, not pumped air from undertray) on 1/4 scale models but never test any in either full scale tunnel.
My concern with injecting the high speed air at the front of the wing (in attempt to make a change in downforce) would be if you'd stall the wing. Testing and getting results for this in the real world would be rather difficult and would require pressure sensors or some pitot tubes.
Old 08-12-2009, 11:45 AM   #12
leecea
Member#: 37359
2003 WRX
leecea is offline   Reply With Quote
Old 08-12-2009, 11:48 AM   #13
samophlange
Member#: 215590
2009 WRX
Dark Grey Metallic
I'm not an aero engineer but when I was growing up I read tons of books on airplanes since aviation ran in my family. So... I don't know what the hell I'm talking about, but its an interesting question to ponder. From what I remember, the design of an aircraft wing is such that (oversimplifying here) the top is curved and the bottom is flat. This makes the path of least resistance the bottom of the wing, so more air passes under rather than over which leads to greater air pressure under the wing and therefore lift. Obviously on a modern aircraft they get a lot fancier, but if you look at the cross section of a wing of a simple R/C plane it's easier to see what is going on. I assume wings on a car work similarly, but upside down and are designed to take into account the airflow around the vehicle body.
Now, specifically WRT your question, I'm not 100% sure what you mean. My guess is that the best approach is to work with the wing within the system it is designed to function, and increase the amount of air hitting the leading edge (and decrease the amount of turbulence if possible). Trying to turn the wing into something like a lever by directly applying an air stream perpendicular to the surface seems like trying to use one tool for another tool's function.
This is an interesting question, I'm looking forward to an answer from somebody who actually knows what they're talking about.
..and by the time I finish my long winded reply, other folks are posting the real info.
Last edited by samophlange; 08-12-2009 at 11:50 AM. Reason: I need to do more reading and less yapping
samophlange is offline   Reply With Quote
Old 08-12-2009, 12:03 PM   #14
leecea
Member#: 37359
2003 WRX
The top path is longer because of the curve, resulting in a higher speed airflow, dropping pressure and hence giving lift. It's not because there is more air.
Angle of attack also comes into play, until the airflow breaks away from the wing and causes a stall. Some air "injection" mechanisms (slats are common) try to reduce the breakaway by 'injecting' air along the top surface, to allow for higher angles of attack. I have no idea if that would help on a car.
I did find some links to powered high-lift designs using air bled off the engines, but again, I have no idea if that's helpful.
BTW, I'm not an aero engineer either.
Old 08-12-2009, 12:07 PM   #15
Mechie3
Member#: 120152
Some fighter jets used to employ a tactic with holes on the top of the wing surfaces. By pulling a vacuum on the wing using venturi's you could essentially pull air from the top of the wing and dump it out the back. This resulted in reduced top pressure. Invert this idea for down force.
Mechie3 is offline   Reply With Quote
Old 08-12-2009, 12:44 PM   #16
573
Member#: 144821
1994 LS1 Miata
2015 white WRX
If you have air that will be blowing out of the car, wouldn't you get more down force from blowing the air upward, or maybe up and back, than you would from blowing it horizontally over a wing? The wing idea seems less efficient because the air is indirectly gaining you down force, where as if it were just blowing upward, it would directly increase down force.
That's just my thought on it. I graduated from HS earlier this year, so I don't have any training in this area.
573 is offline   Reply With Quote
Old 08-12-2009, 12:57 PM   #17
Turn in Concepts
Member#: 93646
Many Track Records
That would work great, but I don't have THAT much air to push, and figuring out how to push it out and an appreciable pressure over a large surface area would not be possible.
Old 08-12-2009, 01:52 PM   #18
Homemade WRX
Member#: 33782
96 bastard child
I still say fill that turbulent zone directly behind the back glass. I should also help direct more flow to the underside (trunkside) of the spoiler...which should have an effect on the air coming off the roof as well, potentially helping to direct airflow much like the spoilers found on 06-07 sti's and VG's on the evo...
Old 08-12-2009, 02:08 PM   #19
PitwrkzZ1
Member#: 94316
You also have to think that at a certain velocity, the volume of air naturally flowing over the wing may exceed the volume of "pushed" air...would this be harmful at higher speeds? It may cause a lower pressure were the natural high velocity air and the "pushed" air meet so that you don't have the most efficient airflow over the wing...or not, haha just something to think about. If this problem exists it would be pretty easy to fix anyways. Just block the airflow at the velocity were it becomes detrimental to flow...
Its a good concept. F1 cars used to do something similar by routing exhaust flow under the car through the diffuser and accelerating flow.
PitwrkzZ1 is offline   Reply With Quote
Old 08-12-2009, 02:46 PM   #20
strong_auto_concepts
Member#: 83716
'04 Burn-Up WRX
F1 uses exhaust flow out the back of the car in concert with the flow coming off of the rear diffuser. I think they're using it more as a flow shaping tool that an "air injection" device though. I had an article on it somewhere and some pictures.... I'll have to dig. I know I've got some close-ups of the 06 Redbull car's rear diffuser.
strong_auto_concepts is offline   Reply With Quote
Old 08-12-2009, 03:11 PM   #21
Turn in Concepts
Member#: 93646
Many Track Records
There was something recently in Racecar Eng. about this and how some teams were protesting another team's exhaust tips coming out above the body work.
Old 08-12-2009, 03:33 PM   #22
Member#: 83716
'04 Burn-Up WRX
yeah, I'm not sure if they've changed the rules since, but '06 has this going on for sure. Pictures are on the home computer unfortunately, but I'll post tonight.
If whatever you're working on has a diffuser you may see better results working there rather than the top wing. I'm going completely on the fact that we're talking exhaust flow here. To be perfectly honest, I don't think you're going to see returns either way, but it's an interesting exercise for sure.
Old 08-12-2009, 03:42 PM   #23
grippgoat
Member#: 62182
2005 STI
I wonder if a 600hp turbo engine would move enough air to put the intake under the car and use the engine as the sucker fan. I guess that wouldn't work too well, since you'd have to be full-throttle through the corner to keep your downforce. I suspect a similar problem would arise from trying to use exhaust to increase downforce.
The more useful strategy would probably be to try and use exhaust to reduce drag.
-Mike
grippgoat is offline   Reply With Quote
Old 08-12-2009, 04:03 PM   #24
Member#: 83716
'04 Burn-Up WRX
Look at the size of the fan on the Chaparral fan car. Turbo inlet isn't gonna do any good in that aspect
Old 08-12-2009, 04:09 PM   #25
Homemade WRX
Member#: 33782
96 bastard child
We studied a few cases where such things had been introduced in attempts for downforce and were trying to inject the exhaust right at the break between the undertray portion and the rear venturi. It had reduced downforce by filling venturi volume. They since moved it up to help shape the backlight angle of the car....then again this was also 4 years ago on an F1 car with released data.
I'm going to guess that they had exhaust breaking some minor rule in an attempt to use the exhaust for downforce...but then again, I'm spectulating.
or reduce drag and increase downforce at the same time
Any software engineers in here interested in an API? Coolingmist Water/Methanol Injection, Nitrous & Intercooler Cooling 1 04-18-2006 01:40 PM
Are there any other engineers in here? StiChiara Off-Topic 24 03-14-2006 01:48 PM
Any Biomedical Engineers on here? Deus ex Machina Off-Topic 4 11-11-2005 08:57 PM
any network engineers/architects here? g0tb00st New England Impreza Club Forum -- NESIC 14 11-03-2005 08:24 PM
Any auto engineers over here? wrxsubaru Mid West Subaru Owners Club Forum -- MWSOC 16 10-04-2004 09:42 AM
