Go Back   NASIOC > NASIOC Subaru Models > Baja Forum
Old 08-12-2009, 08:32 PM   #1
texwr1889
Member#: 139147
2004 WRX
Default Tunning help
Hey guys Cobb has my baja and they are trying to tune it, but have run into a problem with the fuel system. I was hoping someone here could give me their tuners information so I could have them get in touch with Cobb to help them, or at least give insight. They have had the car almost two weeks! If anyone could help me out it would be much appreciated.
texwr1889 is offline   Reply With Quote
Old 08-15-2009, 11:11 AM   #2
Pursuit
Member#: 38370
More info on your baja and the problem they're having? There's nothing tricky about any of the bajas' fuel systems, nothing Cobb won't have seen before on other Subes I mean.
Pursuit is offline   Reply With Quote
Old 08-15-2009, 11:33 AM   #3
twheats1
Member#: 147722
11 Rug
00 R 1100RS
Last edited by twheats1; 08-15-2009 at 11:35 AM. Reason: Thought you had a Baja, not aWRX
twheats1 is offline   Reply With Quote
Old 08-15-2009, 05:54 PM   #4
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
Silver Sleeper Wagon
Which COBB location?? SLC, Plano or PDX?????
I can't imagine any of the 3 would be unable to figure your issue out.
Have you tried posting in the COBB forums??
Old 08-15-2009, 08:39 PM   #5
twheats1
Member#: 147722
11 Rug
00 R 1100RS
I'm confused. Your profile shows you own a WRX. You are asking about a Baja. Which vehicle is yours?
If IIRC the tuning options for Baja's are ECUTEC, Open Source, and the Dastec tuning chip. I didn't realize Cobb made an Accessport for Bajas.
Old 08-28-2009, 08:23 AM   #6
BajaSleeper
Member#: 186725
2006 Baja Turbo
My tuner had to update my rom in order to tune my baja. Maybe that might help? He did OpenSource for mine.
BajaSleeper is offline   Reply With Quote
Old 08-28-2009, 08:25 AM   #7
BajaSleeper
Member#: 186725
2006 Baja Turbo
Im pretty sure they don't make an Accessport for Bajas. I heard they haven't been able to crack the Baja ECU yet.
OP - Let me know how it goes! I'd like to know how good Cobb tunes the Baja! :]
Old 08-28-2009, 04:55 PM   #8
Benhart21
Member#: 149617
They don't/never did. That's why I bought an 04 STi ECU and the AP to go with it.
Benhart21 is offline   Reply With Quote
Old 08-28-2009, 06:16 PM   #9
twheats1
Member#: 147722
11 Rug
00 R 1100RS
I'm running an Open Source tune as well.
Old 08-28-2009, 11:54 PM   #10
Subie_Sleeper68
Member#: 166403
2006 Baja Turbo
Silver 340 AWHP 365 AWTQ
www.turboxs.com guys. Utec Delta is a plug and play piggy back system AND they have one that has the Baja listed on its compatability list. I'm currently running a new FP 68HTA (love it!) 740 cc injectors and all the major supporting mods. It dynod 283 and 327 in a 100 degree shop with 98% humidity and stock iridiums with 45 k on them (WOOPSIE!) I'm going to go with a catless DP and different intake. SPT short ram is great for heat soak. Back to the Utec Delta. It has knock sensing (blinks the CEL if it detects knock AND pulls timing) launch control and an optional remote map selector switch with 5 user maps ( like 93 91 E85 gas&meth and a SAFE map) plus valet mode so nobody can whoop on your ride but you and an engine kill mode. COBB failed me miserably when I was trying to get an answer if a FXT AP would work. TurboXS made a map and then listed the Baja as a platform they support. Good Luck. If you call them (they're in Gaithersburg Md) ask for Germain, he's the head tech / tuner
Subie_Sleeper68 is offline   Reply With Quote
Old 08-29-2009, 01:10 PM   #11
Dave G
Member#: 4738
2006 Baja Turbo
Is all of that on your 2006 Baja Turbo?
Dave G is offline   Reply With Quote
Old 08-29-2009, 10:50 PM   #12
Benhart21
Member#: 149617
Almost $1100 for the UTEC? Ouch. I've got just over half that invested in the parts I mentioned, and if you factor in the 850cc injectors I picked up, about $300 or so for a VF39, and an E85 tune and I'll be at the cost of the UTEC.
Old 08-29-2009, 11:16 PM   #13
JLBaja
Member#: 137951
2006 Baja Turbo Blue
Phat Botti Tuned
SS...next time I'm in Macungie visiting my sister (she lives next door to Mike - salesperson from Becker, the one with a TT and Jeep), I'd like to check out your Bad A$$ Baja!! I won't have my Baja with me since it doesn't leave Florida
JLBaja is offline   Reply With Quote
Old 08-31-2009, 12:50 PM   #14
Subie_Sleeper68
Member#: 166403
2006 Baja Turbo
LOL. He mentioned you to me! Sits in the next cubicle over too. Definately come by. I'll let you drive it.
Old 08-31-2009, 12:51 PM   #15
Subie_Sleeper68
Member#: 166403
2006 Baja Turbo
www.jscspeed.com has the utecs for a lot less. Mention you're on the forums and they usually give a discount too. The utec does SOOOO much more than you'd think. It saved my engine by pulling timing when it started to knock on a few occasions before the tune was fixed.
Old 08-31-2009, 01:01 PM   #16
Subie_Sleeper68
Member#: 166403
2006 Baja Turbo
Yup. Full list is SPT intake (going to replace it with a cobb or perrin unit that's not made of metal lol) gimmick inlet, TXS TMIC, 68 hta, 740 injectors, walbro 255, prodrive 3 port boost control solenoid, Utec Delta W remote map switch, alphawerks 4-1 header/uppipe,(BITCH TO INSTALL) titek catted DP (replacing with catless) random tech(xcceleration) cat back , perrin crank pulley PPG 1 - 4 helicals, 18 X 8 OZ Ultraleggeras Wilwood LGT 4pot fronts and '06 WRX 2pot rear conversion w/ Kartboy adaptors.Front and rear Whiteline sways.STI trans motor and stop pitch mounts. I think that's all. LOL I'll edit if I remember anything else. Dave, I'm not too far from Philly. I'm actually in Delco every other weekend to pick up or drop off my daughter at the ex's house. I live about 10 minutes from Dorney Park.
Old 08-31-2009, 09:34 PM   #17
BajaSleeper
Member#: 186725
2006 Baja Turbo
Sorry for the OffTopic..
Actually I heard the SPT Short Ram is terrible for heat soak. Because of all the heat coming from the turbo in that area. I heard (from my tuner {getadomtune.com}) you're better off sticking with your stock intake and changing to a K&N filter. I guess the short ram does something with the MAF sensor where it basically tricks the car into thinking it takes in more air which runs your car richer in fuel. Its more of a feel good mod, because you can hear the turbo sucking in air and it looks cool. Next time I go down to my tuner, I'll be sure to get the specifics. Just some advice from one subie/baja lover to another.
-BajaSleeper
Old 08-31-2009, 11:00 PM   #18
Subie_Sleeper68
Member#: 166403
2006 Baja Turbo
-BajaSleeper
ABSOLUTE TRUTH! The coolant lines actually clip onto the thing! I'm going Perrin. Maybe even Perrin cold air. Untill then the SPT unit has exhaust wrap hose clamped to it. Hahaha
tunning help fastfox17 South East Region Forum 3 02-08-2007 10:31 AM
Tunning Help jacket03WRX Engine Management & Tuning 4 07-14-2005 09:48 PM
ohh jebus need local utec tunning help? drifterx North West Impreza Club Forum -- NWIC 20 11-07-2003 12:31 AM
Link ECU tunning help WRXThis Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 06-17-2002 04:50 PM
('93-'01) Cobb Tunning ? Help Jimmy Impreza Forum 1 05-07-2001 09:36 PM
