Go Back   NASIOC > NASIOC Subaru Models > Baja Forum
Old 08-12-2009, 07:40 PM   #1
skullnbaja
Member#: 220083
2003 Baja Sport
Default U-Haul Hitch on Baja Sucks!
Had a hitch installed on my '03 Baja Sport a few years ago, complete with electrical hookups. Cost me about $180 from U-Haul. Anyway, after I got home I came to realize the hitch was loose! Took it back the next day and they said that is how it should be! WTF? I tightened a few nuts as best I could seeing as it's extremely difficult to get to the nuts. It no longer has play, but i still don't feel comfortable using my hitch for anything more than a bike rack.
Any suggestions on what I shoud do? Any one have similar problems from U-Haul? Been thinking about taking it to the Subaru dealer and having them install a factory Baja hitch instead.
skullnbaja is offline   Reply With Quote
Old 08-12-2009, 07:59 PM   #2
cowboy_Rob
Member#: 194062
2003 Impreza WRX
no way it should be loose. id try taking it to a different uhual dealer or calling the corporate office and complaining.
edit
no way the actual hitch bracket should be loose. its normal to have a tiny bit of play in the mount where it slides in and you put the pin through.
cowboy_Rob is online now   Reply With Quote
Old 08-13-2009, 07:46 AM   #3
scf
Member#: 189579
Quite possibly they installed the wrong hitch. There are two different models for the Baja. Can't remember where the break point is.
Check the driver's side top of the hitch all the way on the end. See if there's a tab that's up against your pinch seam. If so, take a grinder to the tab and then tighten things up.
scf is offline   Reply With Quote
Old 08-13-2009, 04:35 PM   #4
trabkabab
Member#: 149062
2003 Baja
I had a U-Haul hitch on my baja and the hitch actually bent a part of my unibody, where they had to drill a couple holes. If you plan on towing anything, you should replace the hitch with one that uses the OEM mounting points. I bough a new one over at etrailer and so far, no damage to my car.
http://www.etrailer.com/hitch-2003_Subaru_Baja.htm
The design that damaged my car is listed at the bottom. The first two are a much better design.
trabkabab is offline   Reply With Quote
Old 08-13-2009, 07:25 PM   #5
su-be3
Member#: 78702
2004 BAJA Turbo
Frost Pearl White
Cool
I installed a Subaru genuine part hitch when I bought MY BAJA, back in 2004.
VERY easy installation, 4 bolts, thats it. I forget what I paid for it back then, and I have used my hitch quite often, one time towing my pop-up home! (It weighed 3,000, empty! No, I don't recommend doing this!)
Recently, I checked all the bolts, no problems, tight as the day I installed it.
Go with the factory hitch, follow the instructions, and forget about it!
Keep it under 90, folks!
su-be3 is offline   Reply With Quote
Old 08-13-2009, 11:34 PM   #6
canuck37
Member#: 87491
03 Sport
Blk/Slvr
DITTO WITH ME - IMO, NEVER TRUST UHAUL OR OTHER AFTERMARKET STUFF ON YOUR SUBIE........HITCH, WIRING OR OTHERWISE..ALSO, IT CAN SET YOU UP TO BE LEGALLY LIABLE IF THE HITCH FAILED AND YOU CAUSED AN ACCIDENT.
canuck37 is offline   Reply With Quote
Old 08-13-2009, 11:47 PM   #7
JLBaja
Member#: 137951
2006 Baja Turbo Blue
Phat Botti Tuned
Absolutely....don't F#$% with installing a NON-Subie hitch!!
JLBaja is offline   Reply With Quote
Old 08-14-2009, 07:42 AM   #8
scf
Member#: 189579
Besides, when I priced it out for the hitch/harness, it was cheaper to get the OEM one.
Old 08-14-2009, 10:36 AM   #9
moonzie
Member#: 128537
2004 Baja Turbo
Red/Silver
Heh.. I think I bought my OEM hitch from a local member here a few years back. What was it.. $160? pretty good deal.
moonzie is offline   Reply With Quote
Old 08-14-2009, 01:00 PM   #10
skullnbaja
Member#: 220083
2003 Baja Sport
The one that damaged your car listed at the bottom is the same design U-Haul used. Its too damn narrow, the two above seem better designed as they span a much wider width and probably bolt to much more secure areas.
FS: impreza u-haul hitch reciever! scarsofterror SCIC Private Classifieds 1 05-07-2009 12:55 PM
Who was the 09 WRX sedan that just got clipped by the U-Haul truck on PCH? Leonardo Southern California Impreza Club Forum -- SCIC 8 01-29-2009 01:17 PM
My take on hauling tires on the hitch. GLwagon Tire & Wheel 11 03-19-2007 09:08 PM
Turbo Baja suck in deep snow? subafreak Baja Forum 21 02-02-2005 02:06 PM
Sighting: Silver 2002 Impreza Outback with yakima box, hauling ass on grizzly peak Impretzle Bay Area Impreza Club Forum -- BAIC 0 12-23-2004 01:46 AM
