Old 05-03-2002, 01:11 PM   #1
STEALTH-WRX
Member#: 7822
Multi layer snot green
Default when you have nothing to do...
what i do for a living is put air suspension on trucks and cars. i know everyone hates it but it pays my bills. we use a electric vavles made by a company called smc. all of the parts we use are 12v. when we want the trucks and cars to move fast we use nitrogen and co2. what i am getting at is that co2 ( because it has moisture in it) gets really cold when comming out. what i am going to do is have two smc 15 mm vavles on my car. one will be inside my bumper hidden with a few small nozzles pointed at my front mount to spread evenly. the other vavles will be under hood spray at vavious sections of my intercooler piping close to the throttle body. i will have a small remote tank in my trunk. its at about 3500 psi in the tank so it will last long. the reason for not us nitrous oxide is because of cost to refil and i dont want to blow up with my new turbo. so far i have heard that for every ten degrees drop you get about 1-2% power increase because of better efficiency. so if the air before the intercooler is lets say 200 degrees and my intercooler and all of my crap can make it 100 degrees, then i have just gained a large number.
if my car had 200 hp to the wheels and 1 % is 2 hp. then 2 hp for every 10 degrees would mean with a 100 degree drop i have gain 20 hp to the wheels.
i dont think that my idea is going to work, but i have nothing better to do and i have all of the parts at my work. and for those that have been there, you guys understand.
the entire unit with all of the lines, wires, vavles and tanks weigh about 30 pounds. its not too bad and i can even the car out a little.
STEALTH-WRX is offline   Reply With Quote
Old 05-03-2002, 02:18 PM   #2
blarg
Member#: 17811
blue
carefull!!! dropping temperatures like that on some parts can crack them....plastic...hoses....your engine block....a temperature shock like that could do some major damage...and the CO2 could also lower the partial pressure of O2 that finds its way into your intake screwing up your A/F ration....same ammount of air, but less O2 in it.
A while ago I had a friend with an old Honda. He had a radiator leak and overheated on the freeway. He pulled into a gas station, and used the water hose to re-fill his coolant...just to get the car home....the temp shock cracked his engine block.
I'm guessing most components aren't designed for severe temperature drops like that.....I KNOW it'll crack your paint right off....
blarg is offline   Reply With Quote
Old 05-03-2002, 02:23 PM   #3
jmott
Member#: 6713
2007 Prius
brown
Default Re: when you have nothing to do...
theres a company marketing a product that does exactly what you are planning.
I say go for it and test it at the track, and see how it does.
jmott is offline   Reply With Quote
Old 05-03-2002, 02:35 PM   #4
TypeC
Member#: 9794
02 2.5LWRX-Retired
335i w/twins
Thumbs up Re: when you have nothing to do...
funny you should say that. I say a dyno of a supra that sprayed Nitrous on the FMIC. It gaines 20whp just from that alone. That was awesome. This is cool since you'll already have access to the equipemt. Be sure to get some dyno pulls!
TypeC is offline   Reply With Quote
Old 05-03-2002, 05:14 PM   #5
NoLimitWRX
Member#: 6927
2016 WRX
Thumbs up
sounds like a worthwhile project!
... so, how much $ would the kind of setup you're talking about cost the average joe?
NoLimitWRX is offline   Reply With Quote
Old 05-03-2002, 05:34 PM   #6
nhluhr
John Wayne Toilet Paper
Member#: 7327
2008 Mazdaspeed3
2006 Wrangler Sport
well, no moisture in the CO2 is not why it gets cold.
PV = znRT.
It's the Gas Law. When you let the CO2 flow from a high-pressure region (whatever pressure vessel it's in) to a low pressure region (the front of the intercooler), it loses T.
nhluhr is offline   Reply With Quote
Old 05-03-2002, 05:35 PM   #7
nhluhr
Member#: 7327
2008 Mazdaspeed3
2006 Wrangler Sport
PV = znRT.
The idea sounds like fun and I look forward to hearing how well it works! Perhaps further gains could be found through better (and/or cheaper) compressed gases, such as liquid N2 which could be fogged at low pressure over the front of the intercooler and be VERY cold.
Old 05-03-2002, 06:23 PM   #8
kyllc2
Member#: 17066
nice idea man. keep us posted on the progress. maybe give a list of what's needed to make our own. i'm sure there's nothin to it. thanks
kyllc2 is offline   Reply With Quote
Old 05-03-2002, 07:10 PM   #9
zaxrex
Member#: 9898
Water Injected Blue
Like you said, you are going to need a lot of gass. The temp won't start dropping untill you start letting the gas out and get the pressure change. The aluminum in the intercooler will thake the thermal expansion shock, but just watch out for plastic/rubber parts(crack!).
You might also want to add a small water line or two near the nozzel. The venturi effect and all that high velicity air will suck the water up, then attomize it, make frozen mist. With the higher latent heat capacity of ice/water, you will get a higher efficiency heat transfer.
Rock on
zaxrex is offline   Reply With Quote
Old 05-03-2002, 07:25 PM   #10
kyllc2
Member#: 17066
awesome idea w/ the water. this is gonna be interesting. way to think. hehe
Old 05-03-2002, 10:35 PM   #11
STEALTH-WRX
Member#: 7822
Default cost
the total cost of this if you were to go and buy the parts are as follows:
smc valves (2) $60
co2 bottle $45 at advanced gas in huntington beach
air line/fittings $20
regulator $40
i hope it works good.
Old 05-03-2002, 10:38 PM   #12
jmott
Member#: 6713
2007 Prius
brown
Default Re: cost
smc valves (2) $60
regulator $40
"I hope it works WELL"
Old 05-03-2002, 11:10 PM   #13
Sordid Philosopher
Member#: 16854
2003 WRX Sedan
Talking my silly 2 cents
I wouldn't waste the spray to the radiator, I'd just do the intercooler.
I think it would be much more productive to inject the CO2 into the intercooler - I have been wanting to do this, but I don't know how to build/buy or what to look for in an injector into the intercooler.
I like your resources - I may look into it here.
Good Luck
Sordid Philosopher is offline   Reply With Quote
Old 05-03-2002, 11:41 PM   #14
Somber
Member#: 5118
be careful of thermal shock to the components... be careful to keep the spray focused on the IC alone and spread as evenly as possible...
Somber is offline   Reply With Quote
If you have nothing to do tonight, please come support my band. Kinsbane Southern California Impreza Club Forum -- SCIC 0 04-10-2009 01:49 PM
if you guys have nothing to do this thursday march 9th... SUBYDOODIE Southern California Impreza Club Forum -- SCIC 16 03-09-2006 08:21 PM
If you guys have nothing to do tonight... Danbob Tri-State Area Forum 0 04-24-2005 12:15 PM
when there is nothing to do after school halogen Member's Car Gallery 0 03-29-2004 04:23 PM
If you are in Rochester and have nothing to do tonight..... Shag-e Tri-State Area Forum 11 12-06-2001 09:58 AM
