Old 05-03-2002, 01:31 PM   #1
Ferg
built to spill
Member#: 14145
02 WRX BLOD
76 C30 Dually
Default 15" Rims for AutoX?
Looking for information on any 15" rims for AutoX that will clear the stock WRX brake calipers. Also something that would accept a 235 or 245 tire. Tried a few searches but nothing concrete.
Any recommendations? Thanks in advance!
Ferg
Ferg is offline   Reply With Quote
Old 05-03-2002, 01:59 PM   #2
Richard A.
Member#: 79
1999 2.5 RS
RBP
15x7.5 Volk te-37's fit a WRX I've seen them on one at Nationals. They have a 48 mm offset. They also make a 15x8 w/45 mm offset that will probably fit and may be a better choice if you're going to put 245's on them.
Richard A. is offline   Reply With Quote
Old 05-03-2002, 03:12 PM   #3
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
I have a set of the 15x8" Volks on order, should be here at some point this month (ordered them in February - thanks, Mackin! ). When I get them I can test fit them on my sister's WRX. If you plan to go with a 235 or 245 I would say an 8" rim is a necessity. I'm planning on running 225/50-15s on mine. Are there even any 245/xx-15s available?
The Raceline RL-7 also fits, it's a 15x7" with a +50mm offset. Strong but heavy - just weighed one of mine today and it was 19.75# (on a good shipping scale at the local Mailboxes, Etc type place). I knew they were heavy, but didn't think they were that heavy!
Since the Volks aren't here yet I just bought a set of Kosei K-1 Racings - 15x7", +45mm, 13.5# advertised weight. I'll try to test fit one of those on my sister's car tonight if I get a chance.
Pat Olsen
'97 Legacy 2.5GT sedan
OTC Touring4 #28
Old 05-03-2002, 05:37 PM   #4
BongMan
Member#: 2399
2001 Impreza RS
The Volks should be able to clear ths stock brakes, but not any brake upgrade.
The RL-9 will clear them as well, but I think theyr'e too heavy. they'll also clear the oem 4 pots but that might be it.
I would consider if you want to upgrade the brakes later. That should be a major factor in your wheel choice.
look at this site
http://spdusa.com/prod03.htm
they got some info that might help you.
BongMan is offline   Reply With Quote
Old 05-03-2002, 06:08 PM   #5
Austin
Member#: 7089
2016 STi
Keep in mind the available sizes of the tires you'll want to run...
For instance, Hoosiers aren't available in anything wider than a 225 in a 15" size. Stay with 16's, and you can at least get 245's.
Austin is offline   Reply With Quote
Old 05-17-2002, 11:40 PM   #6
CDTOYS
Member#: 8549
2002 WRX Wagon
Lightbulb What 15" would be best for the WRX ???
The 15" Kosei K1 wheels do not clear the WRX brake caliper. With all the different ideas about 15" wheels in 15x7 and wider, what is the best option for the WRX in 15" for use with Rally tires?? Are there limits for the racing classes that make a 15x7 better than a 15x7.5?? If a 15x7 with a 42mm offset cleared the U.S. spec WRX caliper and cleared the 4-pots, would that be prefered over a slightly higher offset 15x7.5?? If there is enough need for 15" wheels on the WRX, it is possible...
CDTOYS is offline   Reply With Quote
WTB: 15" Rims for WRX element533 Private 'Wanted' Classifieds 4 10-20-2004 10:26 AM
WTB: set of 15" rims for snow tires adam555 New England Impreza Club Forum -- NESIC 3 12-12-2003 04:53 PM
15" rims for WRX? Al Brakes, Steering & Suspension 6 02-21-2002 02:52 PM
Anyone got 15" rims for sale Petrie Vancouver Impreza Club Forum -- VIC 0 10-17-2001 09:55 PM
I am looking for 15" rims for autox, and snow tires. I did a search... Nothing. Boom Brakes, Steering & Suspension 5 10-01-2001 05:51 PM
