Welcome to the North American Subaru Impreza Owners Club Thursday July 2, 2015
Old 08-13-2009, 04:11 AM   #1
kpluiten
Member#: 120273
06 WRBWRXWGN
Now with 100% more Spec-C
Default 06 WRX, DOM 2.0, e85, 373whp/362wtq
Performance Data:
Open Source Tuned by Mark of Mark Jones Tuning
Motor Built by Robert of Forced Air Technologies
All Other Wrenching by Myself
Dyno:
Peak WHP: 373
Peak WTQ: 362
Dyno: Mustang
Correction Factor: 1.11
Fuel: e85
Ambient Temperature: 106 degrees (!!!)
Elevation: ~1100 ft
1/4 Mile:
1/4 Mile: TBD @ TBD
Vehicle Description:
Engine:
8.76:1 Compression Ratio
2.5L Short Block
EJ255 Heads
JE Pistons
Eagle Rods
ACL Bearings
Ported and Deleted TGV's
KS Tech Phenolic Intake Spacers
KS Tech Secondary Air Pump Deletes
Rotated Throttle Body
Throttle Bottle Coolant Bypass
KS Tech Mega MAF Intake (83mm)
Greddy EVO II Catback
Turbo System:
Blouch Dominator 2.0 - Ported Hotside
Tial 38mm EWG
GrimmSpeed EWG Up-Pipe
TWS Front Mount Intercooler
Bellmouth Down Pipe
BPM Turbo Inlet
MAC EBCS
Tune:
Open Source by Mark Hausholder of Mark Jones Tuning
Fuel System:
e85
Bosch 1000cc Injectors
DIY Parallel Fuel Rails & Lines
Walbro 255 Pump
Drivetrain:
2005 STi 6MT
Exeddy OEM STi Clutch Kit
Spiider Dual Mode DCCD Controller
OEM STi DCCD Buttons
Group-N Transmission Mount
JDM Shift Linkage
Brake System:
CarboTech Bobcat Pads
Goodridge Stainless Braided Lines
Speed-Bleeders
ATE Super-blue Fluid
Suspension:
RCE Wagon Specific Springs
Tokico D-spec Adjustable Struts
Group-N Tophats
Extra Camber Bolts
Cusco Adjustable 25mm Solid Rear Sway Bar
Kartboy Rear Endlinks
Hotchkis 1" Hollow Front Sway Bar
Hotchkis Front Endlinks
Interior/Misc.:
Maddad Clarity Rx EGT Gauge
Maddad Clarity Rx Boost Gauge
Autometer Cluster Surround Gauge Pod
TXS Knocklite
JDM Hazard Button
Jazzy Engineering AUX Input
Plastidip Center Dash Console
Hidden Hitch
Kartboy Long Hangers
LED Bulb Replacements
Roof Rail Deletes
Hella Supertones
Plots (Sorry for the poor quality):
Final Numbers:
Not quite final tune:
This one is skewed due to scaling. The real boost was 21.5 PSI and it was at about 20 PSI by ~4000 RPM. It gives you an idea of the lack of boost taper though.
Old 08-13-2009, 08:47 AM   #2
Vid_Maye
Member#: 154197
2006 Impreza WRX
WR Pearl Blue
JDM Hazard Button FTW.
Nice numbers chief.
Vid_Maye is offline   Reply With Quote
Old 08-13-2009, 09:35 AM   #3
boostdog
Member#: 149752
07 wrx tr
rr tuned stg2 12.8@105mph
wow very nice! you basically have the setup i want to run in a few years. good job...just get it to the track and see how it runs.
boostdog is offline   Reply With Quote
Old 08-13-2009, 10:17 AM   #4
juanmedina
Member#: 133146
07 FPgreen 7.37@95
WRX VF39+E85 12.0, 121mph
I am confused! so you made 373whp with 21 psi of boost? If so, why such a low boost on E85 and with a build engine? What is the injector duty cycle with 1000cc injectors?
Sick numbers , I want a big turbo
Old 08-13-2009, 10:26 AM   #5
kpluiten
Member#: 120273
06 WRBWRXWGN
Wirelessly posted (LG Voyager: Mozilla/4.1 (compatible; MSIE 6.0; ) 400x240 LGE VX10000)
Thanks guys.
Juan, I really just wanted a very laid back and safe tune/build. We could have run more boost I suppose, but 21.5 yielded great results especially considering how hot it was outside (106 degrees). Maybe we'll turn it up when it cools down.
The other issue was that those injectors were getting pretty close to maxed and we obviously didn't want to push them. If I increase my static fuel pressure I should be able to get more out of them, but that will require pretty large upgrades to the fuel system. At 100 psi, I should be able to get well over 1000cc/min out of them. We could prossibly lean the tune out a bit from the. but we wanted to take in safe and reliable.
All I can say is that the car scares the hell out of me. I've ridden in a couple "330 to 350 whp" subies and this feels much stronger in my opinion.
Old 08-13-2009, 10:53 AM   #6
juanmedina
Member#: 133146
07 FPgreen 7.37@95
I have JE 8.5:1 compression drop in pistons in my WRX, the compression in my EJ255 is 9.0 with OEM head gaskets. Do you have the 8.0:1 compression JE pistons ?
Is crazy that you are maxing out the 1000cc injectors at such a low boost with a 52lb turbo , I want to run next year a 57lb+ turbo in my car I wonder how big injectors will I need at 1000 ft of elevation.
Take it to the track it should be a mid 11 sec car in the lower side
Old 08-13-2009, 11:35 AM   #7
kpluiten
Member#: 120273
06 WRBWRXWGN
How do you know your compression ratio os 9.0:1? This is what JE estimated mine was when we called then about this? Are they just blowing smoke I wonder...?
Also, I was suprised about the injectors being so close to max too, but I suppose I don't have much experience with these things. Upping fuel pressure would help for sure. You should expect the same I guess since our elevation's are pretty similar. I've also heard, but cannot confirm, that these injectors flow less than comparable 1000cc units at a give pressure, but when it comes to tuneability, there is no comparrison. They perform very, very smoothly!
And mid 11's ?!? No way! I'm a terrible driver. If I broke into the 12's I'd be pumped! I'm not going out until it cools down a bit.
Old 08-13-2009, 07:43 PM   #8
KP
Member#: 147637
HJ's Ask
Hobbs. He knows.
It was more then 100 degrees in the garage that day. I wanna say your intake temps were up above 110 at one point. It's too damn hot here. Tech the wagon in at 14.0, and take me for a couple rides down the track, just hit the brakes at the end haha.
KP is offline   Reply With Quote
Old 08-13-2009, 07:57 PM   #9
juanmedina
Member#: 133146
07 FPgreen 7.37@95
Cameron at camtuning.com did my compression calculation.
Old 08-13-2009, 09:40 PM   #10
kpluiten
Member#: 120273
06 WRBWRXWGN
Hmmm... Maybe I should try that.
It would make sense that you could work backwards from the comp test numbers. Maybe I'll work on that this weekend. You've got me very curious becuase you're right, with 8.5:1 pistons and ej257 heads you get 8.5:1 and the ej255 heads are a smaller volume...
Old 08-14-2009, 11:04 AM   #11
blkscooby
Member#: 44422
2009 G8 GT
Cammed, sprayed, stalled
Let me take that thing down the track! I'll get you a 11 sec slip fo' sho'.
blkscooby is offline   Reply With Quote
Old 08-15-2009, 06:17 AM   #12
KP
Member#: 147637
HJ's Ask
Hobbs. He knows.
Hell Ken. I'll drive it down the strip for ya. I miiiight pull a Jay when I try to launch tho.. Key word try.
Old 08-15-2009, 12:33 PM   #13
kpluiten
Member#: 120273
06 WRBWRXWGN
I'd really like to see what it does when it cools down. We'll go in October when it's finally 75 degrees at night. Who knows, maybe we'll turn up the boost. I just saw some plots for a DOM 2.0 putting down 400+whp on a mustang at 24.5 psi.
Old 08-15-2009, 05:41 PM   #14
KP
Member#: 147637
HJ's Ask
Hobbs. He knows.
blah blah blah blah blah blah blah blah 400+whp on a mustang at 24.5 psi.
DO IT NOW.
Old 08-15-2009, 05:55 PM   #15
juanmedina
Member#: 133146
07 FPgreen 7.37@95
Originally Posted by KP View Post
DO IT NOW.
build motor and a 6 speed, I don't see why not...
just turn it up to 27psi
Old 08-16-2009, 06:10 AM   #16
KP
Member#: 147637
HJ's Ask
Hobbs. He knows.
C'mon Ken, I think it's time to let the wagon grow up and break the 400whp MD mark.
MAPerformance: 68HTA, Stock 2.0, E85 maperformance Proven Power Bragging 379 07-04-2011 05:19 PM
dom. 2.0 vs dom 2.5 mojosti Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 4 01-03-2010 10:46 AM
06 STI, Dom 2.5, Stock TMIC w Meth - 378WHP/425WTQ @ 26PSI AKOUTIN Proven Power Bragging 64 11-25-2009 02:14 PM
wtb: blouch 20g tdo6, dom 2.0,2.5 or fp green va05sti Private 'Wanted' Classifieds 3 11-21-2009 03:07 PM
06 wrx stage 2 map 100oct or E85 needed jonnies UTEC 1 05-24-2007 09:22 AM
