Old 08-13-2009, 05:53 AM   #1
Soukyoku
Member#: 201492
2003 Baja
Default My Baja is dying o me... :(
I don't drive a impreza but a 03 Baja... Hope yall can help me figure out whats wrong with my truck.
Two weeks ago my car got into serious jam. Took in water after driving through a foot and half high flood and an 18 wheeler drove past me so fast pushing water over my hood and the intake sucked in a lot water.
After 2 days of drying and cleaning. Car came back alive.... BUT began acting funny. Battery dying quick. Tested stock alternator and turn out to be bad and replaced it.
Seemed to work better BUT still experiencing random problem like I cant start it and had to have it jumped. Dashboard info (trip and clock) would reset to zero/random time. Headlights seem to struggle to have full power. Just like flashlight on weak battery.
Took it to Advance Auto and have them test it.... Everything passed including my battery.
Lately I've been unplugging gps from the 12v adapter... turning off head light (Including hand brake for DLR) before turning off the engine... Disabled celling light... So I wont have to ask around for jumps again...
I'm dumbfounded.. Help me anyone?
Soukyoku is offline   Reply With Quote
Old 08-13-2009, 10:10 AM   #2
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
Silver Sleeper Wagon
You obviously still have water in places.
You may want to lift the passengers front carpet and make sure the ECU is dry.
But, you still need to get some drying done inside as well as the engine compartment.
Your situation is a crappy one, way too many possibilities for issues.
BTW, yes it's NASIOC, but there are forums for Legacys, Foresters & Bajas.
Old 08-13-2009, 10:24 AM   #3
udelslayer
Member#: 117214
2003 WRX Wag'n Wagon
You can have.
wow, you didnt hydrolock?
water pools in strange places inside the body, could be causing grounding faults.
other than the electrical issues, which could be a lot of things, how is the motor running, power, idle, etc?
udelslayer is offline   Reply With Quote
Old 08-13-2009, 12:31 PM   #4
Cougar4
Member#: 53443
2001 LL Bean Outback
Winestone
Sorry to hear about that. The car may never be the same as before going through the water sorry to say.
You may have to go over most of the electrical connections under the hood at least and clean them. Check the main fuse panel under the hood for and signs of corrosion. Hopefully that will fix the wiring up but it may not. You might have to replace the main wire harness for the engine later on.
Old 08-13-2009, 01:26 PM   #5
Haelan
Member#: 151045
2013 Subaru STI
CBP
I would unplug every connector I can find and write them down in a log book. Let them air out for a few days and re-connect everything. I would also swap out the battery regardless. A lot of times those battery testers do not diagnose a bad cell.
Pull the carpet up and check the ECU for wetness. Also scan the ECU with an OBDII reader and see if any CEL codes are pending.
With the car off, use an ammeter and pull your fuses. Go to each fuse holder and complete the circuit with the meter leads. Check for excess current. If you find something post the fuse number here and at least that may narrow down the short to a small group of sensors.
Haelan is offline   Reply With Quote
Old 08-13-2009, 08:24 PM   #6
Soukyoku
Member#: 201492
2003 Baja
Wow Hydrolock seem scary (Never heard of it until today and googled it)... Now that you mention it.. I feel something new I never felt before. When I drive normally no problem.. But when I try to accelerate quickly I would feel deep rumble almost as if I have an nice aftermarket exhaust which I don't. Everything on the car is stock.
As for ECU... No water got into the car. The door seal did it's job.
No water got into the fuse box.
No codes are appearing on OBDII scanner.
No warning indicator on dashboard appearing.
I'll check each fuse when the god forsaken rain stop pouring... (I live in east coast)
Thanks for the responese everyone.
Old 08-16-2009, 11:57 PM   #7
Soukyoku
Member#: 201492
2003 Baja
I solved the problem with my electrical... Soo simple, stupid, idiotic, moronic, etc etc etc...
It was the main fuse. The one that get screwed down... My dad forgot to screw down the second bolt... It became loose and randomly not getting full contact.
Screwed in a new nut and now it's running like a champ.
Old 08-17-2009, 08:48 AM   #8
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
Glad you fixed the issue (regardless of how stupid you think it was) and then came back to report it for the next guy with a similar issue.
My Computer is Dying! Is there software to fix it? Nightwing Off-Topic 17 10-08-2008 11:10 PM
My baja is scaring me 2003Baja Baja Forum 3 09-02-2005 02:24 PM
Gotta leave my baja behind for 4 weeks :( 2003Baja Baja Forum 3 07-26-2005 02:42 PM
My car just died on me, ***? Capt Crunch Mid Atlantic Impreza Club -- MAIC 19 07-08-2005 02:05 PM
Ok, my car keeps dying on me...what's up? Sauginius Southern California Impreza Club Forum -- SCIC 6 11-07-2000 01:01 AM
