Old 08-13-2009, 01:30 PM   #1
gabedude
Member#: 10108
07 STI
60Trim spun rod bearing
Default Kamak turbos
Preface: Please do not post unless you have useful and reliable information (no posts like, it is just chinese crap).
My Blouch 20G is blown. It went downhill slowly and I am looking at upgrades (my CHRA may be broken is why).
So I am looking into turbos. I will not shell out 1800 for an ATP turbo, although I would love one, it is just not in the budget. This turbo is at the edge of the budget.
I have the fuel system to support E85 to 400+ WHP.
Now looking for a new turbo around 1000 dollars is tough to hit these goals even on E85. My 20G could do it, but now it is blown (mostly due to overboosting, reinstalling it many times as well).
Kamak website: link
Spec sheet on bolt on turbos: link
Turbo for sale on ebay: link
Details:
KAMAK SUBARU IMPREZA STi TD06SL2 Garrett 60-1 Turbo
n Bearing System: Journal Bearing
n Cooling System: Water & Oil
n Turbine Housing Nozzle Area: 8cm^2
n Turbine Diameter: 54mm/61mm
n Turbine Blades: 11
n CFM:[email protected] Bar
n Compressor Wheel: Garrett 60-1 76mm/59.5mm
n HP:500 HP
n Balance:150,000 On VSR
Features:
1. Turbine wheel & turbine housing hybrid design:
Considering quick-boosting so that turbine wheel just comes with 11 blades which is an very rare type, on the other hand, wheel size of TD06SL2 is larger than TD05H so that can keep the top end speed and get more horse power.
2. Thrust Bearing:
360 degree trust bearing that combines with thrust collar and trust ring doesn’t like a stander one, so that it can providers more tolerance of loading pressure at high engine RPM.
3. Compressor wheel:
Garrett 60-1 compressor wheel has more compressor efficiency and comes with smaller centre pillar than original MHI 20G improves air-flow.
Following Included:
n SUBARU TD05H turbo Oil & Water Install Kit
I have done several web searches on these turbos. Most forums are riddled with "It is another Chinese ebay junk turbo". However several people posted that they have used the Kamak branded turbos on Mitsus and Subarus with good results. Several forums mentioned people in Australia running Kamak turbos on their Subarus with great results. Leslie you there?
I doubt anyone here has experience with these, but perhaps someone does. If you have experience with any Kamak turbo (please do not chime in unless it is a Kamak turbo) I would appreciate your views on the turbo. I know Vlad has experience with their rebuild kits from doing a search.
The pricing of the turbo is slightly less expensive than more known names such as FP and Blouch, but it is not as cheap as the unbranded ebay turbos.
Kamak seems to be based in S. Korea with one US distributor.
Thanks,
Gabe
Edit:
After researching, Kamak is based out of Taiwan and makes many rebuild parts as well as the Japanese "Kinugawa" turbos. Read further for links on people who have used them successfully on Subarus, Nissans and Mitsus. Seems to be a good turbo.
gabedude is offline   Reply With Quote
Old 08-13-2009, 02:07 PM   #2
BlackFighter
Member#: 193940
2004 WRX STI Black
RalliSpec Shortblock
Hmm after reading about them and their website they look very well put together. Plus they are using a garrett wheel. I would deff give it a shoot.
BlackFighter is offline   Reply With Quote
Old 08-13-2009, 02:13 PM   #3
jason miller
Member#: 158313
2003 WRX
So they are using an 11 bladed turbine wheel? Sounds a lot like the same wheel FP used to use in their Green, and Deadbolt called their "Fatboy" wheel.
You know, you could always rebuild your 20g with a new CHRA for $500ish. Just throwing that out there...
jason miller is offline   Reply With Quote
Old 08-13-2009, 02:17 PM   #4
gabedude
Member#: 10108
07 STI
It is a TD05 and I kind of want to upgrade.
My fallback is the rebuild.
Old 08-13-2009, 02:20 PM   #5
kellygnsd
Member#: 32669
2007 2.34LR, EFR7670
LINK G4 hybrid STi
If you're trying to do this on the cheap why not just get your 20G rebuilt? Throw a stocker on there in the meantime and go with a $350 rebuild.
Old 08-13-2009, 02:38 PM   #6
gabedude
Member#: 10108
07 STI
If you know me at all, you know I like to experiment. My STi has been a testbed that many people have learned from. An expensive testbed. Sure, I would love a Green or an ATP turbo, but those are already known to be good. I have some method behind my madness. Plus, my wife has an 06 STi that may someday inherit the 20G I have when I rebuild it.
The latest example of my testbed efforts is the new design topfeed AP rails. There are some issues with the way AP assembles the AN adapters, but other than that they are great rails! Look at the Parts Review section for that review.
Old 08-13-2009, 02:41 PM   #7
BlackFighter
Member#: 193940
2004 WRX STI Black
Mmmmmmm wife that drives an STi, why can't all women be like that. Hell i think any women that drives a stick is hot, but an sti. :-)
Old 08-13-2009, 03:05 PM   #8
badmammajamma
Member#: 84419
2005 WRX STi
380whp ATP 35r
My wife funds my STI and sits in the passenger looking all pretty...I like that.
badmammajamma is offline   Reply With Quote
Old 08-13-2009, 03:10 PM   #9
gabedude
Member#: 10108
07 STI
Ok we are getting a bit off topic. Her (Tess on these forums) STi is Full stage 2+, built motor, and the road dyno is in proven power bragging. It scoots for a stock turbo STi on 93.
Her mod list:
Stage 2 shortblock (dropin CPs, came with car)
Full TBE (came with the car)
TXS TMIC
Samco inlet and MAF
APS 65 mm CAI
Cobb sport springs (came with car)
Khumo XS tires (they are sticky)
Old 08-14-2009, 11:59 AM   #10
StupidFastWagon
Member#: 157526
2014 335i xDrive
M Sport
the TEC 20g is more like a green... Btw my small 20g put down 340hp and 375tq
StupidFastWagon is offline   Reply With Quote
Old 08-14-2009, 12:26 PM   #11
gabedude
Member#: 10108
07 STI
Nice Wes. I was doing around 350 on my TD05 8cm^2 20G on gas with the topmount according to the road dyno.
The TEC 20G can't be any better than a Blouch. It does not have the same Green upgrade parts either.
How are you liking the STi? Totally different than a WRX huh?
Old 08-14-2009, 12:46 PM   #12
theotherguy
Member#: 191514
'05 FXT 6spd, 98
Fozzy lifted,'01 RS 6spd
I bought one.
Its not chinese crap, its taiwanese crap...big difference.
I hear that some names in import tuning get their turbos from them and then use their "rebranding" service and sell them as their own. Don't ask me, no law suits here.
Nissan crowd has run them with success for a while. Friend with a sylvia is going in his third year with one.
and as someone else said, just by the rebuild kit from them.
theotherguy is offline   Reply With Quote
Old 08-14-2009, 12:58 PM   #13
Badler
Member#: 133597
It's exciting to see other turbo options that are similar to overpriced name brand ones. Keep up the R&D for us!
Badler is offline   Reply With Quote
Old 08-14-2009, 01:33 PM   #14
habitatxskate
Member#: 197537
06 WRX
matte black
she have a sister? or a mother?
habitatxskate is offline   Reply With Quote
Old 08-14-2009, 01:57 PM   #15
gabedude
Member#: 10108
07 STI
Originally Posted by theotherguy View Post
I bought one.
Yes Kamak is based in Taiwan. I did a bit more research and saw the same comments about the US builders using Kamak parts (or re-branding). The EVO/DSM guys and Nissan guys are loving them.
I am sold.
http://www.dsmtuners.com/forums/newb...-10-turbo.html
That guy had all the Kamak parts on his EVO except the exhaust housing and bent a rod. Turbo was fine though. Definitely sold after doing more research. Looks like there is finally a good alternative to the cheap Chinese turbos. I have been to Taiwan and I trust parts made in Taiwan.
A green for 1150? No problem! I can even use some Kamak parts from them to rebuild my small 20g. Also, it is awesome that they carry actuators, and all the other parts to build or fix your own turbo. They do balance the bolt on turbos as well.
Although I have to wait for my b-day which is in October.
Nissan guys:
http://az240sx.org/forums/index.php?showtopic=42168
Old 08-14-2009, 02:27 PM   #16
torinalth
Member#: 141720
2005 LGT 5MT Sedan
Satin White
another option is to get the japanese venue and get Kinugawa brand. it's about the same cost and they have a Td06SL hotside and the 20g comp wheel... turbine is also 8cm. If I didnt't run out of time I was going to take that route myself....
so gabe, you don't by chance have a used STI turbo in good condition laying around do you? after all, when I was helping with your WRX tunes with the testing and logging hook a brotha up.
T
torinalth is offline   Reply With Quote
Old 08-14-2009, 02:34 PM   #17
gabedude
Member#: 10108
07 STI
T
Good idea, I'll look into that. I sold my stock turbo a long time ago.
Gabe
Edit: Those turbos seem like they may be made by the same manufacturer (Kamak) with their re-branding service.
http://cgi.ebay.com/TD06SL-20G-Upgra...4.c0.m14.l1262
This is 200 more dollars for the same thing. The pics are identical, except for the nameplate. Looks like we found the distributor and the lowest price Green!
Old 08-14-2009, 03:00 PM   #18
timeXlost
Member#: 113924
2005 STI....SOLD!
93 RX7...Not Broken
this td06 25g on their site has me thinking. anyone know anything about these?
timeXlost is offline   Reply With Quote
Old 08-14-2009, 03:14 PM   #19
gabedude
Member#: 10108
07 STI
Not sure about those. Look at the Kinugawa link here. They have info on them. It is the same turbo. It is just re-branded.
http://stores.shop.ebay.com/KINUGAWA...fsubZ353349014
Old 08-14-2009, 03:21 PM   #20
BlackFighter
Member#: 193940
2004 WRX STI Black
Can't say that untill someone puts both turbos side by side.
Old 08-14-2009, 03:38 PM   #21
gabedude
Member#: 10108
07 STI
Not saying that this is an FP Green. Just saying it has similar parts. I am sure FP uses slightly different parts and does not just re-brand.
However, you can tell from the ebay pics that the Kinugawa turbos are in fact made by Kamak. In the 240sx forum link you can see one of the turbos has a Kinugawa label on it instead of the Kamak label.
At least they are not cheap Chinese turbos. They are the cheap Tawain turbos that some people thought were Japanese turbos. They sell well in Britain it seems. It does make me wonder if some of the USA guys are re-branding these as well however.
Also, it seems people are having good luck with them on other platforms.
Old 08-14-2009, 04:09 PM   #22
gabedude
Member#: 10108
07 STI
Oil cooled only it looks like.
Old 08-14-2009, 05:30 PM   #23
fastwrx25
Member#: 126441
03 bugeye
lots of good info here.
and its true. Taiwan crap is still better than chinese crap. You'd be suprised at how much hi tech computer stuff that taiwan produces. They dont dominate the market like they used to in the 90s, but during that time production, quality control improved dramatically. I hope these turbos work well.
fastwrx25 is offline   Reply With Quote
Old 08-14-2009, 06:30 PM   #24
gabedude
Member#: 10108
07 STI
Like I said I have been to Taiwan as I am a software engineer. Definitely better than China.
Old 08-14-2009, 10:06 PM   #25
neg_matnik
Member#: 132389
2006 WRX Wagon SGM
2003 SV1000S, 2014 DL650
There's at least one guy that has been running a Kamak/Kinugawa turbo for a little while with good results:
http://forums.nasioc.com/forums/show...&postcount=441
Another person here as well:
http://forums.nasioc.com/forums/show...&postcount=401
neg_matnik is offline   Reply With Quote
FS: NoVA: Draco Performance Turbo Blanket for Small Frame Turbo. adjasont Engine/Power/Exhaust 4 06-05-2010 03:15 PM
Kamak Turbos drmichael Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 5 02-22-2010 07:04 PM
BNIB Kamak 18G 8cm and DW 650 sidefeeds badhogan Engine/Power/Exhaust 15 10-01-2009 07:34 PM
KAMAK Turbos? 98jdmwrx Pre-2002 Factory Turbo Powertrain 11 06-21-2009 01:10 AM
Kamak Turbos? somaguchi Newbies & FAQs 11 06-11-2009 03:37 PM
