Old 05-22-2013, 04:39 PM   #226
ResidentR
Member#: 281656
2011 DGM WRX
5dr limited
Originally Posted by SouthernWRX View Post
What other mods do you have done? Stock block and internals? TMIC or FMIC? Thanks.
Nice numbers by the way.
Thanks.
I actually put down a bit more power than that, but my tuner dialed back timing slightly to help keep the motor from blowing up too soon
That's just with an AEM intake, FMIC, DW1000 injectors, DW65C fuel pump, GS EBCS, and catted turboback exhaust.
Stock header, stock TGV's, stock inlet, and stock block.
ResidentR is offline   Reply With Quote
Old 05-22-2013, 06:06 PM   #227
Original-ATWRX
Member#: 357107
Originally Posted by ResidentR View Post
I got tuned with a KAMAK TD06SL2-20g a week ago on my 2011 WRX, and it made 370whp/381tq on a dynojet. Very happy with it so far, the billet compressor and sts turbine wheels are works of art.
That's good to hear, do you feel that the STS turbine helps the turbo spool quicker? Does it hold boost right up to red line?
Original-ATWRX is offline   Reply With Quote
Old 05-22-2013, 06:18 PM   #228
ResidentR
Member#: 281656
2011 DGM WRX
5dr limited
I haven't tried a non-STS turbine to compare it with, but the STS wheel has a lot more surface area than the older style wheel, while I believe being lighter. Not having seen the other option I cant tell you how big of a difference it makes, but it is definitely a quality piece of engineering and if I didn't get it I would certainly regret it. On a bigger turbo like this every little bit helps.
If you are on a tight budget and need to replace a turbo I wouldn't hesitate on going with the Kinugawa, but if you can save a little more I would say the KAMAK is worth the difference in price.
It holds boost all the way to redline, and wants to go way past it. Never before have I felt that the rev limiter was a severe performance limitation in my car
Old 05-22-2013, 07:28 PM   #229
Original-ATWRX
Member#: 357107
That's great to hear. I've already bought mine, it's in my wardrobe hiding from the wife
Being fitted on Saturday and mapped on Wednesday.
Old 05-30-2013, 12:55 PM   #230
Original-ATWRX
Member#: 357107
Well it's definitely a TD05-20G. Andy Forrest (THE MAN) mapped it this morning.
TD05-20G Billet with STS 9 Blade Turbine
HRC 340l/hr Fuel Pump
3 Port Boost Solenoid
3" Straight through Decat Exhaust
K&N Panel Filter
Made 391 BHP and 368 lb.ft Torque. The car ran out of Air and Fuel, but the turbo was still going.
Andy thinks with FPR or bigger injectors and an induction kit I will see well over 400bhp. Cracking Turbo and plenty at the top end, was pulling strong well past 6500 RPM.
Love it, Love it, Love it.
Not bad for a 750 Turbo.
Old 05-30-2013, 01:39 PM   #231
tekfoc
Member#: 21392
2014 45 AMG MB
WHITE /MB C300 4MATIC
K&N Panel Filter
what fuel injectors are you running at the time of tuning .
tekfoc is offline   Reply With Quote
Old 05-30-2013, 08:14 PM   #232
gurusan
Member#: 258165
2006 WRX Wagon
Nice turbo. You need a heatshield and turbo blanket though
gurusan is offline   Reply With Quote
Old 06-02-2013, 02:58 PM   #233
Original-ATWRX
Member#: 357107
STi Pinks. I think I'll try to lay my hands on some 750's
Old 06-02-2013, 02:59 PM   #234
Original-ATWRX
Member#: 357107
Can't get a heat shield on due to the oil feed, but will invest in a blanket soon.
FS: NoVA: Draco Performance Turbo Blanket for Small Frame Turbo. adjasont Engine/Power/Exhaust 4 06-05-2010 03:15 PM
Kamak Turbos drmichael Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 5 02-22-2010 07:04 PM
BNIB Kamak 18G 8cm and DW 650 sidefeeds badhogan Engine/Power/Exhaust 15 10-01-2009 07:34 PM
KAMAK Turbos? 98jdmwrx Pre-2002 Factory Turbo Powertrain 11 06-21-2009 01:10 AM
Kamak Turbos? somaguchi Newbies & FAQs 11 06-11-2009 03:37 PM
