Old 08-13-2009, 02:01 PM   #1
BTM88
Member#: 164350
2007 Impreza WRX
World Rally Blue
Default Gas light after spark plug change?
I just did a spark plug change on my 2007 WRX and when I got in the car to start it up the gas light came on and stayed on. I let the motor warm up to operating temp and it was still on. I unplugged the battery, let it sit for a while then plugged the battery back up and started the car again with the gas light still on. What could be causing this? The motor is running fine, holds idle great. Nothing else is abnormal except the gas light. Thanks for any suggestions.
BTM88 is offline   Reply With Quote
Old 08-13-2009, 02:13 PM   #2
munkis
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
stupid question but how much gas do you have?
Old 08-13-2009, 02:23 PM   #3
BTM88
Member#: 164350
2007 Impreza WRX
World Rally Blue
Haha. Not a stupid question, I should have said in my original post. I have half a tank.
Old 08-13-2009, 02:36 PM   #4
yarrgh
Member#: 80465
2001 2.5RS
Black Diamond Pearl
well, your gauge says you have half a tank. How much do you really have? The only way to tell is to either drain the tank, or go fill up and do some math. Maybe your gauge is broken.
Also, check for any wires that may have been messed with/left unplugged when you last tinkered with it.
Old 08-13-2009, 10:18 PM   #5
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
pinched a fuel line????
Old 08-15-2009, 12:25 AM   #6
fastnoypi
Member#: 6886
MY01 EJ207 HTA35r
AVCS ON!
loose ground?
fastnoypi is offline   Reply With Quote
Old 08-15-2009, 07:34 PM   #7
Uncanny
Member#: 133012
2015 STi
Lightning Red
Originally Posted by fastnoypi View Post
loose ground?
This has a good chance of being the culprit
Uncanny is offline   Reply With Quote
Old 08-15-2009, 09:02 PM   #8
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
Silver Sleeper Wagon
I'm not quite sure how changing spark plugs could have anything to do with the fuel gauge.
I also don't see a need to remove any grounds. shrug.
Old 08-16-2009, 01:38 AM   #9
Uncle Scotty
Member#: 16200
OK buy Nates beans
sounds to me like someone shouldnt be working on their car without supervision
Crappy Gas Mileage After Spark Plug Change Dutchman1101 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 10-14-2008 07:06 PM
Misfiring after spark plug change Nuke209 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 19 04-29-2007 06:12 PM
Oil temps after Spark-plug change AmolaitoPR Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 5 07-08-2006 11:27 PM
Starting problems after spark plug change ggergg Normally Aspirated Powertrain 7 09-03-2004 08:25 AM
Help! CEL On after Spark Plug change minx Service & Maintenance 5 01-08-2002 05:33 AM
