Go Back   NASIOC > NASIOC General > Motorsports > Autocross
Old 08-13-2009, 03:12 PM   #1
Jonnywrx
Member#: 207782
2006 WRX TR
SGM
Default R compound question
So I did my first autox a couple weeks ago in the DS class. However I was running street tires and a couple guys were on r-compounds. Can I run slicks in the DS class according to SCCA rules? Dont wanna buy a spareset of wheels and tires if not needed.
Jonnywrx is offline   Reply With Quote
Old 08-13-2009, 03:23 PM   #2
CamaroFS34
Member#: 6850
1996 Camaro Z28 1LE
& 2006 IAG WRX (ForSale!)
You can't run slicks, but you can run DOT-rated tires such as the Hoosier A6 or the Kumho V710.
The key word is "DOT-rated." If it doesn't have the DOT rating, it's not stock legal.
CamaroFS34 is offline   Reply With Quote
Old 08-13-2009, 03:30 PM   #3
Splash
Member#: 55936
04 WRX STi
You can run any DOT-approved tire in Stock. This includes the Hoosier A6 and Kumho V710, the top-2 favorites.
There are such things as racing slicks, which are not DOT approved that you can't run in Stock, but you can run them in Prepared and Modified classes.
That said, I recommend you drive on street tires for a season while your driving improves. R-tires will be worth more once you know more about where to push and where not to.
Splash is offline   Reply With Quote
Old 08-13-2009, 03:56 PM   #4
Jonnywrx
Member#: 207782
2006 WRX TR
SGM
What kind of shoulder would be best?
Old 08-13-2009, 04:16 PM   #5
Draken
Member#: 16
1968 Saab
Sonett II V4
I like broad shoulders. And big calves.
Draken is offline   Reply With Quote
Old 08-13-2009, 07:38 PM   #6
Jonnywrx
Member#: 207782
2006 WRX TR
SGM
I saw there were 3 types. And im a serious noob when it comes to r-compounds. Rounded shoulder, Heat cycle, Square shoulder
Old 08-13-2009, 07:54 PM   #7
Cr0usEEE
Member#: 220048
2000 Camaro
Don't worry about heat cycle for autox...it really doesn't matter with the current compounds.
Rounded shoulder is for people who have limited negative camber up front...Usually best with stock class cars.
Square shoulder is best if you are running 2 or more degrees of negative camber.
And that would be for Kumho's...
Hoosiers only come in one flavor and they LOVE CAMBER...and hate Mini's
Cr0usEEE is offline   Reply With Quote
Old 08-14-2009, 01:11 AM   #8
MurphysLaww
Member#: 171245
99 328i
STX for 2013?
I'm lovin' my Kumho XS'es. They are about as close to an R-comp as you can get. 235/45/17's ran $173/tire @ Tire Rack.
I'll be running DS/Tire class.
MurphysLaww is offline   Reply With Quote
Old 08-14-2009, 08:41 AM   #9
neilschelly
Member#: 94902
1988 911 Carrera 3.2
If you do decide to get R-compounds, you'll need another set of wheels/tires for it. They are very expensive tires to drive on the street for all of the few miles they'd be good for before the wear bars are through. And if it's raining, that will be a scary few miles. ;-)
I'd concur with others just to drive for now. Tires will make you faster, but not by as much as just coming to a second autocross.
-N
neilschelly is offline   Reply With Quote
Old 08-18-2009, 01:40 PM   #10
bcblues
Member#: 17256
04 STi
Blue w/ custom bug splat
IMHO, tires are the single biggest improvement you can make to your times in AX. Since you just ran your first AX, I would recommend a quality set of ultra performance street tires for your first season. Kumho XS or Dunlop Direzza Star Specs are excellent tires for both street (during the summer) and AX, and are reasonably priced. You will learn more driving on the ultra street tires than you will driving on r-comps the first season - unless you are some sort of driving prodigy.
bcblues is offline   Reply With Quote
Old 08-18-2009, 07:03 PM   #11
Jonnywrx
Member#: 207782
2006 WRX TR
SGM
Thanks for the help guys, Im gunna try to pick up some beater rims to throw on for when I race.
Old 08-19-2009, 08:15 AM   #12
bcblues
Member#: 17256
04 STi
You can drive daily with the ultra street tires. No problem (except in snow).
STi swap wiring question BMXspears Subaru Conversions 7 06-04-2010 02:32 PM
Compound allignment question CalcVictim New England Impreza Club Forum -- NESIC 5 04-30-2004 08:09 AM
Hoosier R-compounds Questions uuarex Tire & Wheel 18 04-16-2004 02:49 AM
R Compound Question jonmacs22 Mid Atlantic Impreza Club -- MAIC 7 02-24-2003 08:04 PM
R compound tire wear question??? 2QUICK4U Brakes, Steering & Suspension 24 03-05-2002 12:02 PM
