Old 08-13-2009, 07:56 PM   #1
gregr01
Member#: 49333
04 STi
java pearl black
Default PDE camber plate owners--replace your allen head bolts
If you own PDE camber plates you know how great they are, but if you change settings frequently you also know the weak spot is the allen-head bolts.
Having lost one cap to a rounded bolt head (had to drill it out, completely demolishing the cap), I was struck with fear after a recent autox when two of the bolt heads wouldn't turn (slighlty rounded). Changing setting while the engine bay is extremely hot increases the likelihood of this occurring.
I drove home on the autox setting, and carefully removed the bolts with a new allen socket. I then searched online for replacement bolts in 12.9, which I found at boltdepot.com.
The specific part costs $0.56 each:
#6545 - Metric socket head screws, Steel grade 12.9, 6mm x 1.0 x 45mm
The head is knurled but fits perfectly into the recess. No problems, and no more worries about rounding.
gregr01 is offline   Reply With Quote
Old 08-13-2009, 09:51 PM   #2
controler
Member#: 100271
I have the PDE plates, they've been installed for about a year and changed I'd guess 25+ times. This hasn't helped me yet but I've been extremely careful when tightening/loosening the bolts. I knew someone that rounded off their camber plate bolts, so I've tried to be more careful.
controler is offline   Reply With Quote
PDE Camber plate "tophat" bolt/stud size? (should be the same as stock) Acejam2k Brakes, Steering & Suspension 3 05-04-2009 11:13 PM
PDE Camber Plate V1 Owners - Help with Measurement Moondongle Brakes, Steering & Suspension 0 01-21-2009 08:23 PM
For Sale: STi RA springs, Koni inserts, PDE camber plates TheMirror Private 'For Sale' Classifieds 7 04-27-2006 02:18 PM
PDE Camber Plate Owners : Noise? Scott Farmer Brakes, Steering & Suspension 4 11-15-2005 10:44 PM
PDE Camber Plates! SpeedAbsolute Suspension/Brakes/Handling 8 07-07-2004 01:59 AM
Message Board Statistics All times are GMT -4. The time now is 08:26 AM.
