Welcome to the North American Subaru Impreza Owners Club Monday February 8, 2016
Old 08-13-2009, 10:09 PM   #1
4sworks
Member#: 26119
2015 WRX Limited
Crystal White Pearl
Default CEL Code: P1090 Tumble generator valve #1 (RH) malfunction (stuck open)
Has anyone had this CEL Code come up for the Check Engine light? I was wondering if anyone knows if this is an easy (cheap) or hard (expensive) fix...
4sworks is offline   Reply With Quote
Old 08-13-2009, 10:35 PM   #2
hinoki01
Member#: 182942
2004 WRX Impreza Wag
I'd suggest hitting up one of the vendors here and getting some TGV deletes. It's somewhat complex to get to, as you've got to pull off the intake header and gank the old TGV's then put the deletes in... and then you've got to flash the ECU to ignore the TGV codes.
After that, you're golden. And it's a damned sight cheaper than buying new TGV's from the stealerships.
-Hinoki
hinoki01 is offline   Reply With Quote
Old 08-14-2009, 01:32 AM   #3
beaviscih
Member#: 123362
'93 Crapcan, '98L
Sold, '04 STi - Sold
Check the plug on the TGV sensor first. Its the big black thing on the TGV housing.
beaviscih is offline   Reply With Quote
Old 08-14-2009, 10:21 AM   #4
S7un7
Member#: 181709
2004 WRX Stage II
^This. You might not have the same issue as I did, but I had that code a few weeks ago. I bought some used TGVs, replaced the motor and sensor and the code is gone. I'm eventually using the TGV for a delete or selling them deleted. Replacing the TGV is quite a bit of work. Definitely research if you plan on removing them yourself.
S7un7 is offline   Reply With Quote
Old 08-14-2009, 10:54 AM   #5
Ryan314
Member#: 82989
Hybrid VF22
Ahhh, those damn TGVs. I have a consistent stuck open code (P1092, I think..) I've tried replacing the sensors, but nothing works. Car runs fine with the code so whatever. I did at one point have a stuck closed TGV code. This code will throw the car into limp mode, which is not good.
Is your car running like crap with the code you're getting?
Ryan314 is offline   Reply With Quote
Old 08-14-2009, 11:33 AM   #6
Danep21
Member#: 215816
I got a question guys, and i dont mean to threadjack, but i didnt think a new thread was necessary. The Girlfriends STi, will randomly throw a CEL. The funny thing is, the Cruise Control light always start blinking when the CEL comes on, then the Cruise Control Doesnt Work. 2006 STi, Intake, TBE, and Cobb AP.
First time: Was passing someone, shifted at redline. CEL and CC Light came on.
Second Time: This Morning, doing some pulls with an EVO, once again, CEL & CC Lights.
She doesnt have the Accessport Module so we can plug it in and read the Code.
Anyone have any ideas? Both times we disconnected the Negative battery Terminal, and the lights went off.
Danep21 is offline   Reply With Quote
Old 08-14-2009, 02:23 PM   #7
S7un7
Member#: 181709
2004 WRX Stage II
I don't know about the newer models, but my 04 lost it's balls when it threw the TGV code. I was getting passed by soccer moms in mini vans on the highway.
Should have started a new thread. How do you know your problem is TGV related? Next time the CEL goes off get the codes read, write them down, and then we can help you.
Tumble generator valve CEL TyranosaurusWRX Newbies & FAQs 11 08-09-2010 09:46 PM
P2009 CEL Tumble Generator Valve 97OBWagon Service & Maintenance 4 12-29-2008 07:31 PM
Help ... CEL 1086 re: Tumble Generator Valve Actuator lupohki Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 11 05-20-2005 08:14 AM
HELP! P1088 - Locating Tumble generator valve #1 scoolbuzz Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 15 02-08-2004 06:31 PM
Check engine. Tumble generator valve EPD Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 06-12-2001 12:47 PM
