Welcome to the North American Subaru Impreza Owners Club Sunday August 28, 2016
Old 08-13-2009, 09:46 PM   #1
RhinoRex
Member#: 29825
2002 WRX Wagon
WR Blue
Default Need help with jack stands
I'm going to change my own brake pads for the first time ever next week. I have some questions about putting the car on jack stands.
Can I put it up on one jack stand at a time? That seems to me like it would twist the car. If I do it two at a time, should it be front then back or passenger then driver. Or do I need to get it up on all 4 jack stands?
Right now, I only have the jack that came with the car. If I use that jack and do more than one jack stand at a time, that will mean jacking it up, getting the jackstand underneath, then moving the jack and jacking up the next wheel. Again, I'm concerned about twisting the car and about whether that would rock the first jack stand. Is it important to get a floor jack?
I am working on a 2002 WRX Wagon. I read the instructions at scoobymods, but those use a floor jack and he does not use the jack points that the manual recommends.
So how should I go about this? Any advice is welcome. Sorry for being so compulsive, but it's my first time doing this and brakes are serious.
RhinoRex is offline   Reply With Quote
Old 08-13-2009, 10:18 PM   #2
nkx
Member#: 96951
2004 wrx sedan
'10 Outback 6mt-wifey's
i would definitely invest in a floor jack. you could probably change your pads without one, but that way would involve jacking up either the whole left or right side and doing the front and rear on that particular side at once. problem this way is going to be getting a jackstand to support the car in the same place youve just lifted it at.
nkx is offline   Reply With Quote
Old 08-13-2009, 11:01 PM   #3
yarrgh
Member#: 80465
2001 2.5RS
Black Diamond Pearl
think of it this way: whenever you drive around on a non-perfect surface, it's going to twist the chassis somewhat.
If you plan on doing a lot of your own maintenance, invest in a jack + stands. It helps a whole lot. And don't forget the torque wrench for your brakes.
Old 08-14-2009, 01:24 AM   #4
RhinoRex
Member#: 29825
2002 WRX Wagon
WR Blue
That was one of the things I was thinking about because there isn't much room at those recommended lift points.
I saw a floor jack and 2 jack stands at autozone for $40. I think I'll get those.
This may be a stupid question, but is there any advantage or disadvantage to putting the car up on all 4 jack stands? Or should I just do fronts and backs?
Thank you both for replying.
Old 08-14-2009, 03:33 AM   #5
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
Silver Sleeper Wagon
I typically don't lift the whole car up, I do an end or a side at one time.
As to a "set for $40" from ANYWHERE is not going to last. If you plan on doing lots of regular maintenance I would save up and get a decent 2-3 ton floor jack. It's going to be close to $100 but it's worth it in the long run.
A nice Sears Craftsman steel one will work, the "cheap" Craftsman aluminum one looks great, but many have had seal issues.
Old 08-14-2009, 08:56 AM   #6
bluescoobywagon
Member#: 14911
Not A Wagon!
2011 WRX - 285s on 18x9.5
I've had one of these (mine's gray) for 17-18 years. It's never leaked and still works like new. I use it a lot, too. I will admit that it's a bit small for lifting heavier cars, but a little excersize is good for you.
http://www.sears.com/shc/s/p_10153_1...ment+%26+Jacks
EDIT: I dunno, maybe a better one?
Last edited by bluescoobywagon; 08-14-2009 at 09:00 AM. Reason: Hmm... The reviews don't look good for that one. What's up with that?
bluescoobywagon is offline   Reply With Quote
Old 08-14-2009, 10:07 AM   #7
rkramer
Member#: 118209
2015 WRX Limitec
Mine cost under $20 at walmart, 5 years ago. I use them ALOT and have never had an issue. Rule #1, you NEVER trust a single point of failure when your body being squished is on the line. I've never had a cheap jack stand fail, but I've never given it the chance to fail and kill me either.
Old 08-14-2009, 12:58 PM   #8
leecea
Member#: 37359
2003 WRX
Doing brake pads is very simple and you are not under the car or at any significant risk, so I'd be OK with the cheap stands.
I'm pretty paranoid when I'm getting under the car and I was able to get the Sears 4-ton stands on sale. Their size and the width of their base makes me feel safer.
leecea is offline   Reply With Quote
Old 08-16-2009, 12:47 PM   #9
Tagerman
Member#: 205708
2008 Outback Sport
Black and dark grey
Jackstands are extremely easy but can be dangerous if not done right. Make sure the car is level and you have wheel stops. I wouldn't bet my life on my parking brake lol. Also the best place to put the jack stands are on the frame rails this gives them a large contact area and makes them less likely to slip. As far as one as a time that seems like a bit of wasted effort but it won't harm the car.
Tagerman is offline   Reply With Quote
Old 08-16-2009, 03:25 PM   #10
RhinoRex
Member#: 29825
2002 WRX Wagon
WR Blue
Thank you everybody for your replies. I bought an AC Delco floor jack and a pair of jack stands.
So now I've got 2 more questions.
1) How do I recognize the frame rails? I have the repair manual so if you can refer to a part there, that would be great. I would use the recommended jack points, but my jack stands are relatively shallow and I won't have time to get one of those pinch weld adapters for the jack stands.
2) I borrowed a torque wrench from Autozone. It's about 2.5 fee long and pretty thick so there's no way it's going to be able to get behind the brake pad assembly to the bolts that hold the caliper down. Is there a way to weasel it back there or do I just need to fine a smaller one? I think they thought I only wanted it for the lug nuts.
By the way, in case anybody finds this thread from a search, here are the instructions I'll be following:
http://www.clubwrx.net/forums/mainte...-pads-wrx.html
Except I'm going to swing the caliper up instead of removing it (a suggestion that comes up later in the thread).
Thanks again!
Old 08-18-2009, 12:40 AM   #11
nkx
Member#: 96951
2004 wrx sedan
well you can only get the frame rails behind the front wheels. at the rear, i put my jackstands under the little plate that ties the rear crossmember outriggers to the body, just in front of the rear wheels. as far as the torque wrench, im not sure. it is hard to get something that bulky back there. i just make the bolts farking tight with a 1/2" drive ratchet.
Old 08-18-2009, 12:41 AM   #12
nkx
Member#: 96951
2004 wrx sedan
oops5
Old 08-18-2009, 09:26 AM   #13
rkramer
Member#: 118209
2015 WRX Limitec
Turn your steer wheel all the way to one side. it will offset it more than enough to be able to get the wrench on it.
Old 08-18-2009, 12:19 PM   #14
leecea
Member#: 37359
2003 WRX
Whoa - wait a minute. The bolts that hold the caliper to the sliding pins are pretty small. Don't go crazy on them. Torque spec is 27 ft/lbs.
I think once the car is up and the wheel if off, you'll be able to get the torque wrench on the bottom bolt, which is the only one you need to remove since you're swinging the caliper up. You'd be better off with a smaller 3/8" drive torque wrench, but you can make do with what you have.
Columbus, OH: Need help with TMIC install.. taketurns Mid West Subaru Owners Club Forum -- MWSOC 0 06-04-2010 05:15 PM
need help with a/c compressor replacement sen7inel Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 0 06-04-2010 08:53 AM
In Need of 4 Jack Stands This Weekend westin_impreza North West Impreza Club Forum -- NWIC 8 02-17-2005 01:28 PM
Need help with LinkPlus stand alone & ej22t lotus2843 Engine Management & Tuning 17 01-03-2005 12:39 PM
Need Help with Springs. My Compressor just broke, Car is stuck on jack stands STEALTH-WRX Southern California Impreza Club Forum -- SCIC 33 08-17-2003 02:10 AM
